Driving a stock Tundra in sand.
Discussion in '2.5 Gen Tundras (2014-2021)' started by DenaliLess, May 24, 2023.
  1. May 24, 2023 at 10:29 AM
    DenaliLess
    DenaliLess [OP] New Member
    rob
    2019 CrewMax 4X4
    46 gallon transfer flow tank
    Has anyone done it? How much did you deflate if any?
    I will be in a few areas this summer with either lake sand or ocean sand and didnt want to do something I should'nt have.
    Thanks
  2. May 24, 2023 at 10:31 AM
    AZBoatHauler
    So.Arizona
    Definitely air down and hopefully you’re 4x4. I’d say around 15psi…
    EddieBolt and DenaliLess[OP] like this.
  3. May 24, 2023 at 10:37 AM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Indeed.
    Pac12AfterDark likes this.
  4. May 24, 2023 at 10:42 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    It'd be wise to have recovery gear with you as well in case you're in a situation where you lose traction. Once you start spinning, don't let her eat. Also, a way to air up your tires as soon as your off the sand will help so you're not driving far on pavement at 15psi.
    DenaliLess[OP] likes this.
  5. May 24, 2023 at 10:46 AM
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    If you're on the beach, stick to the wet sand, and don't leave your truck idling.
    If you're in the desert, definitely air down
  6. May 24, 2023 at 10:47 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What does the idling do?
    AZBoatHauler likes this.
  7. May 24, 2023 at 10:50 AM
    NCrunner2012
    NCrunner2012 New Member
    Steven
    2007 Tundra Limited 4x4
    I do this almost every weekend in the summer. Air down to 20psi, 4-hi, and you'll be fine.
    bulldog93, DenaliLess[OP] and Jaypown like this.
  8. May 24, 2023 at 10:51 AM
    70m4h4wk
    70m4h4wk New Member
    The truck vibrates enough to dig you into the sand. In the desert you have all the time in the world to dig yourself out. On the beach you have until the tide comes in or you lose your truck. I've seen lots of guys lose their trucks because they were idling at low tide and didn't notice their truck sink up to the axles in the sand. The tide will free the truck from the sand and then suck it out into the ocean. All you can do at that point is try to anchor it so you can at least get an insurance claim.
    DenaliLess[OP] and dondino like this.
  9. May 24, 2023 at 10:57 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    :eek2: That would be a bad day.
    Thanks!
    70m4h4wk[QUOTED] likes this.
  10. May 24, 2023 at 11:06 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    I got all the recovery stuff I need for our trip to the Outer Banks including: a set of traction mats, portable air compressor, recovery hook/strap setup and I will be trying out driving in sand in Conneaut Ohio at their beach. Inflating and deflating the tires will be a PITA if we go into town too often as it will be an 8 mile drive on the beach until you hit cement again, so I don't plan on too much of that. I've buried my truck up to the rockers in a wet muddy cornfield one morning at about 05:00 goose hunting. Took the big John Deer to get me out. Not fun.
  11. May 24, 2023 at 11:09 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    All these years and I had no idea there was sand to drive on in Conneaut.
    When I had a 14 Tacoma, I drove out on the beach in outer banks and it was easy. I didn't air down (I was naive) and I never had an issue if I stayed in the tracks that are already there.
    dondino[QUOTED] likes this.
  12. May 24, 2023 at 11:21 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Interesting, I hadn't thought of that!
    70m4h4wk[QUOTED] and Jaypown like this.
  13. May 24, 2023 at 6:01 PM
    2-4-5 trioxin
    2-4-5 trioxin New Member
    2020 Tundra Limited
    When we go down to OBX we usually air down to 18 psi. Ease the throttle and no hard braking. The tundra does great in sand.
  14. May 24, 2023 at 6:04 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Someone linked the Deadman a while back. I've never used one but the videos make it look like a must have for any recovery kit.
  15. May 24, 2023 at 6:09 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Not stock, but I had my '07 on the Oregon sand dunes last weekend. 275/70 AT's aired down to 17psi. 4hi and turned the nannies off. She ripped!
    Even got to pull a buddies RZR Pro R out of a nasty spot.
  16. May 24, 2023 at 6:10 PM
    Taco-Spike
    Two Trucks
    I feel like sand isn’t that much trouble. I’ve lived near a beach for years going 4-5 days a week for miles at a time running stock air pressure and 2wd. Never had an issue just driving around in my Mazda B2500.
    I’ve seen threads on TW about this also over years and I just don’t think it’s an issue. I get better precautions but don’t feel much action is needed.
    is it just me? Granted I’m just driving, not going up in dunes or anything
    even gone in my Tacoma and didn’t see an issue
  17. May 24, 2023 at 6:10 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Also s4 keeps the trans temps happier.
  18. May 24, 2023 at 7:26 PM
    panicman
    Eric
    2018 SR5 CM TRDoffroad MGM
    This is like a nightmare I have sometimes.
  19. May 24, 2023 at 7:30 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Due to the insane amount of people at my usual beach hotspots on Memorial Day weekend, I'm taking the fam to the National Seashore where it's 4WD ONLY. Won't be nearly as packed.
    I have an air compressor, shovel, and my spare to use as an anchor with the winch (if necessary). Last time I went down there I didn't need any recovery gear whatsoever but best to have and not need than the other way around.
  20. May 24, 2023 at 7:44 PM
    70m4h4wk
    70m4h4wk New Member
    I never had any issues in my 04 Tacoma. Only needed 4x4 to get on and off the beach as the access point was pretty gnarly. I never aired down, and never had any issues. I never did any of the dunes or anything silly though. Lots of guys broke their trucks fucking around like that. I was just cruising for shellfish
    Taco-Spike[QUOTED] likes this.
