AC blows cold on driver side, warm on passenger and back
Discussion in '2.5 Gen Tundras (2014-2021)' started by Jakopotamus, May 26, 2023.
  1. May 26, 2023 at 7:42 PM
    Jakopotamus
    Jakopotamus [OP] New Member
    As the title says, when I turn the ac on, it blows cold out of the driver and hot out of the passenger. It's an SR5 with single zone control so there's no passenger blender door. I pulled apart the driver side actuators and blenders and they looked fine and operational. Any other suggestions besides AC charge?
  2. May 27, 2023 at 10:34 AM
    rodm1
    rodm1 New Member
    How long have you had this problem? It takes like a half hour to get to a nice level on very hot days. I role down the windows for like 5 minutes until I feel cooler on my skin then role them up half way at that time. Then again when cooler I role them up until they are open like two inches at that time I role RF and LR windows all the way up leave it like that until comfortable. Set the AC to the floor and leave the RR cracked helps push the hot air out.
    Toyota AC success.
    D4x4TRD likes this.
  3. May 27, 2023 at 11:14 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    What year truck do you have?
  4. May 27, 2023 at 2:29 PM
    doggunner
    doggunner New Member
    2014 Tundra Crew max White
    Had the same problem. But in winter and it sucked. I am guessing it’s the blend door has failed and the whole unit needs to be replaced. 2500$. They have to take dash out. The HVAC system. Ya it sucks ass
    rodm1 likes this.
  5. May 27, 2023 at 3:11 PM
    rodm1
    rodm1 New Member
    2017 new it sucked Toyota has never cared to much about the comfort level in there Tundras maybe 2023 is different.
  6. Jun 3, 2023 at 7:21 PM
    LJOHNS
    LJOHNS New Member
    It probably servo assembly. I have the same issue and also my hvac has a delay at start up. Its a pain in the a** to get to. Will be working on mine next week. The part is about $120. Good info here:
  7. Jun 3, 2023 at 7:48 PM
    ToyotaBeast
    ToyotaBeast New Member
    Is the passenger side full heat or just warmer then the driver side with the a/c on?
  8. Jun 4, 2023 at 5:50 AM
    LJOHNS
    LJOHNS New Member
    Not full heat. Just warm and not cool at all.
  9. Jun 4, 2023 at 5:57 AM
    ToyotaBeast
    Either hvac box issue with the internal doors very rare or a low freon charge. The low freon will only cool half the evaporator core causing the driver side to be cold and passenger side to be warmer.
    fiyo1031 likes this.
  10. Jun 4, 2023 at 6:28 AM
    LJOHNS
    LJOHNS New Member
    There is about a one minute delay for my hvac to turn on when I start the truck. That tells me the doors are not in the proper position.
  11. Jun 5, 2023 at 8:23 PM
    fiyo1031
    fiyo1031 New Member
    2008 white tundra
    same problem on mine 2008 tundra low freon was the issue
