2014 Toyota Crewmax
Discussion in '2.5 Gen Tundras (2014-2021)' started by chucklesya77, Aug 7, 2017.
  1. Aug 7, 2017 at 7:15 PM
    chucklesya77
    chucklesya77 [OP] New Member
    Lyle
    2014 Tundra Crewmax
    None
    Has anyone had a 2014 tundra 5.7 L TRD 4wd or relative model just not start? My truck literally has 25k and always maintained on time by factory dealer and would not start the other day. I am pretty mechanically inclined, and the battery measured 12.6 volts, but still tried to jump it with another vehicle. The lights would not turn on or anything. Anyway, had it towed and the dealer said it was just the battery and anyone who had the slitest clue knows that the at least some electronics would work. Just wondering if there's a bigger issue and if anyone else has experienced anything similar?
  2. Aug 7, 2017 at 7:24 PM
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    I have the 2014 5.7L Crewmax with 26k miles on it. Same issue as yours. Battery was replaced by the dealer.
    14burrito likes this.
  3. Aug 7, 2017 at 7:36 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  4. Aug 7, 2017 at 7:45 PM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    Welcome from SOMD. I'm subscribed, I have a 2014 TRD CM. No issues but I'd like to know the cause :popcorn:
  5. Aug 7, 2017 at 8:16 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Man, I have a 14' with about 10k miles, stuff like this makes me wonder if I should replace the battery as a precaution....
  6. Aug 7, 2017 at 8:22 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I had a battery issue too. My battery wasn't holding amps I had a 125k warranty but I was way out from a toyota dealership.16 95k. Replaced it with a Duracell battery.
  7. Aug 7, 2017 at 9:58 PM
    Bienvenidos de Tejas! New member...show us your ride...bought a 2014 CM 5.7 SR5 TSS with 26000 still has stock batt no issues...only issue having now is stock radio head unit freezes up or restarts
  8. Aug 7, 2017 at 10:20 PM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    My radio was doing the same thing. Had the dealership update it, no problems since.
  9. Aug 7, 2017 at 10:22 PM
    Ok ill look into...Thanks!!!
  10. Aug 7, 2017 at 10:26 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    My radio was doing the same thing. Dealership replaced it under warranty.
  11. Aug 7, 2017 at 10:27 PM
    I have 41377 still falls under???
  12. Aug 7, 2017 at 10:29 PM
    Coolhardy
    Harris
    2014 black tundra
    Too many to list
    Nop, gotta be 3 year 36,000. Try it anyways. Try one dealership if it doesn't work try the 2nd one or maybe the third one. Third time a charm.....
  13. Aug 7, 2017 at 10:30 PM
    Its not that bad... jus happens once in while...but ill look into
  14. Aug 8, 2017 at 2:55 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    When my stock battery died, it died without any warning, not even a hint that it was going bad. I took the battery to Advance Auto and they tested it and said it was okay. I put in into my battery charger, and it would not even charge. I now have Interstate battery. My stock battery lasted less than 5 years (granted my driving pattern is hard on the battery).
  15. Aug 8, 2017 at 3:21 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    Just because you read a voltage potential across the battery terminals that doesn't mean the battery isn't bad. It also doesn't mean it can supply the current it needs to. Modern vehicle have extensive electrical systems and the battery obviously wasn't holding the state of charge needed to run the electrical system. Even trying to jump with another vehicle, a bad battery can have a high internal resistance and your vehicle wont see the current it needs. Did a new battery fix the issue?
    MotoTundra, NewImprovedRon and Tomcat like this.
  16. Aug 8, 2017 at 7:23 AM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    X2
  17. Aug 8, 2017 at 9:16 AM
    chucklesya77
    Lyle
    2014 Tundra Crewmax
    None
    Yes, but that means you can't even jump this vehicle...agin, there was no sign of a degrading battery and the fact that the lights or any electronics wouldn't turn on seems very odd. And if that is because of the computers within the vehicle...toyota's reputation won't last...
  18. Aug 8, 2017 at 10:26 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Still under warranty or not? If not....how much they charge?
  19. Aug 8, 2017 at 10:37 AM
    chucklesya77
    Lyle
    2014 Tundra Crewmax
    None
    It's under warranty as the truck only has 25k on it. I'm not concerned about paying for the battery as much as getting stranded somewhere on a road trip...what I'm gathering is with these "computers" you have to carry a spare battery or risk this crap! Absolutely rediculous
    4x4_Angel likes this.
  20. Aug 8, 2017 at 10:40 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    Mines not under warranty any more...it has 91k on it....that's why i ask. I've had my radio torn itself off then turn back on. No issues with my battery
  21. Aug 8, 2017 at 11:21 AM
    Redbeard321
    I wouldn't say you need to carry a spare battery, but if you are going on a long trip and your battery isn't new I would have it checked by someone with an instrument to measure it's ability to accept a charge and supply a current. Normally with a "dead battery", assuming it's just at a low state of charge, you can still jump it. It's not the end of the world, you just had a bad battery. Assuming you had a 2014 battery in your 2014 truck it's not that hard to believe a new one is in order 3 or so years later.
  22. Aug 8, 2017 at 11:27 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    And depending on where you live....it could need to be changed even more often. Higher heat drains the battery even quicker than "normal" conditions
  23. Aug 8, 2017 at 11:56 AM
    chucklesya77
    Lyle
    2014 Tundra Crewmax
    None
    It's not the end of the world, but the truck was in for scheduled maintenance less than two months ago and gave no indication of a "bad battery." I think it's funny that people find this acceptable...if you were stranded you might think differently as you can't even jump the stupid thing...
  24. Aug 8, 2017 at 11:59 AM
    chucklesya77
    Lyle
    2014 Tundra Crewmax
    None
    Again, there should be an indication or at least a factory recommendation of changing the battery every 20k miles...
  25. Aug 8, 2017 at 1:19 PM
    easleycrawler
    Travis
    Yes, mine was still under warranty.
    4x4_Angel[QUOTED] likes this.
  26. Aug 8, 2017 at 2:08 PM
    Redbeard321
    You had a battery die, it happens. Shit happens.
  27. Aug 8, 2017 at 3:34 PM
    chucklesya77
    Lyle
    2014 Tundra Crewmax
    None
    Good answer, just shut up and pay...was wondering if this was a common problem and people like you come on here and make stupid comments...
  28. Aug 11, 2017 at 4:27 AM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    I change out batteries in my wife's car-Honda Accord and my Tundra every 3 yrs. When they go they usually go without any notice. Getting stranded due to a dead battery -non issue. Last Tundra battery from dealer $119.00 -done.
  29. Aug 12, 2017 at 10:54 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    This has happened to me on my wife's 2001 Trans Am, my 2004 GTO and 2014 Silverado. The guy at the battery store told me that the heat from these engines along with the Texas heat cause the plates to short and that is why there may be voltage but no cranking amps. I agree that in the past, I was able to jump start and still can in certain circumstances (battery drained due to parasitic electronics while vehicle sat for 6 weeks), but when the batteries on these cars failed, they just died - 2001 Trans Am got the wife to the store and when she came out it wouldn't start. Just pointing out this is not a Tundra only issue. It was recommended to me by Batteries Plus that I should change batteries every 3 - 4 years (living in Texas, not daily driven). They see a lot of them die like this.
  30. Aug 13, 2017 at 4:27 AM
    PMG
    PMG New Member
    Yep, too much electronics in the cars nowadays. I'm sticking to my Schwinn on road trips from now on.
