2020 Head Unit Question
Discussion in 'Audio & Video' started by EddieBolt, May 26, 2023.
  1. May 26, 2023 at 10:54 PM
    EddieBolt
    EddieBolt [OP] New Member
    2020 CM SR5 4x4
    Just got a 2020 Tundra and it has Apple CarPlay but it's lacking bass and the speakers are meh. I like the head unit, is there a way to keep the stock head unit and get better sound? What would be needed? Thanks!
  2. May 27, 2023 at 4:23 AM
    Search the audio section. There are threads on this question already.
  3. May 27, 2023 at 12:43 PM
    jimg
    jimg New Member
    2016 Tundra Limited 4x4
    Depends on how far down the rabbit hole you want to go.
    what is your budget?
  4. May 27, 2023 at 5:16 PM
    EddieBolt
    2020 CM SR5 4x4
  5. May 28, 2023 at 6:19 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    Jbl or non jbl
  6. May 28, 2023 at 11:14 PM
    EddieBolt
    2020 CM SR5 4x4
    Non JBL
  7. May 29, 2023 at 11:34 PM
    jimg
    jimg New Member
    You might be surprised how much the sound will change just by changing the head unit.
    If you must keep the factory head unit I would look at the NTUNE6 from taco tune
    Or some other type of line out converter.
    Add a five channel amp and replace the factory amp under the passenger seat.
    Replace the door speakers
    Add a basic sub setup
    This can be done for around $1,000
    Will sound way better than what is in it now.
  8. May 30, 2023 at 7:33 AM
    EddieBolt
    2020 CM SR5 4x4
    Thank you! I will look into this.
