  1. May 26, 2023 at 12:02 PM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Installed the driver side grab handle. I got fed up dealing with trying to find a scrap one on FB marketplace and just placed an order at my local dealership Wednesday. I'm not one to underestimate an install time - it literally took me longer to go pick up the parts than it did to install them!
  2. May 26, 2023 at 12:08 PM
    BigOP
    BigOP New Member
    Oleg
    Ohio
    2014 Tundra Limited MGM
    It’s not just one part number, correct? A pillar panel and grab bar need to be ordered separate?
  3. May 26, 2023 at 12:13 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Correct!
    62220-0C050-B0 is the a pillar trim part (in gray)
    74610-0C082-B0 is the handle (in gray)
    Then you'll also need to run by the hardware store and pick up:
    1x 1/4-20 bolt 1.5" long
    1x 1/4" flat washer
    1x 1/4-20 extruded u-nut washer
  4. May 26, 2023 at 1:09 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    305/70/18.. about 35.3" x 12.2"
    JediMedic86 and Tripleconpanna like this.
  5. May 26, 2023 at 1:19 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    They're ATs surprisingly. 305/70/18. Just over 35" diameter
  6. May 26, 2023 at 1:33 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    When you say “pop a lot” what do you mean? I’ve got a sound that I can’t identify.
  7. May 26, 2023 at 2:39 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Sorry, I was using the 'MTs' as abrv for Mickey Thompsons.... They look perfect on your setup!!!
  8. May 26, 2023 at 3:50 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Oh. Haha. Yeah, thanks. I'm enjoying them so far.
  9. May 27, 2023 at 7:53 AM
    Bowzer
    Bowzer New Member
    I-10 Detour while scootin across LA back to TX. Been stopping at this spot in the Atchafalaya Basin for decades to take a breath of the good things...
  10. May 27, 2023 at 8:09 AM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    East side of the Bridge?
  11. May 27, 2023 at 9:00 AM
    Bowzer
    Bowzer New Member
    Yessir. Whiskey Bay exit north to near main river boat ramp. Old wooden bridge crossover. Worth the extra effort every single time...
  12. May 27, 2023 at 11:02 AM
    the red
    the red the threat is real
    New Brunswick, Canada
    Truck stuff. Yard work. Landscaping.
  13. May 27, 2023 at 11:16 AM
    JediMedic86
    JediMedic86 New Member
    Cole
    2022 black 4Runner SR5
    Previous Tundra owner turned 4Runner owner.
    Installed the new Iron Bison BARDE front bumper and a good cleaning. I will say for the price I am really pleased with this bumper.
  14. May 27, 2023 at 11:22 AM
    I have never even heard of that one before. Post side shots showing where it sits in relation to the grill surround. It doesn't look like it comes out very far.
    the red likes this.
  15. May 27, 2023 at 11:30 AM
    JediMedic86
    Cole
    @Tundra234 Yeah I found it on Extremeterrain.com and liked the clearance for bigger tires and it’s modular. Weighs right at 90 lbs. I installed Cali Raised LED Amber pods. It also has a cutout for a 30” dual row light bar behind the license plate.
  16. May 27, 2023 at 11:33 AM
    Not bad at all. My RC bumper is about 110 lbs.
    JediMedic86[QUOTED] likes this.
  17. May 27, 2023 at 11:34 AM
    JediMedic86
    Cole
    I almost went with that one for my front bumper as well…I have the Rough Country rear and I love it.
  18. May 27, 2023 at 11:53 AM
    I love the front but wasn't too fond of the rear. My rear is the Road Armor Stealth.
  19. May 27, 2023 at 5:32 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    Cleaned it and removed the crushed running boards after rock sliding them on CrabTree Meadows trail in VA70692198078__C180C0EC-412E-4229-8C25-A8BC3ECFCE55.HEIC.jpg 70690355867__0B63D9F7-1A85-4471-9C6F-D29676E17876.HEIC.jpg
  20. May 27, 2023 at 5:51 PM
    JustAnEngineer
    JustAnEngineer New Member
    West Tennessee
    2017 Black CM Tundra 4x4
    Installed my RC front coil overs. They replaced my factory strut/Toytec 3” spacer lift. On the highest clip setting (these are the adjustable M1) I got the same amount of lift even though they say 0”-2” of lift. IMG_2137.jpg
  21. May 27, 2023 at 6:45 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Installed the old style Pro grille. I went ahead and JB Welded the sensor to the inside of the bottom of the grille surround, following the @2020Platinum method via @Cthulhu. No issues so far.
  22. May 27, 2023 at 6:54 PM
    I originally had the AJT kit with mine. Starting having errors after about 30 miles or so. The surround method works for moat people. I think I have only seen one or two that it didn't work for them.
  23. May 27, 2023 at 7:03 PM
    Terndrerrr
    Music City
    6UR-FE
    I tried the AJT as well. Some people seem to fix the error messages by making a thinner sensor cover, but I even cut a new cover out of 1/32” (ish) piece of flat black plastic using the AJT cover as a stencil. Still got errors. Seems that every truck is a bit different. No wonder they tell everyone you’re absolutely on your own with it.
    I was going to try using some washers to push the sensor forward more, but I just decided to use the rest of the JB Weld I had on hand.
  24. May 27, 2023 at 7:21 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
  25. May 27, 2023 at 7:26 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    94C4D399-3DDD-4B4C-A0C6-A7F34F298A63.jpg F4F5DC24-21F4-4069-9DC6-91DC58B3DB10.jpg
    Purchased a new to me Thule surf rack setup and also a board. Sold all my boards and rack setup four years ago shortly after my son was born. Finally time to get back on the water. 8’6” 22.5” 2-7/8”. Might need to go on a couple runs so this thing can float me better
  26. May 27, 2023 at 9:11 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Let my wife drive the Tundra today while my cousin and I changed the timing belt and a drain and fill on the transmission on my wife’s 2016 accord v6. That car will be ready to go another 100k miles now with just regular oil changes.
  27. May 27, 2023 at 9:29 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Washed and cleaned it! Now to go get it dirty again.
  28. May 27, 2023 at 10:47 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Fresh oil and filter, sucked out some power steering fluid and put in red Toyota power steering fluid and finally tightened up my parking brake cable. Doesn't budge on inclines anymore.
  29. May 28, 2023 at 1:18 AM
    the red
    Give it a couple weeks.
  30. May 28, 2023 at 3:57 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Get the fluid from your local dealer? Got a picture of it by chance?
