Rear end squeak/chirp
Discussion in '2.5 Gen Tundras (2014-2021)' started by Joe333x, May 23, 2023.
  1. May 23, 2023 at 10:42 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    2019 Tundra CrewMax Platinum
  2. May 23, 2023 at 10:48 AM
    I hate squeaks and rattles. It's hard to tell what it is but check to make sure the rotors aren't making contact with the dust shields.
    Joe333x[QUOTED][OP] likes this.
  3. May 23, 2023 at 10:58 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Are you sure it is in the rear? Sounded far away??
    Mine was a broken nut on top of my front right shock. That allowed the bolt to flex and rub, which was my squeek.
  4. May 23, 2023 at 11:21 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    I'm definitely going to look at that because I actually recently took the rotors and calipers off just to clean everything up and lube the slide pins and make sure that the bolts will be easy to take off when it does come time to change the pads and rotors in a couple years.
    Yes in that video the rear tires go over a speed bump when the squeak happens.
    1UP[QUOTED] likes this.
  5. May 23, 2023 at 11:30 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    LOL you would not like riding in mine
    TRDFerguson likes this.
  6. May 23, 2023 at 11:41 AM
    AZBoatHauler
    So.Arizona
    Spare tire moving underneath? Almost sounds like swinging…
    Demented Canine likes this.
  7. May 23, 2023 at 11:49 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    My truck sounded exactly like this..took me weeks to figure it out. Finally took my tailgate off one day and the sound went away. I sprayed white lithium grease on the lower tailgate hinges, and the top latches.
  8. May 23, 2023 at 11:50 AM
    Daganh62
    Daganh62 New Member
    2017 TRD Off Road
    I second tundra234. If it's not that my next guess would be a wheel bearing.
  9. May 23, 2023 at 11:54 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Any mod???
  10. May 23, 2023 at 12:17 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    I actually took the spare tire off and put it in the bed on my drive to work today to see if that was it.
    I will give that a try as well. My last squeak I had was the latches on the window on my cap, I was so happy when I got rid of it and thought this squeak was the same one but unfortunately after greasing them again it didnt go away.
    Bone stock besides having a cap on the bed and an ATF cooler.
  11. May 23, 2023 at 1:00 PM
    Lol but you also launch yours with wheels off the ground :D :mudding:
    reywcms[QUOTED] likes this.
  12. May 26, 2023 at 9:02 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    Checked every thing everyone suggested, just got finished cleaning and lubing the brakes. Still cant figure this one out. Going to have to wait til i can have someone drive it while I stand outside and listen. The squeak only happens whole the rear end is bouncing.
    https://youtube.com/shorts/2Lmsry8FA5E?feature=share8
  13. May 26, 2023 at 9:05 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Have you lubed the rear leaf shackles with triflow and the front area where they pivot? I also spray the leafs themselves
    Tundrastruck91 likes this.
  14. May 26, 2023 at 9:15 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I second shackles, cause after my shackle lift it sound the same
  15. May 26, 2023 at 10:07 AM
    Joe333x
    Joe333x [OP] Member
    Boston
    Just did this now Will report back, But I got someone to drive the truck over the boards while I listened to the rear end and it's definitely the driver side rear and it did sound like it was coming from the bumper area so let's hope it was the shackle.
    1UP and reywcms[QUOTED] like this.
  16. May 26, 2023 at 7:58 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Lubed the shackles and its still not gone but only hit it with some WD40, will try something better tomorrow
  17. May 26, 2023 at 8:05 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Just a longshot, but give the shield that protects the seal on the rear diff a squirt, some people here were getting an annoying squeak in that area. Good luck with your quest.
    Joe333x[OP] likes this.
  18. May 26, 2023 at 8:07 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Dry lube the leaf springs, raise the frame to open then to full droop and blow them out or just spray into all the ends. A flat tip will spread them if needed. Spray the alignment holders as well
  19. May 26, 2023 at 8:13 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    Sorry I can't picture what you're referring to on the rear diff
    Definitely will do that, I actually had it lifted on the frame trying to maneuver the wheels by hand to get it to squeak but I couldn't. I used two stands to the left and right on the trailer hitch tube, is that a satisfactory stand point? It worked just fine but had never done that before and couldn't see anywhere else I could put a stand that would allow the suspension to fall.
  20. May 26, 2023 at 8:23 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    usually I put jack stand on the frame, right in front of rear wheel, and use a long prybar pry on the part you want to test for any unusual movement and noise.
  21. May 26, 2023 at 8:58 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Check your U joints for slop.
  22. May 27, 2023 at 3:45 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    All right so whatever it is is not related to the rare suspension. I jacked up the frame took the wheels off and took a pressure washer to all the leafs and shackles then lubed everything. Checked to see if the u-joints were loose all bolts were tight got one to tighten just a slight maybe an eighth of a turn.
  23. May 27, 2023 at 3:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Tell a guy rock it on the hitch while you go under. If it only happen at a bump it’s most likely bushings, sway bar, shocks
  24. May 27, 2023 at 3:55 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    UPDATE: I feel like an idiot but finally figured it out! It was the hook on this bungee cord around the d-ring in the bed. This thing's been here for years and never ever squeaked.
  25. May 27, 2023 at 3:58 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  26. May 27, 2023 at 3:58 PM
    Joe333x
    Joe333x [OP] Member
    Boston
    I just happen to be taking the dogs for a walk and let them out of the bed and decided to push sideways on the tailgate so the The truck rock side to side because going up and down wouldn't cause it. Can't believe the amount of work and time I spent on something completely unrelated to the truck itself lol
    Henry1jg likes this.
  27. May 27, 2023 at 4:45 PM
    1UP
    1UP Truck Gang
    Yeah, but the squeek is gone. You no longer need a new truck :thumbsup:
  28. May 28, 2023 at 6:16 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Lmao wow
