Help with lift
Discussion in '2nd Gen Tundras (2007-2013)' started by Jason71, Jun 3, 2023.
  1. Jun 3, 2023 at 11:28 AM
    Jason71
    Jason71 [OP] New Member
    2011 tundra
    Lift big tires
    I purchased a 2011 with a R/C leveling kit with ucas diff drop and a 2” spacer on top of the front struts. I want to get new struts and getting mixed reviews if I need the 2” or 3.5” lifted struts to delete the spacers. Does anyone know the definite answer? Thanks!!!
  2. Jun 3, 2023 at 3:35 PM
    blenton
    blenton New Member
    You have lots of options to get rid of the spacer - from bilstein 5100’s to Dobinson MRR or Fox 2.5’s. If the spacer measures an actual 2” thick, that equates to about a 3.5” lift. The strut to wheel motion ratio is about 1.7 : 1 - meaning, if the strut moves 1”, the wheel moves 1.7”.
    3.5” with a simple adjustable height strut like the Bilstein 5100 or Eibach Pro Truck is going to be a tall order as they typically met 2.5” or so of lift, as well as produce a less comfortable ride. Look for struts that are setup for 3.5” lift; they usually supply longer coils and have a longer extended length than stock.
    Jason71[OP] likes this.
  3. Jun 3, 2023 at 3:40 PM
    Jason71
    2011 tundra
    Lift big tires
    Thank you. Rough country makes a 3.5” strut that seems to have good reviews. With the 2” spacer I didn’t know if I needed a 2” or 3.5” strut. Thanks!
  4. Jun 3, 2023 at 8:57 PM
    blenton
    blenton New Member
    As noted above, pull out a tape measure or calipers or ruler and measure the spacer stacked atop the strut. Multiply that by 1.7 and that should tell you what size lift you need to match what you already have. If the spacer is 2” tall, the lift is 3.5”. If the spacer is 1.25” tall, then it’s a 2” lift.
