Remote tail gate locking for 2019 Platinum, Crew Max.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sal_160, Jun 1, 2023.
  1. Jun 1, 2023 at 10:19 PM
    Sal_160
    Sal_160 [OP] New Member
    2019 Tundra Platinum
    I have 2019 Platinum, Crew Max. The tail gate has to be unlocked with the key. For what I understand, it’s a cheap factory design that the locking mechanism can’t be controlled remotely from the key fob.
    Anyone knows of a kit or modification to control the tail gate lock remotely with the key fob?
    Thanks,
    r
    Tripleconpanna likes this.
  2. Jun 1, 2023 at 10:46 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    This became available as a dealer installed accessory (I think in 2019). Most of us ended up installing the OE set up.... Looks like you have a crewmax, so this would be the correct part# for you:
    PK3B6-34JS0 Tailgate Lock $129.71 (this is what I paid last year to give you an idea)
    https://www.tundras.com/threads/2018-power-tailgate-lock-new-toyota-accessory.52150/
    I'm very happy w/mine :thumbsup:
    If you don't feel like installing yourself most Toyota dealers are happy to do it for you; and if you don't already know, some Toyota dealers have different rates for 'mechanical' vs. 'accessory' labor. Generally speaking though, the service dept won't tell you this outright, so you normally have to ask. The power tailgate lock is considered an accessory, so if they differentiate between the two labor types you'll find it to be a bit more reasonable for labor fees. (An example of this might be the dealerships service dept charges $130-$140/hr mechanical labor, but only charges $80/hr for accessories).
    Good luck!!!
    rdiddy5 and GODZILLA like this.
  3. Jun 2, 2023 at 5:26 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    $195 now. That's wild.
  4. Jun 2, 2023 at 6:09 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
  5. Jun 2, 2023 at 6:17 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    Mine quit working a while back and I just haven't addressed it yet.
  6. Jun 2, 2023 at 6:18 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Any reason this one wouldn't fit on a 2020? Post only shows through 2019.
  7. Jun 2, 2023 at 6:18 AM
    Beach Toy
    SE NC
    2017 White SR5 4x4
    Now that makes a lot more sense than $200 for an actuator. May have to get this one myself and just swap them out.
  8. Jun 2, 2023 at 6:34 AM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    I dont see why it wouldnt, same truck, body etc
  9. Jun 2, 2023 at 6:37 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That's what I'm thinking too
    BigdaddyII[QUOTED] likes this.
  10. Jun 2, 2023 at 6:38 AM
    BigdaddyII
    South Louisiana
    2019 Ram 1500
    You may be able to swap just the actuator depending on the design of the one you have installed. The one I linked, that I installed on mine is a pretty simple deal to swap actuators, I even removed it and tried an extra actuator I had lying around just to be sure. Just slides out and the new one in, and standard plunger actuators are pretty cheap.
    https://www.amazon.com/InstallGear-...refix=door+lock+actuator,aps,108&sr=8-1-spons
  11. Jun 2, 2023 at 7:23 AM
    Beach Toy
    SE NC
    2017 White SR5 4x4
    Mine looks exactly like the first one you linked. Even looks like the same wires so it may actually be the same one the original owner put in.
  12. Jun 2, 2023 at 7:41 AM
    campbell_j_c
    campbell_j_c New Member
    JC
    North Carolina
    2020 Platinum MGM
  13. Jun 2, 2023 at 11:24 AM
    7.62X51
    7.62X51 New Member
    Virginia Beach
    You can buy the parts for about $50.00 and DIY. I did mine that way. Been working perfect for 5 years
    BigdaddyII likes this.
  14. Jun 2, 2023 at 11:38 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    I installed the Toyota one about a year ago and it’s been great. Totally plug and play which is nice
    ejes and Tripleconpanna like this.
  15. Jun 2, 2023 at 11:43 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
  16. Jun 8, 2023 at 12:41 PM
    Sal_160
    Thanks very much for your great and informative responses.
  17. Aug 1, 2023 at 7:03 AM
    ardoporto
    ardoporto New Member
    Alvin
    2019OG
    None
    I think I might have the same issue as Sal. I have a 2019 Tundra with a dealer installed pop lock kit? The tailgate no longer automatically locks just makes a "buzzing noise". I'm thinking if I replace the whole part it will eventually do the same thing. I'm hoping it has been upgraded to something better, but wouldn't bet on it. I'm wondering if 3d printing a gear and gear "receiver" is more expensive than what its worth. The plastic has been worn out. I tried mixing some JB Weld and letting it dry just enough to re-thread but it was unsuccessful. Any thoughts?gear box.png gear and box.png
  18. Aug 1, 2023 at 7:33 AM
    lerbud1
    lerbud1 New Member
    Larry
    Waco, TX
    2021 Tundra SR5
    TRD ROB and ardoporto like this.
  19. Aug 1, 2023 at 12:53 PM
    Jds685
    Jds685 2nd Tundra
    CT
    2024 Tundra i-Force Max 1794
    I have the pop & lock system on my 18. Over 100k miles on it, all perfect.
    I didn't use the cheap taps, I wired it more permanently.
    ardoporto likes this.
  20. Aug 1, 2023 at 8:14 PM
    ardoporto
    Alvin
    2019OG
    None
  21. Aug 3, 2023 at 12:33 PM
    sonofdad
    sonofdad New Member
    steamboat springs, co
    2017 Tundra SR5
  22. Sep 1, 2023 at 1:30 PM
    TreeCat
    TreeCat New Member
    2017 White Limited 4x4
    I've been told I am forgetful (I think.) So I won't likely always remember to lock the tailgate manually. Ugh, another upgrade I have to have!
  23. Sep 1, 2023 at 1:37 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    You’ll love it. Easy install.
