Howdy from CA
Discussion in 'New Member Introductions' started by AMan805, May 24, 2023.
  1. May 24, 2023 at 1:34 PM
    AMan805
    AMan805 [OP] New Member
    Austin
    06 TUNDRA 4X4 DOUBLE CAB
    Hi all,
    I come here to find answers for my truck, I have a mechanic do all my repairs for me because I don't trust myself to do work on my daily driver. But I do like working on cars. Perhaps in the future.
    My question is, alongside with the greeting, is that if anyone has had trouble with the transmission? I bought my truck this year January and it was fine at first but recently starting giving me trouble. It struggles to switch gears when gaining speed, it eventually does so, but almost "jumps" it feels like. This is even after it warms up.
    Thanks
    mtucker and WILLINH like this.
  2. May 24, 2023 at 1:39 PM
    Welcome from NY.
  3. May 24, 2023 at 1:55 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Have you checked the transmission fluid level?
  4. May 24, 2023 at 1:56 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    Welcome from SC.
    My 2013 2nd gen has just had a transmission rebuild, all but 250k miles on it. Fine one day, multiple codes the next. Yours could be as simple as a fluid level issue, or even just due for an ATF change, any idea when it was last done?
  5. May 24, 2023 at 2:09 PM
    AMan805
    Austin
    Just got the transmission fluid changed about a month ago, it was having problems before, it didn't change much after the fluid change. I asked him if he changed the filter he said no. Haven't checked the level, unsure how to.
    Thanks,
    Austin
  6. May 24, 2023 at 2:56 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire.
  7. May 25, 2023 at 11:20 AM
    TheBrit
    Mark
    Did you get it done at some 5 minute chain store type place? A conscientious tranny shop would have almost insisted that you had the filter changed at the same time as the fluid.
  8. May 27, 2023 at 6:01 AM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Welcome from Pennsylvania
  9. May 27, 2023 at 7:13 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  10. Jun 1, 2023 at 5:23 AM
    nordicfreak
    nordicfreak New Member
    2015 Navy Blue Tundra SR5 Double Cab
    Topper Decked Drawer System Katzkin Leather
    Welcome. Keep us posted on your findings!
  11. Jun 5, 2023 at 5:03 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Welcome from So Cal
  12. Sep 20, 2023 at 2:05 PM
    AMan805
    Austin
    No, had it done at my mechanic. Looking elsewhere for another mechanic. After some searching on these forums I see a drain/fill 3-4 times is a common thing.
    Thanks for all the welcomes guys.
    Austin
  13. Sep 20, 2023 at 2:19 PM
    AMan805
    Austin
    No idea. Bought this car this last January, I'm assuming the previous owner took very minimal care of this truck. So I'm getting everything I can, within my budget, done.
    as a side note...
    Repairs done since purchase 01/23 to date 09/20/23:
    Took truck in to tranny shop, they said it was fine (also read on another post here that this is a common problem, problem with going to 2nd-3rd, 3rd-4th gear)
    timing belt/tensioner/front brake pads/water pump(was leaking) thermostat.
    new radiator (was leaking)
    just bought spark plugs friend who works on cars gonna help me put em in
    new battery
    multiple new lights (headlight, fog light, bed light)
    new tires
  14. Sep 20, 2023 at 2:21 PM
    AMan805
    Austin
    No sir.
  15. Sep 22, 2023 at 1:11 PM
    You don't need to change the filter.
  16. Sep 22, 2023 at 1:12 PM
    AMan805
    Austin
    ok
  17. Sep 22, 2023 at 1:37 PM
    And as to "why", it's just a sheet of metal mesh which is more about screening chunks. It's not a paper or fiber element like you find in a lot of other vehicles. It's not worth popping off the pan to swap out the filter. Drain and fill; and note, it may not fix the trans. Also note, there's a late-shift thing that happens on the 1st gens naturally, when cold.
  18. Sep 22, 2023 at 1:40 PM
    AMan805
    Austin
    Appreciate that. As I read the forums more I think that's what's happening. I'll continue to drain/refill the tranny fluid.
    Austin
  19. Sep 22, 2023 at 1:54 PM
    EC1
    EC1 Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    Well howdy, neighbor! We're up in Rocklin! What part of CA? North, south, central, Bay, somewhere in between?
  20. Sep 22, 2023 at 2:01 PM
    AMan805
    Austin
    Santa Barbara
    EC1[QUOTED] likes this.
  21. Sep 22, 2023 at 2:53 PM
    Scud
    Scud New Member
    San Francisco Bay Area
    2017 1794 Tundra Super White
    Working on it :-)
    Welcome from NorCal
