Bedside Decal Removal - I may have made a horrible mistake
Discussion in '2.5 Gen Tundras (2014-2021)' started by evanhauer, May 23, 2023.
  1. May 23, 2023 at 7:47 AM
    evanhauer
    evanhauer [OP] Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    Yesterday, I started to replace the white TRD 4x4 passenger side decal with some new matte black ones for both sides.
    As I was peeling off the factory decal I realized with horror that there was some kind of significant coating over the top of it, resulting in a glaring outline where the sticker used to be.
    :annoyed:
    I did have the truck fully detailed, clay bar, and ceramic coated in October. Could this possibly be the ceramic coating? It seems so thick like it somehow got factory clear coated over the sticker.
    I have an email out to my detail shop asking the same question, but wanted to get some more eyes on it or see if anyone here has had this experience?
    Trying to determine if this can be "buffed out" and re-coated or if I should be calling around to auto paint shops to correct it.
    Good news is the driver's side looks great!
    panicman likes this.
  2. May 23, 2023 at 7:57 AM
    Outbound
    Aaron
    Northern Alberta
    Have you tried one of the eraser wheels that goes on a cordless drill? That might just be residue.
    1UP, evanhauer[OP], 1lowlife and 3 others like this.
  3. May 23, 2023 at 8:39 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    It can be buffed out. You are correct it is probably polish and ceramic that built up on the edges of the stickers.
    Either you or your detailer can buff it out.
  4. May 23, 2023 at 10:22 AM
    gizardlizard
    gizardlizard New Member
    Madison,WI
    2017 TRD pro Tundra
    6” lift, 35 inch tires, chrome delete, ridiculous stereo
    It will come right off with the correct buffing wheel. I once was able to remove PAINTED on lettering on outboard power head. After removing the lettering, you could still read the lettering underneath as it etched the original surface. I tried polishing first with an orbital and then was able to finally remove it with a high speed rotary and a heavier compound. Yours will be quick and easy.
    bulldog93 and evanhauer[OP] like this.
  5. May 23, 2023 at 10:25 AM
    evanhauer
    Erik
    VT
    Well these replies are good to hear. Finally a situation where hearing "It'll buff right out" is actually true!
    bulldog93, panicman and batman900 like this.
  6. May 23, 2023 at 10:44 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    :itllbuffout:
  7. May 23, 2023 at 11:14 AM
    Rubberdown
    Rubberdown Spilling my guts here.
    Well, your issue is going to be that if it was ceramic coated and you remove the decal, there is no ceramic coating there. You’re gonna have to strip the entire panel of ceramic coating and then reapply so you’re going someplace anyway to get that done. Might as well have them do it.
  8. May 23, 2023 at 11:14 AM
    d_kinneyjr
    d_kinneyjr New Member
    Dave
    Southern NH
    2018 Crew Max SR5
    I had the same residue after I took my bed stickers off. I too used the eraser wheel. Removed all the un-wanted sticker goo! Good Luck
  9. May 23, 2023 at 5:12 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Looks like it might just be glue?
    Go to the autoparts store and get 3M adhesive remover. Usually comes in a white aerosol can with red lettering. It's magic. Spray directly on the remaining glue then wipe off with a soft cloth. Might take a few times, but it'll come right off if thats what it is. That's how i removed my TRD stickers.
    bulldog93 likes this.
  10. May 23, 2023 at 6:57 PM
    evanhauer
    Erik
    VT
    I think some of you guys are seeing the image in the reverse of what it actually is.
    Where the sticker was is an indentation - in other words the entire rest of the panel surrounding the sticker shape is a raised coating.
  11. May 23, 2023 at 7:05 PM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    That's really weird if so. Is it the same on both sides?
  12. May 23, 2023 at 7:10 PM
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    It's actually very interesting, to see the ceramic coating and how thick it is over the paint. I hope it doesn't cost you too much to have to reapply the ceramic
  13. May 24, 2023 at 7:18 AM
    yakeng
    yakeng 3URFE Apologist
    Yea, I'm confused how the driver side is OK but the passenger side had this issue? Maybe I'm missing something.
  14. May 24, 2023 at 8:09 AM
    evanhauer
    Erik
    VT
    I only had an OEM decal on the passenger side. Sorry, didn't mean to be confusing, I just assumed that was Tundra stock - I guess the PO removed the driver side decal at some point in the past pre-whatever-the-hell-this-layer-is.
    So my driver side was all good-to-go for the new matte black decal.
  15. May 24, 2023 at 8:51 AM
    Has the truck been repainted on that side?
  16. May 24, 2023 at 8:59 AM
    evanhauer
    Erik
    VT
    I guess I don't have any record or evidence of it being repainted.
  17. May 24, 2023 at 9:15 AM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
  18. May 24, 2023 at 10:44 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    Removed the TSS stickers from that location on both of my 2018s. WD-40, a microfiber, and elbow grease removed that with no problem. Follow that with a wash and coat of wax and theres no evidence the sticker was even there.
