Fuel Mileage
Discussion in '1st Gen Tundras (2000-2006)' started by Zoroaster, May 21, 2023.
  1. May 21, 2023 at 12:32 PM
    Zoroaster
    Zoroaster [OP] New Member
    2002 LTD AC TRD
    Had the opportunity to find some 89 octane for the same price as regular elsewhere and filled up with <1/8 tank 87. Drove 24 miles mixed city/hwy, redlining in 1st when possible…
    Stopped at a shell and only needed 1.1 gal. Granted efficiency should be better with a full tank, but this seems better than on 87 with increased throttle response (though I did run some injector cleaner two tanks ago).
    anyone running premium while naturally aspirated in a non-vvti? I can’t imagine any gains would be had to offset the expense. One would assume the vvti was more efficient, but what is the experience here?
  2. May 21, 2023 at 5:04 PM
    SeanL
    SeanL New Member
    2002 Supercharged Beauty
    Octane of gas barely if at all increases mpg for any vehicle. Want better mpg? Tonneau cover and 12port injectors for the tundra are the best from what I hear
    Aerindel likes this.
  3. May 21, 2023 at 5:48 PM
    Mythbusters quashed the 'bed wind resistance' myth by removing the tailgate entirely and driving with it. I know tonneau manuf'ers like to claim improved fuel efficiency via less drag, but based on Mythbusters' tests, it looks bogus.
    They tested it in Episode 43.
    Then re-tested with other methods in Episode 64.
    I suspect the 12-holed injectors thing is a myth too. So far no evidence on that one.
    2006Tundra, bmf4069, Aerindel and 2 others like this.
  4. May 21, 2023 at 7:03 PM
    Zoroaster
    2002 LTD AC TRD
    Im sure most people run 87 unless boost is involved or they prefer ethanol free. Is vvti supposed to help with the mileage as well or just power though?
  5. May 21, 2023 at 7:38 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Just to clarify (you probably know, but in case anyone misunderstands your post), ethanol can be added as an oxygenate to regular (87), mid-grade, or premium gasolines. If you want ethanol-free gasolines, you need to look for signs that say ethanol-free.
  6. May 21, 2023 at 7:50 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    You can wash ethanol out of fuel, but gimme the cheap gas for the truck, cause the buell only takes premium.
    i average about 17mpg stock height, stock tires.
    gas is 2.90 here, mid grade is 3.14, i'd be 8% (or whatever) more pissed at people effing up my momentum if i were paying 8% extra for my gas.
  7. May 21, 2023 at 8:07 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Been a while since I watched it... but wasn't the myth better mileage with tailgate down? And it proved the opposite.
    Better with it up and/or with a tonneau.
  8. May 22, 2023 at 4:56 AM
    Demented Canine
    Demented Canine Hiding in the Baffles
    Extreme Southeast Georgia
    2020 MGM SR5 DC
    Stock '02 SR5 Access Cab V8 Auto 2WD with 265 70R16 Tires inflated to 34 psi cold. ARE Hard Tonneau. Exxon/Mobil 87 Octane Fuel.
    My usual observations over a 250-mile trip on Scangauge II (Interstate Driving):
    20.9 mpg @ 70 mph. Fuel Flow about 4 gph
    24 mpg @ 62 mph. Fuel Flow about 2.5 gph
    Manual calculations based on distance traveled and fill-up quantities confirm this.
    Zoroaster[OP] likes this.
  9. May 22, 2023 at 5:11 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    What engine? Auto or manual? 4WD or 2WD? Important details...
  10. May 22, 2023 at 5:47 AM
    Demented Canine
    2020 MGM SR5 DC
    Agree. Updated Post.
    w666[QUOTED] likes this.
  11. May 22, 2023 at 5:49 AM
    Correct. I probably could've worded more clearly.
