*Resolved*
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sacul, Jun 5, 2023.
  1. Jun 5, 2023 at 12:02 AM
    Sacul
    Sacul [OP] New Member
    2024 Tundra Limited TRD
    Nothing yet
    I know RainMan posted a very detailed wiring diagram but it might as well be rocket science to me.
    2021 SR5 5.7L TSS 4WD CrewMax
    Left hand drivers seat w/o climate control & w/o seat position memory
    My seat is stuck in the forward position, it will not even try to lean back. I think my electric seat switch is bad. I don’t know for sure but when I push the switch to lean back I don’t get the same audible/physical feedback that I do going forward. It’s not the circuit breaker because all the other seat position movements work.
    I work out in the desert for weeks at a time and I’m nowhere near a dealership. I was wondering if I could bypass the switch with a jumper to lean the seat back until I can get to the dealership. I have spare wire. Plus this would help me diagnose if it’s the switch or the motor.
    Where would I need to place the jumper on the pin receptacle?
  2. Jun 5, 2023 at 3:11 AM
    2mchfun
    If you go to the garage heading and then to electrical sub heading you will find all wire diagrams.
  3. Jun 5, 2023 at 4:35 AM
    Sacul
    Nothing yet
    Yeah the one RainMan posted.
    I’ve found the right diagram but not sure where the power/ground comes in. The power goes into the switch on the same connector that it goes out to the motor. So all I know so far is that the electric motor is terminals 9 & 10. Reverse polarity to power opposite direction.
    2mchfun[QUOTED] likes this.
  4. Jun 5, 2023 at 5:05 AM
    Sacul
    Nothing yet
    Actually I just got lucky with my multimeter finding the power/ground. It worked. Nevermind. This post can be deleted
    2mchfun likes this.
  5. Jun 5, 2023 at 5:25 AM
    Sacul
    Nothing yet
    RainMan_PNW and 2mchfun like this.
  6. Jun 5, 2023 at 5:25 AM
    2mchfun
    Exactly what I was about to suggest
    Sacul[QUOTED][OP] likes this.
