  1. May 22, 2023 at 11:45 AM
    :101010:
  2. May 22, 2023 at 5:25 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    BF5CF7D8-0844-414B-8FB2-3B4C5CE209F3.jpg A3F9C3CF-C03E-4C24-AE9D-A396176C1627.jpg
    Over the weekend I installed a Westcott Designs lift and today got some Cooper AT3 Discoverers 195/70 and had front end alignment done. I removed mud flaps just incase they were going to rub but I believe I’ll be able to put them back on. It’s nice having a few more inches in height. I installed lift kit myself. Wasn’t too bad after I figured it out. I still have skid plate and cat shields off. I think I’ll spray them with Raptor bed spray before I put them back on.
  3. May 22, 2023 at 5:57 PM
    Azblue
    The Dirty T ( ^_^)_且
    TWSS
  4. May 22, 2023 at 6:55 PM
    Rangergillikin
    Alabama
    Well played!lol perfect setup.
    Azblue[QUOTED] likes this.
  5. May 22, 2023 at 7:02 PM
    Installed the P.I. hitch lock.
    WVI, bulldog93 and JCBerb like this.
  6. May 22, 2023 at 10:32 PM
    4x4 gypsy
    4x4 gypsy New Member
    2017 Crewmax 4x4
    It did. But also changed tire brands at the same time and I carry a lot in the back constantly. Rides good on flat roads. On the Tacoma had kings installed and of course I’m missing those. Not a fair comparison but if I had more money yes please. The uneven roads with dips and bumps aren’t great but I’m hoping it settles in after a few hundred miles. Also wondering whether changing to 17 wheels with a couples sizes up in tires may help soften it up by absorbing more from the road. I’m on the stock 18s with stock tire size.
  7. May 22, 2023 at 10:33 PM
    4x4 gypsy
    2017 Crewmax 4x4
    Stock: 275/65/18
    Wish I had gone 275/70/17 or maybe one more size up.
  8. May 23, 2023 at 7:28 PM
    ohiowa
    ohiowa Have you tried turning it off and back on again?
    Ohio
    2021 SR5 CM Cavalry Blue
    28k oil change
    Mobil 1 0W-20
    My very first Fumoto installed
    I'm looking forward to the next one when I can just run a tube to the drain pan instead of guessing where it's gonna splatter.
  9. May 23, 2023 at 8:00 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    I use a piece of rubber tubing to drain from the valve to pan. I also recommend two drain pans so you can drain from the sump and filter at the same time. While these drain, rotate your tires. Have you gotten the MotivX kit with the oil filter housing socket, drain tube and oil fill funnel? Those all make the change a much more enjoyable process.
    rdiddy5, CaptRussia253, WVI and 2 others like this.
  10. May 23, 2023 at 8:11 PM
    ohiowa
    Ohio
    Yes, though I had to pry the housing wrench off the housing with a screwdriver since it was stuck.
    Had the oil fill funnel already since the last truck was a 2.5 gen taco.
    Overall not a bad process. Didn't need to remove the SR5 "skid plate" (term used loosely here) to get to the filter, which was a plus.
    DZ_[QUOTED] and bulldog93 like this.
  11. May 23, 2023 at 9:33 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    45k oil change, Kirkland 0w-20, OEM filter.
    Rotated tires (rearward cross).
    OHwendTrd, BlueRibbon4x4, WVI and 5 others like this.
  12. May 24, 2023 at 7:55 AM
    Cl8NL
    Cl8NL Pocket-Sand
    MKE WI
    2017 SR5 5.7 4x4 quicksand dbl cab
    I wire brushed the entire underside of my 17 two days ago and did some sloppy test sprays of Rust Kutter (highly rated citric and phosphoric acid rust reformer). Truck wasn’t on ramps or lift and that stuff hurts to have drip on ya lol. I like the initial results so here is my plan going forward, please lemme know if I’m on the right track-
    • I’m going to finish the job and do about two more coats of rust kutter, making sure all visible rust is reformed.
    • After that stuff fully dries/converts I’m going to do a full application of POR15.
    • before winter I will apply fluid film or PB blaster surface shield (every winter)
    for comparison sake I only sprayed the right side of the diff. I didn’t have much time and only did about 1 min of spraying with a patchy inconsistent application, anywhere that is white used to be rust - you are to rough up the white and apply more to fully convert with rust kutter
  13. May 24, 2023 at 9:05 AM
    Cthulhu
    Switch Pros 9100 with SDHQ center console mount. Got rid of a bunch of relays and wiring under the hood; much cleaner looking. Kept two switches open for possible front and rear locker options. The off-road flash and strobe functionality, as well as the master switch function, are neat bonuses.
    https://youtube.com/shorts/04lObnNiZ44?feature=share
  14. May 24, 2023 at 9:14 AM
    Taco-Spike
    Two Trucks
    Nice!
    Cthulhu[QUOTED] likes this.
  15. May 24, 2023 at 12:13 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Sounds like a good plan.
    I tried a can of the PB Blaster Surface Shield.....I'll not spend the money on another can. It was a PITB to get it to keep spraying. It sprayed like a can of .99 cent spray paint!
    Cl8NL[QUOTED] likes this.
  16. May 24, 2023 at 12:28 PM
    SAGE63
    San Diego County
    Hit a milestone... original warranty out of mileage... glad I have the extended... btw mpg is actually closer to 12.5 with 5.29 grears and 37s
  17. May 24, 2023 at 1:11 PM
    LabRat
    LabRat New Member
    Houston TX
    '14 Tunda
    Stealership oil change and tire rotation. They threw in a "free" wash...
    While it was there, I asked if they'd pull off the tow hooks for me so I could paint them...they said sure for $165...?!? Hard pass...
  18. May 24, 2023 at 1:13 PM
    AZBoatHauler
    So.Arizona
    :rofl::rofl::rofl:
    I mean - that only translates to like $3,000/hr.
  19. May 24, 2023 at 1:15 PM
    LabRat
    LabRat New Member
    Houston TX
    '14 Tunda
    I know, I'm clearly in the wrong line of work!
  20. May 24, 2023 at 1:15 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
  21. May 24, 2023 at 1:34 PM
    1794TX
    Steven
    N.TX
    '20 1794
    Tell the spouse what they wanted to charge you, with added acrimony; and then explain why it's important for you to save money by getting your own tools:
    DEWALT XR 1/2-in 20-volt Max-Amp Variable Speed Brushless Cordless Hammer Drill (2-Batteries Included) in the Hammer Drills department at Lowes.com
  22. May 24, 2023 at 1:36 PM
    They gave you a "free" wash which translates to "you are probably missing a skid plate bolt or two now".
  23. May 24, 2023 at 2:19 PM
    wiltech
    wiltech New Member
    Tony
    Lafayette, IN
    2018 Inferno Limited
    Nah, he needs the 1/2" impact for the extra ugga duggas (will need it to get the oil filter housing off next time anyway)
    Red: https://www.homedepot.com/p/Milwauk...One-5-0-Ah-Battery-and-Bag-2767-21B/312012941
    Yellow: https://www.lowes.com/pd/DEWALT/5002909283
    Blue: https://www.lowes.com/pd/Kobalt-24-...s-Impact-Wrench-1-Battery-Included/5013201381
    Whichever battery ecosystem you already have...
  24. May 24, 2023 at 4:02 PM
    the red
    the red the threat is real
    New Brunswick, Canada
    haha yeah…wrong tool for the job though
    Unnecessary teal option: https://www.homedepot.com/p/Makita-...-w-Friction-Ring-Anvil-2-5Ah-GWT01D/316617986
    :D
    wiltech[QUOTED] likes this.
  25. May 24, 2023 at 4:04 PM
    the red
    Hope enough air is getting to your rad.
  26. May 24, 2023 at 4:46 PM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Haha. I lived this also. The local stealership did not seem shocked or even apologetic. Have not been back.
    Tundrastruck91 likes this.
  27. May 24, 2023 at 4:46 PM
    1794TX
    Steven
    N.TX
    '20 1794
    It's not an impact driver, but it definitely gets the job done. And it's a multi-tasker...
    WVI, RainMan_PNW and PlaysARobin like this.
  28. May 24, 2023 at 6:10 PM
    Cthulhu
    Yep, monitor the temps, all good.
  29. May 24, 2023 at 6:18 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Busy 3 wks. So I finally got a driver side grab handle. The install was a breeze. Did what another member did using his idea and called several dealers. What do you know a dealer close by ordered one for me and had it in a week. I also got the TRD dual exhaust painted and installed that as well along with the ESP storage. You know, i never know what size to upload these pics as so it can be seen good enough.
    rdiddy5, mgm16trdpro, the red and 3 others like this.
  30. May 24, 2023 at 6:33 PM
    PlaysARobin
    PlaysARobin New Member
    Thomas
    East Houston - Texas
    2021 TRD Pro Super White
    (2021 TRD Pro) AMP Steps, Ceramic Tint 5/20/70 windshield, Kilmat floor, doors and rear with Audiofrog/Arc audio/JL speaker upgrades and factory HU. AJT blackout. Ironmax4x4 Raid bumper with 10w amber work lights and 32" light bar. Rago dash setup with Bulletproof phone mounts. VLEDs interior kit with front and rear footwell lighting. X2Power AMG 27F.
    Only one uni-tasker allowed, and it serves the same purpose in the garage as the kitchen.
    1794TX[QUOTED] likes this.
