  1. Aug 13, 2017 at 9:31 AM
    #8491
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    If I put a Toytec Boss lift on my truck and keep the factory wheels and tires for now, will it...
    A. ..look ok or bad lifted and w/ 285/5520 tires?
    B. ..be ok with stock UCA since it's factory TSS wheels offset and won't stick out too far?
    C. ..still need an alignment since I'm keep wheels and tires the same?
  2. Aug 13, 2017 at 9:40 AM
    #8492
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    A- Those tires will look tiny.
    B- You can keep stock UCA's but it is definitely recommended to replace them to get proper alignment.
    C- Yes you still need an alignment. Alignments have nothing to do with which wheel and tires you have.
    SouthBoundSteve and T-Rex266[OP] like this.
  3. Aug 13, 2017 at 9:52 AM
    #8493
    Darth Tundra
    Curt
    17 CM TRD Black
    Im with Joon !!..LEAVE IT WHITE...LESS IS MORE...SOMETIMES...IMO
  4. Aug 13, 2017 at 10:34 AM
    #8494
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Added an O.C.D.
    Watt maker likes this.
  5. Aug 13, 2017 at 10:45 AM
    #8495
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Don't worry about A. It's just a step in the transformation. I'm probably going to rock new wheels on the stock rubber, then lift, then get some meaty tires. Gotta do what ya gotta do.
  6. Aug 13, 2017 at 11:02 AM
    #8496
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Yeah obviously I wish I can do it all at once but just can't. And I figure it's a must to at least do the lift first because I can't add larger tires first without the lift.
    I just notice more and more how low my front end looks and wish it was a little taller.
  7. Aug 13, 2017 at 11:45 AM
    #8497
    Brutus T
    Brutus T New Member
    Ian
    2016 Silver Sky Tundra SR5
    Installed Silver Sky mirror caps and door handles today. Almost done with the de-chroming process.
  8. Aug 13, 2017 at 1:50 PM
    #8498
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    Drove it to check on the new house build, and booked it home when I saw dark clouds forming :laugh:
    @WarEagleSteve
  9. Aug 13, 2017 at 2:27 PM
    #8499
    PermaFrostTRD
    Northern NY
    Y'all moving?
  10. Aug 13, 2017 at 2:29 PM
    #8500
    Further up N/. Building this go around.
    PermaFrostTRD[QUOTED] likes this.
  11. Aug 13, 2017 at 3:27 PM
    #8501
    mdavis
    Michael
    Rock Hill, SC
    Are you going to do a build thread?
  12. Aug 13, 2017 at 3:29 PM
    #8502
    If I'm not too lazy...not a bad idea :thumbsup:
    mdavis[QUOTED] likes this.
  13. Aug 13, 2017 at 3:30 PM
    #8503
    mdavis
    Michael
    Rock Hill, SC
    As someone who just went through it, I would love to see someone else's experience.
    T-Rex266[QUOTED][OP] likes this.
  14. Aug 13, 2017 at 3:42 PM
    #8504
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    20170805_203918.jpg Sorry boys for letting ya down this weekend didn't have time to do the install of everything. Despite the great packaging, FedEx still managed to do a number on it. I didn't notice it until I really took everything out and looked close at things. I spent yesterday with a rubber mallet straightening some metal and some krylon rust proof textured black rattle can to match the powder coat. Planning now to install all one shot for this Saturday coming up after work. For the letdown on my end I'll let u all see 1 product out of the bunch. Trust me there's alot more than this. There's a whole other box besides this one that I couldn't let u see without giving it all up. What 1 product you see here in white and red as part of a whole bunch of other goodies in this box is a 30" BD s8 lightbar in clear that I'll run the amber backlight feature when not really turned on tied into my DRLs. It's not installed yet, just felt bad for letting some down who were expecting to see it all like I was shooting for today. I also need to decide if I want to use the separate switch I already have tied into cab for the true on/off or just simply tie into highbeams. Any suggestions? Think it will be easier to tie into highbeams, not sure if I'd like the ability to turn on and off separately from highs plus then need to take extra step to turn off via switch to not blind others rather than just turn off highs from stalk? Where I live and getting called into work during some crazy weather and times when no one else on road I'm thinking I will be using it on the road for the extra visibility. I'm leaning toward just tying into highs that way I can use more often and easier without needing to hit the separate switch every time. Any thoughts, opinions, or suggestions on the wiring? Sorry n tnx in advance.
  15. Aug 13, 2017 at 4:06 PM
    #8505
    done
    Watt maker and mdavis[QUOTED] like this.
  16. Aug 13, 2017 at 4:31 PM
    #8506
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    Did this today.
    20768100_1623832054295584_48634009874967_96309c7529358d179c6aa52d293dce0f88bfd03d.jpg
    Started with this.
    20728201_1623831320962324_61870863495892_33b2b88f5e4cb22b1960c8b40a8f7df1d7272d96.jpg
    Other than the quick release mount https://www.amazon.com/gp/product/B00NN80YFC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 and the plastic knobs https://www.amazon.com/gp/product/B00A9N54FE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 that fit the T-slot nuts for the rail system, everything else was bought at a local hardware store.
    Cut to length and sprayed with PlastiDip.
    20881889_1623832050962251_16407877400515_fecfaca600906451c874a30a9b71113e72a80513.jpg
    Mounted to the rail.
    20728381_1623851174293672_73684427401018_2347c39e1a1358965c45b0f3a30b29418d93a27c.jpg
    Only sticks out about 5 inches.
    20767947_1623832067628916_67284885169694_69e0de77f4a137403b970fe9f50ee6998b4d65ab.jpg
    Totaled out to around $120 with the extinguisher.
    If I don't like how it sits later, I have plenty of the hole bunch metal that I can make new mounts for and have the extinguisher tucked out of the way closer to the bed side.
    TXMiamiFan, Medic, Spvrtan and 5 others like this.
  17. Aug 13, 2017 at 8:52 PM
    #8507
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    IMG_0216.jpg IMG_0218.jpg When your truck is so clean it tells you where to go lol
  18. Aug 14, 2017 at 4:30 AM
    #8508
    Stig
    Stig New Member
    Deleted post
  19. Aug 14, 2017 at 6:51 AM
    #8509
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Dropped it off for Lift, wheels, & tires.
  20. Aug 14, 2017 at 7:04 AM
    #8510
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    Had to remove my front wheel spacers due a popping noise when turning and approaching the end of the turn
  21. Aug 14, 2017 at 7:38 AM
    #8511
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
  22. Aug 14, 2017 at 8:14 AM
    #8512
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    Did you update lighting as well? What did you go with?
  23. Aug 14, 2017 at 8:21 AM
    #8513
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Had a retrofit done a few months ago.
  24. Aug 14, 2017 at 5:20 PM
    #8514
    Flyinryank
    Flyinryank New Member
    Las Vegas, NV
    White 2015 CM 4x4
    Painted and mounted :thumbsup:
  25. Aug 14, 2017 at 5:53 PM
    #8515
    Eclipsed & Floating
    Eclipsed & Floating Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Installed my shovel, ax, and maxxtraxx by bolting it all to my @RCIoffroad bedrack.
    It ain't like being at home where I'm headed. Big city, bright lights brings on them boys that like to take stuff that's not theirs. I'm hoping everything being bolted on will deter them. If I end up camping with @dcsleeper408 and @joonbug then I'll definitely need security. I might need to take @4x4_Angel for "security forces" back up20170814_182139.jpg 20170814_182028.jpg 20170814_181955.jpg
  26. Aug 14, 2017 at 5:59 PM
    #8516
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    You guys and the retrofits. Damnit. Seriously considering this. I probably should have looked into it more prior to buying the Recons.
  27. Aug 14, 2017 at 6:00 PM
    #8517
    Baja Mike
    South Bay, Ca.
    If it isn't bolted down, keep it inside the truck.
    Spvrtan, 757TUNDRA and Watt maker like this.
  28. Aug 14, 2017 at 6:01 PM
    #8518
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I'll go! does it pay?
  29. Aug 14, 2017 at 6:02 PM
    #8519
    Eclipsed & Floating
    Voluptuous Whitey
    Yep
  30. Aug 14, 2017 at 6:04 PM
    #8520
    4x4_Angel
    Bree
    Funky Town, Texas
    hmmmmmm......i could use the money....
