  1. May 25, 2023 at 3:15 AM
    Henry1jg
    Henry1jg 2021 TRD Sport
    MI
    I am a huge fan of what you're doing. When my dad passed, he left me his F150. First time I got under it for an oil change I was shocked by how much rust rot it had. 18 months later, the frame gave. I capped a 6' section on each side and drove another 4 years before it gave 16" past the cap. Nothing I could do to save her then. So, I vowed to find out how to not let this MI road salt not destroy my vehicle and landed where you are now
    When you're using fluid film/surface shield, make sure to get inside every piece of frame that you can. I also hit the bottom of doors, tailgate, can corners, etc. I won't let rust rob me of a 160k mile truck again! Good luck!
  2. May 25, 2023 at 6:23 AM
    Cthulhu
    OBD Fusion with the Toyota expansion pack.
    bulldog93 and the red[QUOTED] like this.
  3. May 25, 2023 at 6:46 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
  4. May 25, 2023 at 9:05 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Put in the new replacement Ironman Foam Cell Pros with new brake rotors and pads. And finally got the alternator diode installed for the AGM battery, reads 14.1v at idle now.
    BlueRibbon4x4, the red, Piki and 3 others like this.
  5. May 25, 2023 at 3:39 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    The frame seems to be a “C” shape for most of its length so fingers crossed I can hit most of it
  6. May 25, 2023 at 4:07 PM
    I was just looking at those on Discounts site. What size and how do you like them?
  7. May 25, 2023 at 6:35 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Installed a dual battery isolator, ran a positive wire above the frame to the bed, put an old 80 Ah battery to test. Will see if it can run my shiny new ARB Element fridge through the night.
    This fridge is huge! A lot of cold beer in the woods, a lot! :) I wish it was a dual zone fridge/freezer, so I could have a frozen meat and vegetables/beverages at the same time, but this one was the only IP67 fridge ARB makes. I think I can build an insulated box for veggies and run ARB as a freezer.
    Also will need a deep cycle marine battery.
    Wallygator, WVI, Tundra-XP and 5 others like this.
  8. May 25, 2023 at 6:37 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Buy a can or two of Noxudol 700, it comes with an inner channel attachment that will let you spray the boxed part of the frame from within. 700 will creep everywhere, in every rust spot, and it will drive the water away from metal.
    bulldog93 and Cl8NL[QUOTED] like this.
  9. May 25, 2023 at 7:10 PM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    Thanks for the tip, seems like good stuff - I researched it a bit and it looks like Toyota themselves issues a repair protocol using it https://static.nhtsa.gov/odi/rcl/2009/RCRIT-09V444-6633.pdf
    Also- do you think I should spray POR15 inside before it?
    bulldog93 likes this.
  10. May 26, 2023 at 5:02 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Big NO! 700 and that's it. 700 is very agile and can travel a few inches in any direction, even upwards.
    I used Noxudol 1600UM on the outer part of the frame, it holds up pretty well after 3 New England winters and a few dozens of offroad trips. Applied with www.amazon.com/gp/product/B001TZEIBM, it lays nice thick droplets. Used U-Pol Raptor gun on wife's Sequoia, likes it less (deposits a thinner layer).
  11. May 26, 2023 at 6:22 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    @vtl how much air do you need to run that sprayer?
    Cl8NL likes this.
  12. May 26, 2023 at 6:33 AM
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Literally had not heard of this now. Wish i had it. You were smart to use that. I need to take off my skids to service my transfer case and its the absolute biggest pain trying to pull these skids off. Tore up my hands pretty good when i first put them on.
    If you offroad a decent amount you may need to retorque the bolts every so often as otherwise they pop a lot. At least for me they do, especially the side brackets on the Talon skids. I may try some blue loctite.
    Nbab23 likes this.
  13. May 26, 2023 at 6:35 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    I'm in the same boat, I fear my 30K mile maintenance because of this...
    AggiePhil and PomDad like this.
  14. May 26, 2023 at 6:44 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Hahaha, same. Still got ~6000 miles to dread/think about it though.
    Edit: really considering just doing all fluids at 30k so I only have to take them off once.
  15. May 26, 2023 at 7:00 AM
    300BLK
    300BLK New Member
    Yeah I have no shame saying i'm overdue and its mainly because of how time consuming taking the skid plates will be lol. I'm at 160k and just going to take care of a slew of maintenance items including front and rear diff, brake fluid, pads, rotors all at the same time and just set aside a day for it all.
  16. May 26, 2023 at 7:07 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It’s really not that bad. Hard to fit my arms above the crossmember to tighten those nuts, but other than that, it’s just an extra 20 minutes on either end of the job. Pressure wash the skids while you’re at it.
  17. May 26, 2023 at 7:12 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    My arms were torn up after the initial install of the plates, plus I always get my truck undercoated with fluid film so between the tightness and the oil everywhere it’s not something I look forward to. But I will say the fluid film is certainly doing its job. 4 years in the northeast and not a spec of rust on the underside
  18. May 26, 2023 at 7:41 AM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Leveling kit, TRD wheels, remote start, Hellwig helper springs, TRD Rear sway bar. TRD Rear shocks, Dirty Deed 10" exhaust, S&B Cold Air intake
    My fat arms don't even come close to fitting. I came up with the wrench on stick but I will be making my own nut plate the next time I need to take the plates off.
  19. May 26, 2023 at 7:42 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    So do you advise the use of POR 15 on external areas of the underbody? Or just spray it with the nuxodol after I reform withe the rust kutter? I’ve already done the whole thing with rust kutter at this point. No top coat of paint at all?
  20. May 26, 2023 at 7:49 AM
    Cthulhu
    RCI made a retro-fit bar with nut clips that sits on top of the cross member so you can bolt from the bottom with the engine and trans skids in place, without having to jam your arms up there (if they even fit; mine, like yours, doesn’t :mad:). It’d be neat if RCI offered it standalone; it currently comes with the RCI cat shield kit.
  21. May 26, 2023 at 9:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    My compressor is biggish: 20 gal 5 CFM@90 PSI, but I think a smaller one can do it as well.
    bulldog93, Cl8NL and DZ_[QUOTED] like this.
  22. May 26, 2023 at 9:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    1600UM is tar-like (but it is not tar). It has fiber reinforcement and is loaded with rust inhibitors. It also heals itself when pinched. It dries up somewhat in a month, but remains tarrish for a long time. Doubles as sounds deadening.
    I love this stuff, it's perfect for salty winters and offroad.
    Cl8NL[QUOTED] likes this.
  23. May 26, 2023 at 10:03 AM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Genius! I may have to use that idea next time around
  24. May 26, 2023 at 10:13 AM
    Cthulhu
    LOVE the homebrewed ingenuity, redneck engineering, whatever you want to call it...awesome! :thumbsup:
    The stool is yet another example...fantastic!! :hattip:
    Terndrerrr, WVI, bulldog93 and 2 others like this.
  25. May 26, 2023 at 11:16 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Those MTs look really good on your rig. What size did you end up with????
  26. May 26, 2023 at 11:29 AM
    BigOP
    BigOP New Member
    Oleg
    Ohio
    2014 Tundra Limited MGM
    Officially out of warranty on my ‘14, year and mileage wise.
    WVI, Johnmatrix, Tundra-XP and 5 others like this.
  27. May 26, 2023 at 11:29 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Still have mine as a backup since my mechanics shop was able to tighten the carraige bolts while I had it there for new shocks and shackles. I had the plates all in place but no way could I tighten them fully. Shop said it was easy when up in the air. Sucks lying on your back in garage lol ..but hey still have my cats now :)
    Cthulhu[QUOTED] likes this.
  28. May 26, 2023 at 12:00 PM
    Gainer
    Gainer New Member
    Columbus, OH
    2018 SR w/8' Bed
    Many laps around the garage on that seat... I made it YEARS ago. Now you can buy them all day off Amazon.
  29. May 26, 2023 at 12:02 PM
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    Installed the driver side grab handle. I got fed up dealing with trying to find a scrap one on FB marketplace and just placed an order at my local dealership Wednesday. I'm not one to underestimate an install time - it literally took me longer to go pick up the parts than it did to install them!
  30. May 26, 2023 at 12:08 PM
    BigOP
    BigOP New Member
    Oleg
    Ohio
    It’s not just one part number, correct? A pillar panel and grab bar need to be ordered separate?
