Longevity Modifications
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tsm503, May 26, 2023.
  1. May 26, 2023 at 11:53 AM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Hey everyone, looking for some input on what kind of modifications should be installed to preserve the longevity of our trucks. Thanks
  2. May 26, 2023 at 11:56 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Longevity and mods don't usually go hand in hand.... I'm pretty much stock 2nd gen at 275k. I'm sure there are other moded Tundras with similar miles with no issues.
  3. May 26, 2023 at 11:58 AM
    Tsm503
    2021 DC SR5
    I would have to agree but an example would be the transmission cooler for the 19-21 models which I have installed. Looking for more opinions, thanks for the reply
  4. May 26, 2023 at 12:34 PM
    Mr Badwrench
    Mr Badwrench New Member
    Get standard load range, low rolling resistance tires like the Michelin Defender and drive conservatively. That's about all you can do for longevity. Probably not worth much, it is just my opinion on this.
    Tripleconpanna and Tsm503[OP] like this.
  5. May 26, 2023 at 12:37 PM
    yakeng
    yakeng 3URFE Apologist
    Transmission cooler, cat plates and potentially an ECGS bushing swap for the needle bearing if you have a 4x4. I wouldn't swap it unless you start getting a lot of play in the front drivers side CV axle and vibration.
    I think the main thing for longevity is routine maintenance. These 2.5gen trucks are probably the most reliable generation of light duty trucks on the road today. Often mods accelerate wear.
    rock01, Wallygator and Tsm503[OP] like this.
  6. May 26, 2023 at 12:47 PM
    evanhauer
    evanhauer Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    I think the rear diff breather relocation mod falls into this category.
  7. May 26, 2023 at 1:06 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Nothing, just change the oil/ATF and do normal maintenance. I'm over 290k with a supercharged tundra and have done nothing out of the ordinary. If anything it's the least maintenance intensive vehicle I own, change the oil and filter and occasionally the transmission fluid and it's happy.
  8. May 26, 2023 at 3:14 PM
    kevine0001
    kevine0001 New Member
    Kevin
    Normal and timely maintenance of all fluids. Conservative driving. I've put in a Bilstein lift (6112/5160) and run 285's. That's the only "mod" I've done, but I've been religious about my maintenance (oil, coolant, diffs, t-case, brakes and battery, etc.) Just don't abuse your truck and should be okay
  9. May 26, 2023 at 4:59 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    Ok, here ya go:
    - I'd argue a ceramic coat and some sort of regular wash routine to keep that coating and your paint healthy.
    - A cover if your parking outside.
    - A protective bed coating. Rhino or otherwise.
    - Scotch guard your seats
    - rubber laser fit floor mats
    - if your outside the mouse/squirl mod for your cabin air.
    - cam tower seal leak thing thats is about sticky'd top of the 2.5 Forum page.
    I'm sure I'm missing some.
    panicman and Tsm503[OP] like this.
  10. May 27, 2023 at 12:08 AM
    Blue Thunder
    Washington
    Don’t do anything and just keep up on maintenance. I wound not even add the transmission cooler.
    Sierradevil and RustyShackle323 like this.
  11. May 27, 2023 at 12:33 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm at 265k on my '08...
    It's towed, it's travelled, it's camped, it's partied, it's been to Canada :canada:
    it's transported dogs (a lot of them), and most importantly it's kept the family safe and never left us stranded :thumbsup:
    It's already been said a few times, but just keep on the maintenance. Also, I know some folks are into the gucci type of additives, synthetics, etc.. For me, I've stuck to the basics and used recommended fluids and such at reasonable intervals, and it's served the truck and I quite well.
  12. May 27, 2023 at 2:53 AM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Not sure about that one, covers can be more of a curse than a blessing. The three obvious drawbacks are scratching from dirt, condensation issues and small animals that fancy camping out.
    1UP[QUOTED] and Spyker like this.
  13. May 27, 2023 at 5:39 AM
    TheBrit
    Mark
    Seat and floor covers are the biggie for me and a must for those who use their beasts for work, have pets or the ultimate in interior destruction, kids. Dirty little beggars can trash an interior in 20 seconds flat.
    Wallygator and batman900 like this.
  14. May 27, 2023 at 9:55 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Yep, there's nothing inherently wrong with the design of the 2007-2021 tundra. Nothing that needs to be "modified" in order to extend the life of the vehicle.
    Basic maintenance and don't smash it into anything and it'll last a million miles.
  15. May 27, 2023 at 3:23 PM
    1UP
    1UP Truck Gang
    - After a certain mileage (100k?) you could get the engine bay and underside cleaned with dry ice.
    - There is that little area in the fender area that collects leaves and crap. Something to keep that clean and free from wet materials to minimize rust over time.
    - 3M protection film on headlights.
  16. May 27, 2023 at 5:22 PM
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    I recently got a 2020 so the trans cooler will be a must mod for me !
  17. May 27, 2023 at 5:42 PM
    Ginsterkev
    Ginsterkev Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    For me and where I live in the north east I keep the underside fully fluid filmed and also in the frame rails I use a cavity wax and a 36 inch wand and I spray away, it really gets into the tight areas and def helps with corrosion
    Wallygator, Joe333x and Henry1jg like this.
  18. May 27, 2023 at 7:11 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    ATF Cooler, switching to 5w30, doing 5000 miles OCI keeping the undercarriage clean and sprayed with an anti corrosive.
    Larly5000, TundraTed, TWJLee and 2 others like this.
  19. May 31, 2023 at 4:04 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    If it's a Ford, GM, or Ram, most important mod for longevity would be to trade it in for a Toyota. :rolleyes:
    If it's already a Toyota, yer' good! :bananadance::dancingbacon::broccoli:
    rock01, Piney, evanhauer and 5 others like this.
  20. Jun 1, 2023 at 5:50 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    303 UV protectant on all rubber and plastics, fluid film undercarriage, diff breathers if you off-road, trans cooler, Husky/Weathertech mats. Avoid lifts, big tires etc. All increase wear.
    Tsm503[OP] likes this.
  21. Jun 1, 2023 at 6:04 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    move that $200 pile of sh1t out of your garage & park your $60k truck in it.
    I got neighbors with 3 car garages with piles of crap in them...and $100k worth of cars parked on the driveway.
  22. Jun 1, 2023 at 7:26 AM
    1UP
    1UP Truck Gang
    Amen. Paid for apoxy floors, installed some cabinets along the garage wall, bought a 10x10 shed and shelving for it.
    Shed and garage are fully organized and Jeep is parked inside. Expensive but definitely my best "mod" ever.
    rock01 and nobodyintexas[QUOTED] like this.
