Billet Tie Downs - Memorial Day SALE
Discussion in 'Deals & Group Buys' started by Charvonia Design, May 25, 2023.
Thread Status:
Not open for further replies.
  1. May 25, 2023 at 6:16 AM
    Charvonia Design
    Charvonia Design [OP] Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    Hey Tundras.com! It's been awhile since we had a sale on Billet Tie Downs, so let's do one for Memorial Day!
    Use code TUNDRAMEMORIALDAYGB to get the discount.
    Free shipping will still apply for orders of 2+ items.
    If we don't hit 25 orders during this GB all orders will have the option to be canceled or purchased at the normal retail price.
    I know this is a bit of a different format, but it's the best way to capture all of the orders on my site and avoid manually entering everyone's info.
    And now....some info on Billet Tie Downs in case you haven't already seen them:
    These are a direct replacement for the steel U-shaped hooks that are bolted in your bed. Available in red, black, blue or silver, the patented slot keeps your ratchet strap hook from falling out while you tie things down. There are also multiple ways to attach bungees, rope or ratchet straps.
    Sold in pairs
    • Application: 2007-2023 Toyota Tundra (uses two pairs, or four Bed Tie Down Anchors)
    • Application: 1995.5-2023 Toyota Tacoma (uses one pair, or two Bed Tie Down Anchors)
      • Early 2nd Gen Tacoma will require holes to be drilled
    • Application: 1999-2023 Ford F-250 (uses two pairs, or four Bed Tie Down Anchors)
    • Machined 6061-T6, anodized, engraved with logo and torque spec
    • Includes corrosion resistant, Grade 8.8 mounting hardware
    • Replaces stock steel tie-down points that are prone to scratching and rusting
    • Multiple methods for attaching ratchet straps, bungee cords, or rope
    • Radius on inside to avoid cutting straps and ropes
    • Center slot retains tie down straps
    • T40 Torx bit required to remove the stock bolts
    • M6 Hex bit required to install the new hardware
    • Designed and Manufactured in the USA
    • Patent Pending
    These have more options for attaching straps while being 1” closer to the factory bed rail. They will also clear tonneau covers and bed racks when the OEM tie-downs won't. These are MUCH STRONGER than the stock plastic cleats that flex and move under load.
    Sold in pairs
    • Fits 2007-2023 Toyota Tundra w/ OEM Bed Rails
    • Replaces stock bulky, plastic or cast aluminum tie-downs
    • Lower profile design with more open area to attach straps
    • Flush design fits with tonneau covers and camper shells
    • Patent Pending
    • Everything you need for your Tundra in one easy kit!
    • Save by ordering the kit!
    • Includes:
      • Two pairs of Bed Tie Downs
      • Two pairs of Rail Tie Downs
      • Free Shipping
  2. May 31, 2023 at 5:37 AM
    Charvonia Design
    Keith
    Huntersville, NC
    Last day for this sale! Thanks for all the orders!
Thread Status:
