For you solar octane trd pro nuts wanting trd watch
Discussion in '3rd Gen Tundras (2022+)' started by nodak67, May 22, 2023.
  1. May 22, 2023 at 10:14 AM
    nodak67
    nodak67 [OP] New Member
    JR
    https://www.autoblog.com/2023/05/20/toyota-trd-pro-watches-are-far-from-subtle/
    Toyota has partnered with Original Grain, a San Diego-based watch company that carved a niche for itself by using sustainably harvested wood to craft their timepieces. Called the Solar Octane collection, subtlety is not their forte. The watches are named after the orange color exclusive to TRD Pro Tacoma, Tundra, 4Runner and Sequoia for 2023.
    Somewhat confusingly, there are three watches named after three different trims for Toyota's off-road rigs. The top-of-the-line TRD Pro is a 44mm with automatic movement constructed of "racing grade" aluminum and blackwood. It wears a camouflage — if you can call bright orange digital camouflage — pattern and comes in its own orange rugged case. It costs $749 and is limited to 250 pieces, each serial numbered.
    The middle-grade one is called the TRD Off-Road, named after the grade that's not as hard-core as TRD Pro but still fairly off-road capable. It's a 45mm case with solar movement made of stainless steel and blackwood. It too features a digital camouflage print, but at least the primary color is black. It's priced at $549 and is also limited to 250 individually numbered pieces.
    Finally there's the TRD Sport, named for trucks tuned for street use. It has a 45mm case, uses solar movement and is made of stainless steel. It costs $595 and is not a limited production item.
    manapiko likes this.
  2. May 22, 2023 at 10:19 AM
    Taco-Spike
    Two Trucks
    I have a few OG watches
