Window Issue
Discussion in '1st Gen Tundras (2000-2006)' started by tdavis5f15, May 28, 2023.
  1. May 28, 2023 at 6:20 PM
    tdavis5f15
    tdavis5f15 [OP] New Member
    2002 Tundra SR5
    Bone Stock
    Good afternoon all.
    I’m hoping for a little help with my windows. For some reason, the drivers side window switch operates backwards. Pushing the button down will raise the window and pulling it up will put it down. The passenger window functions as designed.
    I ordered another switch and tried that with the same result. I can’t seem to find any information about it on here.
    Any ideas? Anyone else experience anything similar?
    thanks in advance.
    02 Access Cab
    w666 likes this.
  2. May 28, 2023 at 6:31 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Sounds like someone replaced the motor and the motor power connector is wired backwards.
    shifty` likes this.
  3. May 28, 2023 at 6:58 PM
    What he said ^^
    Others have found similar situation with aftermarket motors. They're not pinned same as factory, just swapping the two motor function wires fixed others issue.
  4. May 29, 2023 at 2:07 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
