Let's see those Lawnmowers
Discussion in 'Home Improvement' started by Bob, Mar 22, 2017.
  1. Feb 18, 2023 at 8:32 AM
    #181
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    A lot of people swear by Seafoam but I think Techron cleans better
    Check azon you’d be surprised how cheap a new carburetor is
  2. Feb 18, 2023 at 12:30 PM
    #182
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    2020 Tundra Limited
    You would think if the compression is gone it would not crank at all or run rough wouldn't ya?
    I like the idea of carb cleaning or replacement!
  3. Feb 18, 2023 at 12:46 PM
    #183
    Ours started being hard to start. Progressively got worse over 3 years and finally started smoking when it ran. My first thought would be tune up with carb cleaning (rarely works). New spark plug etc. then valve adjustment. Not hard to do yourself. Set of valve feeler gauges and the right specs, just turning some nuts. If that fails and you feel good about the motor otherwise, new carburetor is probably cheap online.
  4. Feb 18, 2023 at 2:40 PM
    #184
    Moon Puppy
    Bob
    2020 Tundra Limited
    Well I went got some Gumout and Seafoam. got'er cranked up with ether and warmed up the motor real good then pulled the air filter off squirting gumout up in the carb throat, actually the duct work but it wanted to stall out so it was doing something. Never saw any puffs of smoke or anything. Then I put an once or two of Seafoam in the crank case and some more in the gas tank. Ran for about an hour, cut the front weeds (no grass growing yet) and during that time I would stop it for a minute and test the crank, by the time I got done it was cranking on first bump. We'll see how that holds out. I watched a video on how to replace the carb, think I need to find a small engine guy around here to do it.
    I'll change oil and drain gas later this week, supposed to be up in the 80s mid week.
  5. Feb 18, 2023 at 8:17 PM
    #185
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Which motor did you go with? I might be in same boat.
  6. Mar 29, 2023 at 7:20 AM
    #186
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Cub Cadet zt2, 60" deck. We have a large property and I keep roughly 2 acres of it cut, plus the road frontage and a few trails. It has a kawi motor. Had it a few years now and it performs great, although, I need to get more aggressive tires for some of the sloppy areas and a few spots where the ditches are a little steep. The property is still rough and far from a nice lawn. The ride is rough so I use a gel foam seat pad, but it's a good machine overall.
    I did the initial heavy work with the brush hog and a chainsaw. I need to get everything smoothed out and nice before I beat the crap out of the mower (the front suspension on that Ferris looks nice. probably $$$ though). The cub cadet was $4k from Tractor supply a few years ago.
    Thought I had better pics of the mower, like a glam shot of it sitting on the trailer when I brought it home, but could only find one with the supervisor sitting on it in the garage.
  7. Apr 23, 2023 at 10:43 AM
    #187
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I finally get to post in this thread. Wife said why are we paying a guy $100/month to cut our grass? I said "Here, hold my beer."
    19HP
    42" cut (we don't need more as we have lots of trees to go around so this is perfect)
    Hydrostatic transmission
    Mulch kit ordered
    Dump trailer with matching wheel color on the way haha
    20230423_105423.jpg 20230423_105428.jpg 20230423_105435.jpg 20230423_110739.jpg 20230423_110743.jpg
  8. Apr 23, 2023 at 11:06 AM
    #188
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    Thats a sharp looking lawn mower :thumbsup:
  9. Apr 23, 2023 at 11:09 AM
    #189
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    What lift and tires are you going with?
    NewImprovedRon and texasrho83 like this.
  10. Apr 23, 2023 at 11:24 AM
    #190
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My buddy came over and we are doing Tundra stuff. He saw the mower and asked exactly that..."How tall are we going with it?" Haha
    I told him they actually have a brush guard for it. I doubt it does much but eh it looks cool lol.
    Leo's first and RichterScale like this.
  11. Apr 25, 2023 at 6:31 PM
    #191
    Moon Puppy
    Bob
    2020 Tundra Limited
    RngNP23EhsGcUsmstZATnAhKG7tx8gkY4TlZ5vyV_1cdb686b7754b9cbb6d649e117f39154a83edb14.jpg
    Y'all asked for it. just under 300 hours clocked, lost the front guard about the same time my Wife drove it up in a tree root and busted the mower deck and I had to get "Tiny the Welder" out and had him fix it. New tires on the front last year. Guess it was out of alignment....
    Last oil change oil ran clear, keep all the filters clear and clean. Going to be spreading out Pennington's Centipede seed and Mulch out most areas. all that brush behind the mower will be gone in a couple of weeks, hired out a guy to clear it back to the property line and will plant something nice down that area.
  12. Apr 25, 2023 at 7:03 PM
    #192
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Did it have a cover for the driver at one point?
  13. Apr 25, 2023 at 7:16 PM
    #193
    hainesfive
    hainesfive New Member
    MD
    2020 Black TRD Sport Crewmax
    TRD Dual Exhaust Weathertech rear floor liner Black out badging Linex sprayed bed TRD PRO Wheels VLED Interior and exterior Drivers side grab handle Front drivers and passenger window tint Focal speaker upgrade with amp and 10" sub Retrax pro bed cover Falken tires
    Toro Titan 60" 3 acres 45 min
  14. Apr 26, 2023 at 6:16 AM
    #194
    Moon Puppy
    Bob
    2020 Tundra Limited
    No, it's an option I never bought. It would be ripped off first drive around my yard. I do a lot of duckin' under the overhangs.
  15. Apr 27, 2023 at 4:22 PM
    #195
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    The little dump trailer came in. Wife said I can't pull the kids around in it. Sheesh now I don't have a use for the damn thing...
  16. Apr 27, 2023 at 5:20 PM
    #196
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    You can still haul the beer around in it.
    Just sucks that you have to stop, get off the mower and get one, instead having them hand you one on the go.
  17. Apr 27, 2023 at 5:21 PM
    #197
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'm sure I can Jerry rig somethin up haha
    WILLINH and RichterScale[QUOTED] like this.
  18. May 25, 2023 at 3:23 PM
    #198
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Figured this would fit in the lawnmower section but I'm stoked about this new weedeater. The battery is a damn Odyssey lol
    Leo's first likes this.
  19. May 25, 2023 at 3:43 PM
    #199
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
  20. May 25, 2023 at 4:31 PM
    #200
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    98 model Grasshopper 614. Got about $300 in it all together. Cuts good, 46 in. Having the deck all the way in front helps you get in and cut things you usually couldn't, only downside is it's 8ft long. Planning to run it till it quits.
  21. Jun 30, 2023 at 9:54 AM
    #201
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Ordered new rear tires for the zero turn. The stock tires are still good, but they're not great for steep hills/ditches or sloppy wet areas.
    Called a local small engine shop and they want $30-50 EACH to swap the tires. And that's with me taking them off and bringing them just the wheels/tires.
    Looks like I'll be doing them myself.
    Only $150 for the set. A place in TN, through Amazon.
    These are the stock tires
  22. Jun 30, 2023 at 8:44 PM
    #202
    Leo's first
    Groton ma
    The hardest part is seating the bead
    A ratchet strap around the middle of the tire helps sometimes then there's always the ether method but its especially dangerous on smaller tires
  23. Jul 4, 2023 at 3:55 PM
    #203
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    What's the purpose of the wheelie bars in the back?
  24. Jul 4, 2023 at 4:37 PM
    #204
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    It's a Lawnstriper.
  25. Jul 5, 2023 at 10:55 AM
    #205
    Dan_Gleesac14
    Dan_Gleesac14 New Member
    2023 Tundra SR5;2018 Tundra Platinum (SOLD)
    JD S140 with 48in deck from Atlantic Tractor. Nothing too fancy as I have just a little under an acre, def makes quick work of it.
  26. Jul 5, 2023 at 5:18 PM
    #206
    Moon Puppy
    Bob
    2020 Tundra Limited
    I went John Deere also.
    Handed down the husqu to my great nephew.
  27. Jul 6, 2023 at 12:12 PM
    #207
    catus
    catus New Member
    Centennial, CO
    I really wanted a TimeMaster, but can't justify the cost for our 1/4 acre lot. So I bought this one...still pricey, but works like a dream. This is replacing a 1987 Toro that is still running great, just a bit heavy and cumbersome for when Mrs. Catus needs to cut the lawn. The renter neighbors aren't much on weed control.
  28. Jul 18, 2023 at 1:31 PM
    #208
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Forgot to post a pic here. There was blood and swearing. It was a very hot/muggy day and one tire really didn't want to seat. Had to pump it up to over 40psi and bounce it like a basketball to get it to pop on.
    Max psi is 32 and they run at like 7psi :eek:
    It was a PITA but I saved $100 and it's done.
    Next I need to see if Kawi makes a supercharger. Then I'm done with mods.
  29. Aug 19, 2023 at 3:14 PM
    #209
    SwitchThrottle
    2021 Barcelona CrewMax
    Not a lawnmower, but I am building a rear rack for my my moms GT235. Made a bunch of progress today.
  30. Oct 3, 2023 at 4:10 AM
    #210
    Kung
    KG, VA
    @RichterScale - how are these working? I've got a 48" ZTR that mows just fine, but there are some slopes on our new property that cause mine to slide a bit in wet grass. The stock tires look just like your OEMs and I'd like to try something like this.
    Eventually I plan on upgrading to a small lawn tractor (e.g., small Kioti or Kubota) but for now I'd like to get as much out of this mower as I can.
