Ask the Detailer
Discussion in 'Detailing' started by T-Rex266, Nov 13, 2017.
  1. Apr 26, 2023 at 11:31 AM
    #4951
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    I plan on 2gal or so to throw the mitts into, use once and discard. What ratio of onr did you use when washing and using it as a drying aid?
  2. Apr 26, 2023 at 1:00 PM
    #4952
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I've tried it at 256:1(wash solution right outta the bucket before washing of course) and the 16:1 they recommend. I've noticed it either way.
    sask3m[QUOTED] likes this.
  3. May 24, 2023 at 5:37 AM
    #4953
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Any recommendations for some good detailing brushes? Right now I am just using a Purdy paint brush, and it does work but I'd like to get some real brushes. Appreciate any help.
  4. May 24, 2023 at 9:37 AM
    #4954
    briarpatch
    briarpatch New Member
    I've noticed a lot of detailers using the ones from Work Stuff (link...https://work-stuff.com/products/brushes). I've been using these Amazon cheapies for years with no issues..... https://www.amazon.com/Detailing-Brush-Set-Different-Automotive/dp/B07PKT21PR?crid=1XL1XAPEYOJE4&keywords=detailing+brushes&qid=1684946166&sprefix=detailing+brushes%2Caps%2C113&sr=8-6.
    For nav screens....I went with these:https://www.detailedimage.com/Detai...oft-Detail-Brush-Synthetic-Gray-P2352/Set-S3/
    dondino[QUOTED] likes this.
  5. May 26, 2023 at 11:21 AM
    #4955
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    A three legged cat tried to jump onto my bed cover, didn’t quite make it, and scratched the snot out of my bedside. Is this something I could expect a detailer to fix up? Or do I need full-on paint correction?
    Hard to see here, but there are three marks like this down the bedside near my fuel door.
  6. May 26, 2023 at 11:30 AM
    #4956
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    From a small animal? Should buff right out.
    dondino and Terndrerrr[QUOTED] like this.
  7. May 26, 2023 at 12:08 PM
    #4957
    briarpatch
    Does your fingernail catch in any of the scratches? If not, it should be fairly easy to correct...especially given how soft Toyota clear coat typically is
    Hi06silver likes this.
  8. May 26, 2023 at 12:20 PM
    #4958
    Terndrerrr
    Music City
    6UR-FE
    I can easily feel the scratches. Seems a lot worse than one would expect.
  9. May 26, 2023 at 1:40 PM
    #4959
    briarpatch
    Cats claws do more damage than you might think. If you're not going to attempt it yourself, take it to a detailer and get their opinion.
  10. May 29, 2023 at 9:27 AM
    #4960
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    Want to protect my saddle brown leather seats in my '23 1794 - Are these seats aniline leather? Was going to use Gyeon's leather shield ceramic protection, but it says not to use it on aniline leather. Does anyone know?
  11. May 29, 2023 at 9:54 AM
    #4961
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    Found this link on toyota canada's site, mentiins the Capstone using semi-aniline leather. https://www.toyota.ca/toyota/en/abo...de-elevates-2022-toyota-tundra-to-new-heights
    This link talks about semi-aniline being similar to aniline but covered with a top coat.https://en.m.wikipedia.org/wiki/Aniline_leather
    gj953[QUOTED] likes this.
  12. May 29, 2023 at 1:31 PM
    #4962
    gj953
    gj953 New Member
    East Coast
    Thank you, using your info - I went hunting - and found that the 1794 just has regular leather, and the capstone has the semi-aniline - so I'm good to go it seems on my 1794
  13. May 29, 2023 at 3:07 PM
    #4963
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    What product seems to work best for you guys to clean tires? Recently got Meguiar's D1430.
  14. May 29, 2023 at 4:14 PM
    #4964
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    most modern leathers in automotive use have a top coat. So rubbing some leather feed onto a leather seat is generally a waste.
    You do want to clean dirt & oils off the seat, but you're usually cleaning it off the top coat, The leather is nicely protected below.
    Maybe in a bespoke Rolls, Ferrari, or such - but in mass production vehicles, it's less likely. I'd suggest digging a little deeper into that 'regular' leather to see if it isn't also top coated.
  15. May 29, 2023 at 4:50 PM
    #4965
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I personally use optimum power clean. I cut it at about a 2-1 ratio since I pretty much use it just for in my wheel wells and on my tires to prep them.
    ToyoMafia likes this.
  16. May 29, 2023 at 5:53 PM
    #4966
    briarpatch
    I've not bought a dedicated wheel or tire cleaner for years. I use Bilt Hamber Surfex HD at 10:1. I do have it mixed at 5:1 if the tires are really bad, or are receiving a coating as opposed to a dressing. If wheels are really bad, I will use an iron remover as well. I know there are situation that call for an acid, but I've just not run into that yet.
    Fotnot likes this.
  17. May 29, 2023 at 6:18 PM
    #4967
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Simple green gets it done. I don’t find tires to be difficult. All my wheels have coatings and just take soap water and some MF to wipe down
    Fotnot likes this.
  18. May 30, 2023 at 3:11 PM
    #4968
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Need a wash pole and was looking at the Incredipole but dam it's 69.00. Anything cheaper that you guys like?
  19. May 30, 2023 at 3:18 PM
    #4969
    ToyoMafia
    Magic carpet.
    That’s a great product. Get what ya pay for
    War Machine and dondino[QUOTED] like this.
  20. Jun 5, 2023 at 10:17 AM
    #4970
    briarpatch
    I have one....love it...only down side is how heavy it gets when its wet
  21. Jul 13, 2023 at 8:18 PM
    #4971
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Can i spread out a 3 step paint correction over the course of 2 weekends or does it have to be done all at once?
    If I do spread it out, what precautions or extra washes etc, should I perform in between?
    We did the wash, iron remover yesterday. Tar remover last night. Today we did a clay bar.
    This will be the first time we have ever done one. Truck is coming up on 4y, minor scuffs and brush marks from.camping/fishing. We will be using a Griots G9 polisher and matching 3 step liquids/pastes/wax etc
  22. Jul 13, 2023 at 8:26 PM
    #4972
    Just do one side a weekend to help save time/stress. I would do the full correction, and ceramic it before moving onto the next section. I would wash the vehicle with graphene shampoo once an area has ceramic on it.
    BravoDeltaRomeo likes this.
  23. Jul 14, 2023 at 1:23 AM
    #4973
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I couldn't do my whole truck in one sitting a few weeks ago ( polish, seal, wax) so I basically did one process at a time and spread the whole thing out over a week. I just did a re-wash before each of the steps. Turned out fine IMO.
  24. Jul 14, 2023 at 4:49 AM
    #4974
    War Machine
    War Machine SSEM # 5 3MW
    It’s expensive, but I’ve had mine for years and it’s never broken. All the cheap ones I ever had did.
    ToyoMafia and Runway like this.
  25. Jul 14, 2023 at 7:10 AM
    #4975
    briarpatch
    ^^^^Best advice you are gonna get^^^^^
    Runway likes this.
  26. Jul 14, 2023 at 7:48 AM
    #4976
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Are you driving in between each step or parking inside a garage? Nothing wrong with spreading it out if you wash it or wipe off the dust (If it stays in the garage) before moving on. Wax will be a waste of time, wont last more than a few weeks. Invest in a paint sealant or ceramic instead...its about the same effort to apply as wax but lasts substantially longer
  27. Jul 14, 2023 at 9:40 AM
    #4977
    BravoDeltaRomeo
    Bruce
    MB Canada
    We decided to do all 3 stages today.
    Stage 1 done. Stage 2 after perogie lunch. Stage 3 after that.
    We will do wax this time and look at a sealant for future use.
    Put the kid to work, he likes working on the truck. He's working the polisher and I'm taping and hand buffing off.
    eddiefromcali[QUOTED] likes this.
  28. Jul 14, 2023 at 10:46 AM
    #4978
    briarpatch
    please post pics of the finished product. As an aside....if you're looking for a sealant, look no further than Jescar Ultra Lock Plus. Far and away the easiest product I've worked with.....ridiculously easy to apply and remove....6 months of protection with great gloss and slickness...apply by machine...Griots red finishing pads are perfect for this task.
  29. Jul 14, 2023 at 12:08 PM
    #4979
    BravoDeltaRomeo
    Bruce
    MB Canada
    First 3 stage ever.....
    Only 1 application of wax, got too tired to do a second.
    We are happy with how it turned out and all the swirls and scratches it removed.
    PXL_20230714_184531980.PORTRAIT.jpg PXL_20230714_185720097.jpg PXL_20230714_190350074.PORTRAIT.jpg
  30. Jul 14, 2023 at 12:12 PM
    #4980
    20GR8 Super
    Corey
    PNW Outskirts
    2007 Super White CM Limited
    :101010:
