Icon RXT Leaf pack driving me mad
Discussion in 'Suspension' started by Tundra694, May 29, 2023.
  1. May 29, 2023 at 6:36 AM
    Tundra694
    Tundra694 [OP] New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    I have maybe 2k miles on my RXt leaf pack by Icon. After the first 1k it started squeaking at every movement. Not just bumps, the loading and unloading of any weight transfer in the truck.
    All bolts are torqued and checked 3 times and to spec. I tried silicon spray. I’ve tried white lithium. I’ve done both twice and not lightly. Nothing shuts them up. It’s not the bushings either it’s the spring pack just grexing. Any successful tips ?
  2. May 29, 2023 at 6:44 AM
    Can you post a clip of what it sounds like?
  3. May 29, 2023 at 8:22 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yes go to a deaver leaf pack. It’ll fix that right up
    JCBerb, Sierradevil and Mater like this.
  4. May 29, 2023 at 8:59 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Mine are pretty much shot now at option 3. For sure will be toast once the rear bumper goes on. Not worth re-arching
    reywcms[QUOTED] likes this.
  5. May 29, 2023 at 9:45 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    We have a surefire method that we call the bicycle tire method and those that have used it have enjoyed effectively 100% success in silencing squeaks on these packs. Head on down to Walmart and pick up a bicycle inner-tube. It comes in a roll. Cut it into small strips (a few inches long). Lift the truck and then use a prybar to separate the leafs. Can be done with the truck on the ground, but easier if the load is off. Use a brush to clean up the area, and then USE PLIERS to put a small strip of the bicycle tire rubber where you can see that the leafs are making contact. You'll see the friction pads already in there, but we're essentially spreading that out.
    You also could use this - https://www.amazon.com/dp/B07B8V5BHW
  6. May 29, 2023 at 10:00 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Did you spray the leafs under full droop? I recently used this spray: https://www.amazon.com/dp/B00D3G6IFE?ref=ppx_yo2ov_dt_b_product_details and actually tapped a screwdriver in-between leafs to create gaps to spray in. I stuck the straw in and really saturated them as well as spraying down both sides. Seems to be working well so far.
    Rodtheviking likes this.
  7. May 29, 2023 at 10:33 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    This must be creaky-leaf weekend... I've got my truck up on stands right now with PB Blaster's brand of dry-lube drying. It seems like the two overload springs where there are not friction pads on the bottom of my Dobinsons leaf packs creak. I think. Lol.
  8. May 29, 2023 at 11:53 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    RTX's are squeaky AF, both the pads and bushings.
    This looks likea great idea
    Tundra694[OP] likes this.
  9. May 30, 2023 at 9:22 AM
    memario1214
    Colton
    Missoula, MT
    It works! Promise :fingerscrossed:
    C.I.[QUOTED] and Mater like this.
  10. May 30, 2023 at 9:33 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    C.I. and DZ_ like this.
  11. May 31, 2023 at 3:20 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    ZappBrannigan, Mater and Rodtheviking like this.
  12. May 31, 2023 at 3:21 PM
    memario1214
    Colton
    Missoula, MT
    What happened? It worked?
    Mater and reywcms like this.
  13. May 31, 2023 at 3:43 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Yep, for the time being, at least. Thanks for the tip!
    ZappBrannigan and memario1214 like this.
  14. May 31, 2023 at 6:49 PM
    I'm going to put liners in my Alcans after my camping trip next week. They creak like a damn Dodge.
    DZ_[QUOTED] likes this.
  15. May 31, 2023 at 7:21 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    @Tundra234 next time I buy leaf packs I will do exactly that before installing. No idea why I didn't think of it beforehand.
    Tundra234 likes this.
  16. Jun 20, 2023 at 7:51 AM
    I bought 2 rolls of this. Now to figure out how to install it lol.
  17. Jun 20, 2023 at 8:00 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Let me know how it goes! Whenever I get around to this, I plan to remove the u-bolts, lower the axle, c-clamp upper leaves and remove the center pin to slide in lengths of liner.
    Two rolls? Sounds like enough for both of our trucks. How about you stop by and we'll have a shop day?
  18. Jun 20, 2023 at 8:00 AM
    memario1214
    Colton
    Missoula, MT
    I have a video on my Youtube channel that I just uploaded that should help you. I need to re-upload it though as I have an error in it. Should be able to re-upload/post it here later today.
    Nbab23, Mater, DZ_ and 1 other person like this.
  19. Jun 20, 2023 at 8:05 AM
    I have Alcans so they are 8 leaf packs.
  20. Jun 20, 2023 at 8:49 AM
    So usually the noise just comes from the ends? i was thinking I needed to pull the whole pack apart....that would be a PITA.
  21. Jun 20, 2023 at 9:06 AM
    memario1214
    Colton
    Missoula, MT
    BINGO. You also could take the entire pack out/apart to make things a tad easier, but in my experience the noise comes from the ends (or the bushings) almost all of the time.
    DZ_ and Mater like this.
  22. Jun 20, 2023 at 9:08 AM
    Ha....I think I'll stick to a few inches on each end. I think I fractured a couple of ribs on Friday and still bruised and sore as hell so I'm not trying to fight with taking those heavy ass things out.
  23. Jun 20, 2023 at 9:17 AM
    memario1214
    Colton
    Missoula, MT
    Sounds like you picked the wrong fight
    Mater likes this.
  24. Jun 20, 2023 at 9:22 AM
    Lol. A fight with a shelf at Wally world when I was trying to help a lady reach some dog food. The damn thing fell apart. I didn't think anything of it until I got home and the adrenaline wore off lol.
    RobertD likes this.
  25. Jun 20, 2023 at 3:07 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    That seems to make sense to me as that's where the force is being applied by each leaf.
    @memario1214 what is your youtewb?
  26. Jun 20, 2023 at 3:27 PM
    Its on his signature if you're on a PC. It won't show on a phone for some reason. I just googled it from my phone when I was at work.
  27. Jun 21, 2023 at 12:41 PM
    memario1214
    Colton
    Missoula, MT
  28. Jun 21, 2023 at 12:46 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    memario1214[QUOTED] likes this.
  29. Jun 21, 2023 at 12:56 PM
    memario1214
    Colton
    Missoula, MT
    Works like a charm!
  30. Jun 29, 2023 at 2:55 PM
    Tundra694
    AJ
    I’ve tried pressure washing and air gun combined with white lithium then Teflon then dry moly. Nothing. Shuts. Them. Up. I thought I was upgrading by going to Rxts. This will be the next attempt. Thank you for this response and video. It gives me some hope. My 2021 sounds like an old mattress in a whore house.
    Mater likes this.
