Black box with wire by windshield
Discussion in 'General Tundra Discussion' started by TundraTRD08, May 22, 2023.
  1. May 22, 2023 at 3:23 PM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    There is this black box with a wire on the driver side of the dash on my 2008 sr5 trd off-road. Maybe something to do with the security system? JBL? It has to be factory, so that may narrow it down.
  2. May 22, 2023 at 3:26 PM
    TundraTRD08
    Wesley
    How I feel:rofl:
    Sierradevil likes this.
  3. May 22, 2023 at 4:05 PM
    What radio is installed? That looks like the GPS that comes with some aftermarket radios.
  4. May 22, 2023 at 4:07 PM
    TundraTRD08
    Wesley
    Stock JBL head unit without navigation. And this was bought new, so no previous owners could’ve done it
  5. May 22, 2023 at 4:09 PM
    That was added at some point. Definitely not OEM.
  6. May 22, 2023 at 4:17 PM
    Elbman
    Elbman New Member
    2016 Grey Tundra Platinum
    Aftermarket GPS or Satellite Radio antenna.
    1lowlife, Mater and TundraTRD08[OP] like this.
  7. May 22, 2023 at 4:20 PM
    Yinzer73
    Yinzer73 New Member
    Menifee, Ca
    2011 Tundra 5.7
    None yet but the list is growing
    2nd the Satellite Radio antenna. I had one years ago when I got Satellite Radio with a vehicle that's radio was not set up for. Ran on an FM radio station that was not in use. Looks exactly the same
    1lowlife likes this.
  8. May 22, 2023 at 4:28 PM
    TundraTRD08
    Wesley
    :notsure::notsure:
  9. May 22, 2023 at 4:30 PM
    TundraTRD08
    Wesley
    Maybe satellite. There’s no gps and I bought it new
  10. May 22, 2023 at 4:32 PM
    I'm confused lol. So you bought the truck new in 2008 and it's been there since then? :facepalm:
  11. May 22, 2023 at 4:33 PM
    TundraTRD08
    Wesley
    Yes.;)
  12. May 22, 2023 at 4:39 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Looks alot like the gps antennae in my 2008 jbl with nav. Mounted on a metal plate just underneath the dash in about that spot.
    TundraTRD08[OP] likes this.
  13. May 22, 2023 at 4:40 PM
    TundraTRD08
    Wesley
    What’s weird is that I don’t have factory nav. Maybe it’s just prewired
  14. May 22, 2023 at 4:42 PM
    Gravy
    Yucaipa, California
    Probably. The things are dirt cheap, maybe they meant to put a nav unit in then the order got changed. :notsure:
  15. May 22, 2023 at 4:44 PM
    TundraTRD08
    Wesley
    Good possibility
  16. May 22, 2023 at 4:49 PM
    TundraTRD08
    Wesley
    It sis pretty loaded up for an sr5. Leather with gel, backup camera, JBL, steering wheel controls, power and dimming rear view mirrors, dual temp A/C, info screen thing on dash, and some other stuff I can’t think of lol
  17. May 22, 2023 at 5:12 PM
    I highly doubt that it would have been left like that.
  18. May 22, 2023 at 8:25 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    Navigation antenna or satellite radio antenna. Since you said the truck does not have navi, I would assume satellite radio.
  19. May 22, 2023 at 8:59 PM
    Gravy
    Yucaipa, California
    I'm assuming he means that its been underneath the dash since he's had it. Even the metal plate its resting on looks like the mounting plate for the antennae from under the dash (at least as well as I can remember).
  20. May 23, 2023 at 4:31 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    Looks like the satellite radio antennas we use to install back in the early 2000s in cars
  21. May 23, 2023 at 5:27 AM
    PermaFrostTRD
    Northern NY
    OP did you recently pull the dash and find it? Or have you had the truck for 15 years and just finally noticed that? Color me confused also.
    If it's the former, I'd guess GPS antenna. All of the 2.5 gens have a GPS antenna even if the head unit doesn't support the factory Nav. I'm guessing that's your situation.
  22. May 23, 2023 at 8:30 AM
    TundraTRD08
    Wesley
    I’ve seen it all this time, just kinda looked past it, but got curious lol. Call me a 2.5 gen!:rofl:
  23. May 23, 2023 at 8:39 AM
    PermaFrostTRD
    Northern NY
    Ha! sorry I should clarify - I know you're a 2nd Gen, I was just saying that since all of the 2.5's have the GPS antenna it wouldn't be out of reason to presume that the 2nd Gens did too regardless of head unit.
  24. May 23, 2023 at 8:51 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The oddest thing about this pic is the splice.
    It's a shielded cable and a bitch to splice.
    I can't see this being OEM, it's too sloppy.
    A metal plate stuck to the dash and a magnetic satellite or GPS antenna?
    Do/did you have a satellite radio, maybe an external unit?
    It looks a lot like the satellite radio antennas I used in my work tractor over the years.
    Have you ever pulled the HU and seen if the other end is in there?
    Ever pull it up and see if anything is written under it?
  25. May 23, 2023 at 9:24 AM
    TundraTRD08
    Wesley
    I do have satellite radio. And it does plug into the factory head unit. And as for it being sloppy, maybe they got frustrated, or the truck just took a long time to build. When I pulled the sunglasses holder thing above my head, there where hearts and smiley faces drawn into the roof, and had surface rust on em. Point is, they can be known to be “sloppy” haha
    1lowlife[QUOTED] likes this.
  26. May 23, 2023 at 9:40 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    100% aftermarket XM or Nav antenna installed by a monkey that gave 0 fucks.
  27. May 25, 2023 at 8:11 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    To me the most interesting part about this is that you looked at it for 15 years, and then one day suddenly went
  28. May 25, 2023 at 8:25 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    100% gps antenna from an aftermarket stereo with navigation.
    The magnetic plate under it is a dead giveaway.
  29. May 25, 2023 at 8:33 AM
    TundraTRD08
    Wesley
    I’m thinking another dealer did this. It was bought in Arkansas, but a dealer in Texas put a few goodies on it
  30. May 25, 2023 at 8:40 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    That dealer in Texas has been tracking you since 2008.
