  1. May 28, 2023 at 5:20 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Haven’t seen the old school grille with the army green. Looking killer.
  2. May 28, 2023 at 6:04 AM
    SwitchThrottle
    2021 Barcelona CrewMax
    That's a stout trailer. I picked up 4 yards of compost with mine yesterday so pretty much doing the same this weekend.
    the red[QUOTED] likes this.
  3. May 28, 2023 at 7:57 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
  4. May 28, 2023 at 8:02 AM
    BlueRibbon4x4
    Geno
  5. May 28, 2023 at 8:19 AM
    BlueRibbon4x4
    Geno
    Stealthy Midland radio. Installed in the center console to be able to access controls, got a mic extension and mounted to the front of the center console. That way I can just plug the mic in and everything stays hidden. On pavement it just comes out and stores next to the radio. Antenna hidden is in the bed behind the Rotopax, we’ll see if this location works for good enough reception.
  6. May 28, 2023 at 9:46 AM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    While I still got my from skid plate off. I was thinking about getting the TRD front sway bar. I already have the rear one and I really like how it makes the truck handle. Has anyone ever used those quick disconnects on your sway bars for off roading?
  7. May 28, 2023 at 9:55 AM
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    Would like to know as well if they make quick disconnects for the TRD sway bars. Last I checked I couldn't find anything on it.
  8. May 28, 2023 at 10:40 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Nice! It’s that time of year. The tractor and trailer are my father-in-law’s. He built the trailer on the heavy side.
  9. May 28, 2023 at 10:41 AM
    bfunke
    bfunke Tundra Curmudgeon
    I think the fluids vary by dealer region. Toyota PS fluid in SC is colorless
  10. May 28, 2023 at 10:52 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    MadMaxCanon[QUOTED] likes this.
  11. May 28, 2023 at 11:39 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Genuinely curious - is there any difference between the TRD front sway bar and the black sway bar that comes stock?
    WCTXN likes this.
  12. May 28, 2023 at 11:41 AM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Lookin’ good. How many miles did you get out of the old set?
  13. May 28, 2023 at 11:42 AM
    BlueRibbon4x4
    Geno
    I got them used, but I put about 30,000 on them.
  14. May 28, 2023 at 11:47 AM
    MadMaxCanon
    The trd is substantially heavier. One of the few trd products that I think actually makes a noticeable difference.
  15. May 28, 2023 at 2:56 PM
    RustyShackle323
    Stewart
    NC
    Solid bar in comparison to the black standard hollow bar.
  16. May 28, 2023 at 5:06 PM
    Yep...hollow is 17 lbs and theTRD is solid and 29 lbs.
  17. May 28, 2023 at 5:49 PM
    biebs96
    PA
    Replaced the battery. Nothing special.
  18. May 28, 2023 at 6:47 PM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
  19. May 28, 2023 at 7:02 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Let us know about that reception quality!
  20. May 28, 2023 at 7:15 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Painted skid plate
  21. May 28, 2023 at 7:20 PM
    centex
    centex New Member
    You painted a thing whose sole purpose is to get beat up?
    AggiePhil likes this.
  22. May 28, 2023 at 7:24 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Yes
  23. May 28, 2023 at 7:28 PM
    BlueRibbon4x4
    Geno
    Nothin wrong with that!
  24. May 28, 2023 at 7:30 PM
    biebs96
    PA
    Cleaned the k&n
  25. May 28, 2023 at 7:33 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    The b/a came in ...very niice.20230528_204814.jpg 20230528_204830.jpg 20230528_005611.jpg 20230528_005714.jpg 20230528_005738.jpg 20230528_005600.jpg
  26. May 28, 2023 at 7:34 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Right! :fistbump:
    BlueRibbon4x4[QUOTED] likes this.
  27. May 28, 2023 at 9:00 PM
    Rangergillikin
    Alabama
    I bet some of those universal ones would work. Maybe someone will have the answer.
  28. May 28, 2023 at 9:02 PM
    Rangergillikin
    Alabama
    I’m going to do the same thing before I put mine back on. Did you remove plastic letters? Looks good
    bulldog93 and Y0TA PR0[QUOTED] like this.
  29. May 28, 2023 at 9:11 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Thanks! Yes I did. The back of the letters has some kind of 3m tape, so just be careful when you pull them off not to get them to dirty.
    bulldog93 and NewImprovedRon like this.
  30. May 28, 2023 at 9:50 PM
    Rangergillikin
    Alabama
    Yeah
    I experimented with the letters to see how hard they would be to get of. Probably going to take a little heat. Mine are stuck down pretty good.
