Trd pro suspension problems
Discussion in 'Suspension' started by Smitty80, Jun 26, 2021.
  1. Jun 26, 2021 at 8:04 AM
    Smitty80
    Smitty80 [OP] New Member
    2017 Super White TRD Crewmax
    Hello, I have a 2019 TRD Pro with the Fox suspension. I've noticed when slowly driving over bumps, pulling out of my driveway that's on an incline, or driving over rough terrain popping or snapping noises coming from the front suspension. Also a squeaking noise coming from the front suspension when stepping on my running boards while getting in and out of the truck. Is this a serious issue?
  2. Jun 26, 2021 at 8:35 AM
    AircareTundra
    AircareTundra New Member
    JT
    Look through the threads on here. Others have talked about the creaking/groaning noises.......
    Per the discussion on this it seems to be something very minor with bushings or something down on the skid plate. Others have replaced these very small parts and found it to fix that noise you speak of.
    Hope that helps. If you can find that particular thread......the folks on here do a good job of explaining what it is and how to fix it.
    Luckydog and BlueRibbon4x4 like this.
  3. Jun 26, 2021 at 9:02 AM
    15whtrd
    15whtrd Mr. Blonde
    Start small, take off the skid plate and see if the noise goes away. Confirm all the hardware is tight on the suspension. When I installed mine I put a paint mark on every nut and bolt I tightened to spec. Then, with just a glance I can tell if any of it has backed off.
    bulldog93 likes this.
  4. Jun 26, 2021 at 9:43 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
  5. Jun 26, 2021 at 9:58 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Quite a few folks have had similar experiences. It’s apparently an issue sometimes with the aluminum skid plate. I have never had any noise like that from my Pro, so it certainly isn’t all of them
  6. Feb 27, 2023 at 1:29 PM
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    Newbie here just got my 2021 TRD Pro and I have same issue. Taking it to the dealer on Wednesday. With 31k miles I'm thinking it should be covered regardless if skid plate or suspension.
  7. Mar 1, 2023 at 6:49 AM
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    At dealer now, getting standard maintenance however I advised of noise from underneath possibly from skid plate. Truck has 31k and still under warranty but they advised the skid plate is not covered? Also stating the skid plate is suppose to move around an creak for off road tolerance stress? That doesn't make sense to me, anyone else encounter this from their dealers?
  8. Mar 1, 2023 at 1:20 PM
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    Dealer added bushings,on my insistence...solved problem.
  9. Mar 5, 2023 at 6:17 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Skid plate likely not warranty item for impact. Not sure how it’s “supposed to move” when it’s bolted tight with 5 fasteners…. I’d call bullshit.
    Powskier likes this.
  10. Mar 5, 2023 at 7:57 PM
    p1ayn
    p1ayn New Member
    2021 TrdPro Tundra
    Actually stated on toyota sites, I agree with you but hard to argue for now. Maybe a case down the road. I had them install bushings an it did fix the issue.
  11. May 30, 2023 at 8:43 PM
    Powskier
    Powskier New Member
    Nathan
    2021 Tundra TRD Pro
    Auto Air bags, 5th wheel trailer receiver
    Can anyone describe more specifically what “bushings” were replaced to correct the suspension noise issues? (Shocks, torsion bars, springs, skid plate….)
  12. Aug 1, 2023 at 3:44 AM
    yonquixote
    yonquixote New Member
    ‘21 TRD Pro CM Lunar Rock
    Yes…please define which bushings. Having same sound on my 21 pro w/25k miles
  13. Aug 2, 2024 at 4:23 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Late reply to two above but I think he’s saying they added rubber bushings to wear the skid plate bolts up
