Rear passenger Axle will not go into the differential, Help!
Discussion in '1st Gen Tundras (2000-2006)' started by TeagueExpeditionary, May 25, 2023.
  1. May 25, 2023 at 10:31 PM
    TeagueExpeditionary
    TeagueExpeditionary [OP] New Member
    2001 Tundra Limited TRD 4wd
    full camper drawer system, 33" Skinnies, steelies, 2.5" OME front, 1.5" ICON aal rear, Midland GMRS, hard mounted scanguage, pioneer headunit,
    Title says most of it: I have a 2001 Tundra Limited TRD 4x4.
    My rear axle seals blew out (clogged breather) so I’m replacing them and brakes etc.
    Got the axles out easy and took them to a local Toyota shop to have new axle bearings pressed on. Put the new seals in. Got the axles back from the shop and got the drivers side in without a problem... but the passenger side refuses to go into the diff.
    It will go just enough to catch and spin the opposite side but it absolutely will not go in the last inch and a half or so. I’ve tried wiggling it and spinning it and with the other side installed and not installed and nothing has worked. There is no remove-able rear diff cover so we’d have to pull the whole thing to get a better look and want to avoid that if possible. Any advice???
    upon further inspection there is damage to the end of the axle.. however the drivers side axle won't go in all the way either and the splines still look good, I carefully filed them just barely to remove a tiny bit of mushrooming (could only feel it with finger nail, barely see it) but that didn't help.
    I’m very new to working on vehicles, my buddy who’s helping me do it all is more experienced than me and did this job on his 2wd 99 4Runner (no lsd) with no real hiccups so this is messing with our heads. I need it out of his driveway as soon as possible!
  2. May 25, 2023 at 11:07 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    After the splines get far enough to just engage, does it feel like you are then hitting a hard stop or does it feel like it just gets too tight?
    can you get a decent view looking all the way through the tube with both axles out? You may be able to use a camera to get a shot and zoom in to see if anything it out of sorts.
    seems like a long shot that there is a spline problem. But an inch and a half also sounds like more than a loose outer seal would cause.
    got any pictures of the tube end?
    once the splines are started it should just pretty much go as you already know. Both axles work on one side and not the other? Then rule out the axle shafts.
  3. May 25, 2023 at 11:25 PM
    TeagueExpeditionary
    I will check again in the morning but I think I remember it felt like hitting a hard stop, I can get a decent view so I'll also check with a better quality camera and light to see what I can see. I will update with pictures tomorrow as well as measuring the amount it has left to go in. The ABS ring was 2/3 inside the axle housing I think that's as deep as it'd go? I will also check and see if both axles work properly on drivers side but I know the drivers side doesn't work on the passenger side while it does work on its proper side, is there any differences in the splines?
  4. May 25, 2023 at 11:31 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Sometimes you have to grab the top and bottom of the axle assembly and tip the spline end 'up' to align it with the carrier hole. Then wiggle it in.
    If you need more to grip and the drum is off, slide it on backwards and run a couple nuts on.
  5. May 25, 2023 at 11:40 PM
    TeagueExpeditionary
    sweet ok I'll try that tilt wiggling method
  6. May 26, 2023 at 4:25 AM
    You have to lube it up before you put it in. I know, I know. Sounds like I'm being perverted but only kinda. Mine wouldn't go in so I took it out and coated it in diff juice and it popped right in. Also, if you take a peek down the axle tube, you can see right where it needs to go.
  7. May 26, 2023 at 5:18 AM
    Boone01Tundra
    Boone01Tundra New Member
    Benjamin
    Boone, NC
    2001 AC Tundra V8. OEM 2 tone. Leather 49k miles
    I haven't messed with the rear axle of my AC but I do have a story about rear axles that may help.
    You mentioned the breather tube being clogged.
    On my ZJ Grand Cherokee's, the breather tube nut/bolt passes through the brake distribution block and holds it to the axle. I was rebuilding the whole axle and had all the brake lines off but I screwed in the breather tube into the hole most of the way. When I was reassembling the axle, the driver side axle shaft would not go in! I couldn't figure it out. I tried and tried. I just happen to look down the axle tube and what do you know...that breather tube bolt was way inside of the axle tube. It threaded in way further without that brake distribution block and wouldn't let the axle go in straight....
    So, moral of the story..look down the axle tube into the pumpkin before trying to put the axle shaft back in...might save you a headache.
    TX-TRD1stGEN likes this.
  8. May 26, 2023 at 5:38 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I believe there is a seal right before the splines go into the carrier. You may have knocked it out of place and is now blocking the hole into the carrier.
    Gonna have to take out the 3rd member to look.
  9. May 26, 2023 at 5:46 AM
  10. May 26, 2023 at 5:59 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That oil seal is out at the end of the axle tube, just inboard of the wheel bearing.
  11. May 26, 2023 at 7:33 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    There are 2 seals, inner and outer. The outer is the one he just replaced.
  12. May 26, 2023 at 7:44 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    @landphil is correct.
    Here's some pictures from my truck. Inner axle seal (S seal) that pops into the axle assembly is 90310-50006. On your diagram it's the left seal on part #5.
    Outer axle seal (K seal) that goes onto the axle shaft is 90313-54001. On your diagram it's the right seal on part #5.
  13. May 26, 2023 at 8:28 AM
    2mchfun
    I'd take out the third member and get a good look. You already have so much apart, why not give it a good once over just for the peace of mind if nothing else. Once out, you can do a test fit before going back in. Might actually be faster in the end!
  14. May 26, 2023 at 9:04 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Ok, I've been calling it a seal but it's actually a baffle. My bad :p
    But check out 4:52 on this video, which is what I was talking about.
    EDIT: yeah yeah 2nd/turd gen but same thing though
    https://youtu.be/sq5pZuEm7mI
  15. May 26, 2023 at 9:53 AM
    des2mtn
    Shady Grove
    Tonto cover
    Gotcha. Just wanted to clear up any confusion from your descriptions/ diagrams. Toyota calls the baffle a DEFLECTOR, REAR AXLE HOUSING OIL. p/n 42108-34010 for my truck.
    Still worth a check, but I'd take a good look down the tube and try the lube and wiggle before pulling the diff.
  16. May 26, 2023 at 9:55 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    Yeah, definitely pulling the 3rd member is last resort cuz that fucker is heavy!
  17. May 26, 2023 at 11:35 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The axle shafts are the same length on both sides on these trucks, right? It’s been a while, I can’t remember for sure. If not, maybe the shop pressed the left shaft into the right bearing / housing / backing plate…
  18. May 26, 2023 at 11:41 AM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Same length.
  19. May 26, 2023 at 1:17 PM
    TeagueExpeditionary
    Ok we're back at it now, the truck is in park and the brakes are off so I cannot shift it, will that be preventing it from going back in? is there a way to shift into neutral without using brakes?
  20. May 26, 2023 at 1:25 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    No.
    You can just twist the axle to line up the splines or rotate the backing plate to line up the studs with the axle flange.
  21. May 26, 2023 at 1:32 PM
    TeagueExpeditionary
    wiggling and spinning the axle to align the spines has been fruitless and looking down the housing I cannot see any obstructions
  22. May 26, 2023 at 1:38 PM
    TeagueExpeditionary
  23. May 26, 2023 at 1:40 PM
    TeagueExpeditionary
    Should I disconnect the driveshaft so I can spin/wiggle the input shaft while trying to insert the axle?
    rockmup likes this.
  24. May 26, 2023 at 1:45 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Maybe the opening is not level, for example it might be pointing slightly down, which prevents the shaft from going in straight. Thinking loosening up the 3rd member to give you extra wiggle room may help :confused:
  25. May 26, 2023 at 1:49 PM
    TeagueExpeditionary
    Hmmm that sounds like it could help
  26. May 26, 2023 at 1:52 PM
    TeagueExpeditionary
    I'm really appreciating the help this community has been providing, makes it a lot easier to feel like I can get this done as a noob
  27. May 26, 2023 at 2:03 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I don't see anything in the pics that would prevent install. But maybe there's a bit of spline that needs to be filed?
    Does it feel like the splines make it past the baffle and you can feel them against the inner splines when twisting the axle trying to engage them? Like there skipping across each other.
    If yes you can try and smack it in with a dead blow.
    2mchfun likes this.
  28. May 26, 2023 at 2:09 PM
    TeagueExpeditionary
    I can feel it hit the splines and it does spin the opposite side when pushed in all the way but my buddy checked it with a paint pen and only the very very end of the splines is touching
  29. May 26, 2023 at 3:23 PM
    2mchfun
    Hit the leading edges of the splines with a triangular file, clean any filings completely, lube it and try again, I think gravity is pulling it down and your going to have to fight that as it goes in. You might fabricate a sort of handle or lever that will attach to the lugs to give you added leverage to help raise it up with an equal and opposite force. Good luck!
  30. May 26, 2023 at 3:25 PM
    TeagueExpeditionary
    I love the handle idea I'll see what I can do
    2mchfun[QUOTED] likes this.
