'07 Tundra, 144k, no trans service records....what to do?
Discussion in '2nd Gen Tundras (2007-2013)' started by Trademan8284, May 31, 2023.
  1. May 31, 2023 at 3:48 AM
    Trademan8284
    Trademan8284 [OP] New Member
    Greg
    2007 Tundra 2WD SR5 4.7
    Hello all!
    My son just bought a very nice '07 SR5 2WD 4.7 with 144k miles. Previous owner had a fat file of maintenance and repair receipts, including replacing the timing belt 6,000 miles ago. However, I did not see any mention of the transmission being given any love. The truck does have the towing package (w/factory cooler,) but the receiver hitch shows little wear indicating that the last owner's claim that the truck was mainly used to go to the golf course was probably true. (He was the 2nd owner.)
    The truck runs and shifts just fine. The maintenance freak in me wants to do a drain and fill on that trans fluid, but I hear all sorts of opinions on transmissions at this age that have never had a fluid change.
    What would you do if this was your truck?
    Thanks for you opinions.
  2. May 31, 2023 at 4:17 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! A drain and fill would not hurt and might help with longevity.
    Trademan8284[OP] likes this.
  3. May 31, 2023 at 6:13 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Drain and fill or swap all the fluid. Just don't do a power flush at a dealer.
  4. May 31, 2023 at 6:23 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Drain and fill, each of the first 2-3 oil changes. This is all I ever did to my 09 Crewmax and it shifted same as brand new when I traded at 13 years and 113k.
    Trademan8284[OP] and KNABORES like this.
  5. May 31, 2023 at 7:41 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Got mine at a similar mileage and couldn't find documentation of the service.
    I've done drain and fills at 8-10k miles and the fluid is now pretty and red. I use only Toyota WS ATF and use the leveling procedure "hack" in the following video. He does a different fluid exchange process, but the leveling starts just after 8mins
    https://youtu.be/cB8MdGgwg68
  6. May 31, 2023 at 9:23 AM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    https://youtu.be/y7-H5KwzFdI
    Maintenance manager from dealership thats had 2 tundras (both 07s I think) go well past 1 million miles talking about changing fluid every 100k-ish.
  7. May 31, 2023 at 9:35 AM
    CTundraForMe
    CTundraForMe New Member
    There are a number of threads on how to safely change transmission fluid, regardless of age.
    A "power" flush is the dangerous type you want to avoid.
