Ceramic coated my tundra
Discussion in 'Detailing' started by Ginsterkev, May 21, 2023.
  1. May 21, 2023 at 12:17 PM
    Ginsterkev
    Ginsterkev [OP] Lessons not learned in blood are soon forgotten
    Kevin
    Pennsylvania
    2019 tundra Trd pro supercharged
    Tvs1900 magnuson blower Team rxp catch can Wescott designs collar lift on fox factory suspension Front and rear TRD sway bars
    Well just finished my first ever coating, took me around 8 hours and my paint was perfect and all the prep work has been done so just the coating itself was an all day thing for me, I took my time and was in no hurry, I used gtechniq csl and I topped it with gtechniq exo v5 I did all the glass and trim, headlights down to the mud flaps and I am very very impressed by this I was never a huge believer in this stuff but I am now and I would absolutely never pay to have this done it was very easy and I'll even say it's easier then waxing just take your time and make sure all the paint and prep is perfect and you will be fine
    Ace96, Tundra Dude 45, sask3m and 3 others like this.
  2. May 21, 2023 at 1:47 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Can you mind sharing your process and what pads you used.
    Thanks in advance!
  3. May 21, 2023 at 2:16 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Sure, so basically I washed it and then used iron buster from p&s, followed that with clay bar mitt the light version and just did a single stage polish wich is all I needed, no compound necessary as my paint was in great shape as far as pads go I use my dewalt buffer with a 3m polish pad and the 3m polish I am an auto painter by trade so it is the same stuff we use at work on fresh paint after wet sanding dirt nibs so I didn't feel the need to go buy one of those buffers for paint correction as I have one that works really good, if I did it for a living I would prolly reconsider . So basically after all of that I started my coating wich basically involved me splitting each panel into two sections working the applicator in two different directions to make sure I missed nothing, let it flash to wear it looks like it's beading up and wipe with your first towel and follow with second making sure to level everything and not to leave any excess I did that for the glass and all the trim. Once that was done I pretty much already was over the 2 hour time to start applying the exo v5 wich is put on the exact same way but is an even more hydrophobic ceramic then the CSL and by adding both you pretty much just got yourself a 5year ceramic coating or more depending on how you care for a vehical .... just as a note I did change my towels often going through about 8-10 total towels and 2 different applicators, I forgot to add that before I started the coating I wiped the whole truck down with gtechniq panel wipe wich is like an ipa wipe with alcohol, pretty much gets the panel ready for the ceramic to bond the right way, I'm new at doing this but I'm a crazy person when it comes to the cleanliness of my vehicals so I def wanted to tackle this myself and see what it was all about, and I will say it was def worth my time and to save possible 15-2000 dollars doing it myself is even better
  4. May 21, 2023 at 3:53 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Here are the pics not that you can really see anything as far as the coating goes but I'm proud of it
  5. May 21, 2023 at 4:02 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Looks great! Going to tackle mine this weekend I think; not looking forward to all the work but it'll be worth it. Did you do the wheels too? My yellow ebc breaks coat my wheels within a week with an insane amount of break dust.
    Ginsterkev[OP] likes this.
  6. May 21, 2023 at 4:06 PM
    PermaFrostTRD
    Northern NY
    Man. That coating and finish look so good it’s like you have a one of a kind blue.
    Tripleconpanna likes this.
  7. May 21, 2023 at 4:07 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Yes literally just finished the wheels 5 min ago with the product I had left so hopefully it will help
  8. May 21, 2023 at 4:09 PM
    Ginsterkev
    Kevin
    Pennsylvania
    You no it's kind of crazy that it now looks like a different shade of voodoo kinda like it got a little darker, my other car in the garage is a Lexus GsF and I bought that already ceramic coated and I swear when ever I see ultra sonic blue on any other Lexus it does not look the same either, who knows maybe this ceramic stuff does tint it down a touch idk !
    PermaFrostTRD[QUOTED] likes this.
  9. May 21, 2023 at 4:22 PM
    briarpatch
    briarpatch New Member
    Very nice work. With the newer versions of ceramic coatings, there's really no reason not to do it yourself.
  10. May 21, 2023 at 4:27 PM
    Ginsterkev
    Kevin
    Pennsylvania
  11. May 25, 2023 at 7:21 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Wow that looks fantastic. A lot of work to get it looking like that though. Great job.
  12. May 25, 2023 at 7:40 AM
    Vuducrumax
    Vuducrumax New Member
    I've noticed my voodoo paint looked much darker with a coat of meguairs ultimate but I just tried griots 3-1 ceramic and noticed no change in shade. Awsome color regardless.
  13. May 27, 2023 at 8:03 AM
    EddieBolt
    EddieBolt New Member
    2020 CM SR5 4x4
    That's pretty impressive results. I'm looking to do this to my voodoo blue, what was the overall cost with the gtechniq products?
  14. May 27, 2023 at 10:45 AM
    briarpatch
    CSL/EXO combo pack...both 30ml...121.95....50 ml combo pack...187.95
  15. May 27, 2023 at 11:33 AM
    Ginsterkev
    Kevin
    Pennsylvania
    Yup that was what I paid actually ... user friendly as well I mean seriously awesome stuff , but this was my first time so I have nothing to compare it to, but I will be using this on my wife's vehicle soon
  16. May 27, 2023 at 1:08 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Thank you !
  17. May 27, 2023 at 1:10 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Got the 50ml and that got me the entire truck including glass, all trim, door handles, headlight lights, taillights and wheels, still have enough left to maybe get the jambs done
    dondino likes this.
  18. May 27, 2023 at 1:43 PM
    hiimbrando
    hiimbrando Chop shop owner / Degenerate car part buyer.
    Brandon
    Dallas, Texas
    Any more pics of the GSF lol
  19. May 27, 2023 at 2:08 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Sure, I don't actually have to many but here are a couple
    DannyD303, RobertD, dondino and 4 others like this.
  20. May 27, 2023 at 2:24 PM
    JRS
    JRS New Member
    2012 DCLB
    Forget about the coating and let's praise what needs praising - that Voorhees hitch cover.
    Toyotoholic and Ginsterkev[OP] like this.
  21. May 27, 2023 at 2:27 PM
    Ginsterkev
    Kevin
    Pennsylvania
    Ha ha I thought I was the only one who likes that stuff lol ...
  22. May 27, 2023 at 2:39 PM
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    OP...
    You do Blue very well.
    That's the best I've seen Voodoo look!.
    Great write up too.
    Minor thing: "wich" in you context would be spelled "which" sounds the same, but totally different words.
    Wich is a bundle of thread, or a settlement.
  23. May 27, 2023 at 2:42 PM
    Ginsterkev
    Kevin
    Pennsylvania
    I do blue well, I do proper spelling oh so bad lol ... I'm working on it one of my many many faults I'm trying to fix
    RobertD and Toyotoholic like this.
  24. May 27, 2023 at 4:51 PM
    EddieBolt
    2020 CM SR5 4x4
    Thank you! That’s not bad at all !
  25. Jun 17, 2023 at 8:18 AM
    Boxerdog
    Boxerdog New Member
    Looks good…don’t see that blue often
