5 sec- 1 min delay to engage into reverse??? SOS
Discussion in '2nd Gen Tundras (2007-2013)' started by jd77, May 21, 2023.
  1. May 21, 2023 at 11:07 PM
    jd77
    jd77 [OP] New Member
    I recently acquired a 2nd gen Toyota Tundra 4x4. It runs great and I love the ride. However there is this very problematic issue with the transmission engaging into reverse.
    When I shift from park/neutral/drive into reverse, there is a delay that can be anywhere from 5 seconds, all the way up to a minute plus. It’s worse when trying to engage into reverse at a decline.
    I’m going to try and flush the trans and change filter but not sure what to do if that doesn’t work.
    Anyone deal with this issue before?
    Any and all help will be greatly appreciated! Thank you all in advanced!
  2. May 22, 2023 at 1:12 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I've not dealt w/that problem. How many miles on truck? Good choice to start w/a trans service.
    I know there are different schools of thought on doing the trans service; some say flush, some say drain and fill :notsure:
    Speaking from personal experience and hearing stories of others w/high mileage trucks, I sit on the side of the fence that says to only drain and fill (not flush). It is my understanding that older transmissions (especially ours) can kinda find a niche w/what they have in their systems for fluid and sludge. Sometimes removing everything (flush) can create a problem and some folks have reported having catastrophic failures immediately following a flush, especially when the trans has not been serviced in a while. Most of the techs I've spoke w/suggest drain and fill only and to use ONLY Toyota ATF WS. Just my opinion....
    I'm sure you'll have more folks w/considerable experience jumping on here to offer some thoughts and advice in the morning.
    Good luck w/finding a simple and inexpensive resolution.
  3. May 22, 2023 at 10:15 AM
    jd77
    Thanks Tripleconpanna,
    miles 191000
    I’m not very mechanically inclined but able to do basic maintenance jobs. Everything else I use YouTube university lol. But I am unable to find anyone dealing with this exact issue. Most people experience issues shifting into other gears as well as reverse. But mines only in reverse. When I shift into reverse, the trans stays in neutral and takes time to engage, I don’t mind 5 sec delays, still humbug but it’s those min plus delays that got me really wanting to fix this thing. I’ll try posting a video to view. And will take your advice on draining and refilling with Toyota ATF. Praying that someone on here may have had the same issue and found a fairly affordable solution.
    Tripleconpanna likes this.
  4. Jun 11, 2023 at 6:56 AM
    YoungManTan
    YoungManTan New Member
    San Diego
    2008 Desert Sand Tundra 5.7 Crew Cab 7Ft bed
    Billstien 5100 in front, .5” spacers, serviceable drive shaft u-joints, 18” Vision Nemesis Wheels, Kenwood touchscreen head unit
    There’s a newer thread on here I just skimmed through talking about the same problem and the issue being “solenoid D”
    let me go find it…
    EDIT: I realized OP had commented in the other thread already lol
    Tripleconpanna and 2mchfun like this.
  5. Jun 11, 2023 at 7:00 AM
    coTony
    Tony
    Montrose, CO
    I would check the shift solenoids. I had this problem in a LandCruiser and while I was in there I swapped out all of the solenoids because I figured if one is going the other s may not be far behind. My problem was never seen again for over 10 years when I sold it
    NewImprovedRon likes this.
  6. Jun 11, 2023 at 8:58 AM
    AZBoatHauler
    So.Arizona
    Mind sharing pics of the LC if you have any? 80 series?
  7. Jun 11, 2023 at 10:36 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I've had that problem on my matrix, your tranny fluid level is off I would bet.
    VWTim likes this.
  8. Jun 12, 2023 at 4:41 AM
    coTony
    Tony
    Montrose, CO
    Here is one I found, I have tons of pics but sold it 5 years ago
  9. Sep 3, 2023 at 4:25 AM
    Retired...finally
    I had something similar happen after my 21 sat for 10 days. Start and within a second put it in drive. Truck didn't pull as strong when I released the brake. Moved but I could tell it wasn't the same. Applied thr brakes, went back to park and right back to drive and all was fine. This was the first time the truck sat more than three days without being driven.
  10. Jun 22, 2024 at 4:02 PM
    Cesarion23
    Cesarion23 New Member
    2013 black tundra 2wd
    Did you fix the issue?
