No air coming from vents after drink spilled into defrost vent
Discussion in '2.5 Gen Tundras (2014-2021)' started by sdf1tbf, May 20, 2023.
  1. May 20, 2023 at 5:20 PM
    sdf1tbf
    sdf1tbf [OP] New Member
    terry
    2020 tundra
    none
    A drink was spilled on top of my dash board. Got down into the defrost vent. Now none of the vents will operate. I'm guessing the blend door actuator? It's a 2020 Toyota Tundra. I've not been able to find any videos on how to change the vent door actuator. Can anyone point me in the right direction?
  2. May 20, 2023 at 6:43 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Was it a sugary drink like pop (or do you call it soda?) or juice? If yes, I suspect that the air door(s) may be jammed up from the stickiness on them and their weatherstripping. The actuators are positioned on the outside of the HVAC box and I have a hard time thinking that they’d have been swamped themselves.
    If that’s the case though, that leaves the question of what to do about it. I’m having a hard time with the idea of suggesting that you spray warm water down the defrost vent of your ‘20 with a garden sprayer and let it all drain out the evaporator drain tube. :eek2:
    ColoradoTJ likes this.
  3. May 20, 2023 at 7:07 PM
    sdf1tbf
    terry
    2020 tundra
    none
    It was a darn 16 ounce Carmel iced coffee. My wife had just bought it. I would say very sticky. Im thinking about spraying some electronic cleaner.
  4. May 20, 2023 at 7:31 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I’d be concerned with what the electronic cleaner would do to the plastic parts, and the glue on the air door weatherstripping. Unless you’re thinking of something different than I am.
  5. May 20, 2023 at 7:35 PM
    sdf1tbf
    terry
    2020 tundra
    none
    I agree, just not sure what to do. maybe I just need to bite the bullet and take it to a shop.
  6. May 20, 2023 at 7:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Can you hear anything when switching between different modes, defrost, heat, etc.?
  7. May 20, 2023 at 7:41 PM
    sdf1tbf
    terry
    2020 tundra
    none
    I can't. I have all of the dash off the passenger side so I had decent access. It actually takes the fan about 30 seconds to come on after I turn the knob on.
  8. May 20, 2023 at 7:51 PM
    TILLY
    Massachusetts
    There were some members here who had some funky stuff happen when water got down the same area having their windshield tinted. I wonder if you could be having the same problem.
  9. May 20, 2023 at 8:24 PM
    sdf1tbf
    terry
    2020 tundra
    none
    Could be, I've done no window tinting but I guess the same difference with a caramel coffee going in. I'm just not sure where to look. When I turn the fan switch on I can hear it cycling and it takes about 30 seconds for the fan to kick on. When it does kick on no air comes out of any vents.
  10. May 20, 2023 at 8:32 PM
    TILLY
    Massachusetts
    Let me search to see if I can find the thread, maybe others who remember can chime in as well.
  11. May 20, 2023 at 8:33 PM
    sdf1tbf
    terry
    2020 tundra
    none
    I really appreciate any help.
  12. May 20, 2023 at 8:42 PM
    TILLY
    Massachusetts
    Found the thread, it was a no start problem after getting fluid in the same area. Back to square one.
  13. May 20, 2023 at 8:43 PM
    sdf1tbf
    terry
    2020 tundra
    none
    Thanks
  14. May 20, 2023 at 8:44 PM
    TILLY
    Massachusetts
    Not giving up yet, hang in there, we can figure this out.
  15. May 20, 2023 at 8:47 PM
    sdf1tbf
    terry
    2020 tundra
    none
    I'm going to disassemble the drivers side tomorrow and listen to the mechanism. I'll see if there is anything I can see.
    thanks
    TILLY likes this.
  16. May 20, 2023 at 8:47 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Did you notice if the coffee came out anywhere? On the floor? The ground? Could it still be pooled up in the ducting somewhere?
  17. May 20, 2023 at 8:53 PM
    sdf1tbf
    terry
    2020 tundra
    none
    I did not see anything coming out of any vent. But it was a mess. Picture that 16 ounces of Carmel coffee running over the dash from the defrost vents to the floor and everywhere on the dash between. We were going to see our newly born granddaughter, my wife set it on their dash to gather other stuff and it got knocked over. I knew some when down the defrost, a couple days later the vents would not work. but their truck has a nice Carmel smell.
  18. May 20, 2023 at 9:04 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Well, it's about 3 hrs past my bedtime and I'm not sure why I'm still up, so take anything I say with a grain of salt.
    I was thinking there's some diverter flaps stuck closed and if you knew that it would drain out somewhere, possibly try pouring small amounts of hot water down the vent to flush it out some. But that's probably not a good idea.
    My first move would likely be finding a parts diagram of how the dash and duct work are laid out, then start planning for pulling it all apart and cleaning it. Without the air moving, that coffee might be food for mold.
  19. May 20, 2023 at 9:12 PM
    sdf1tbf
    terry
    2020 tundra
    none
    we can get back to it tomorrow. past time for some sleep
  20. May 20, 2023 at 10:04 PM
    Sounds like he may need a plumber...and this is the only plumber crack I wanna see.
    This could turn into a dash removal and some serious cleaning of the HVAC system.
  21. May 21, 2023 at 5:49 PM
    TILLY
    Massachusetts
    Any luck?
