Stealth Custom SR8 & Nitto Ridge Grappler set up for 17 TRD Pro
Discussion in 'Wheels & Tires' started by like the fish, Aug 12, 2017.
  1. Aug 12, 2017 at 6:02 PM
    like the fish
    like the fish [OP] New Member
    4runner, tacoma, now tundra
    Since other forum members posted their experiences with wheel and tire upgrades, I'll add to the collective.
    Based on other posts, I upgraded my tires to 295/70R18 Nitto Ridge Grapplers, but not without issue. Some folks had rubbing and some did not. I fall into the rubbing camp. These tires rubbed on the front and rear portions of the front wheel well, so I ended up removing both the small front mud flap and rear mud flap on the fronts and used a heat gun to push back some of the plastic wheel well.
    So before the questions flood in, here are the specifics...
    Stock suspension, no spacers, no shackles, no shims, no blocks, no new upper controls arms, etc. Stock TRD Pro suspension.
    SCS SR8 18X9 wheels in dark bronze (offset +25 vs OEM TRD Pro wheels +60) Thanks Vin.
    McGard spline drive cone seat lug nuts, since OEM mag shank, flat seat lugs do not work.
    Since :worthless:see before and after pics below
    Before: suspension clearance with OEM Michelin 275/65R18 tires
    Before: top down view of clearance
    After: suspension clearance with new 295s
    After:
    Now for the problems and solutions...
    Tire touches the large mud flap in the front at full lock
    Tire touches the front of the wheel well where the small mud flap was installed (already removed for this picture.
    Solution part I: front tire mud flaps removed.
    Solution II: heat gun this edge of the plastic wheel well cover and push back towards the front bumper.
    Now we clear.
    Finished product...
    Thanks for the help Tundras.com
  2. Aug 12, 2017 at 6:11 PM
    like the fish
    I forgot to show the overhang .
  3. Aug 12, 2017 at 6:15 PM
    PMG
    PMG New Member
    Am I the only one who can't see the pics on the first post?
  4. Aug 12, 2017 at 6:42 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Good pics David. Pics are always a persons friend especially when words get lost in translation. ( and yes I did understand your words ) I think the truck looks great :thumbsup:. Nice job all the way around !!!!
  5. Aug 12, 2017 at 6:56 PM
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Looks great but do you think you will add coach builder shims up front in the future? Or do you like the stance?
  6. Aug 12, 2017 at 7:30 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Looks great.
  7. Aug 12, 2017 at 9:12 PM
    TheBeast
    TheBeast The Beach
    did you cycle the suspension to the max to see if you are still not rubbing ?
  8. Aug 13, 2017 at 4:30 PM
    like the fish
    TheBeast, I did not cycle anything. I did not make any adjustments to the suspension, only the removal of mud flaps and reshaping of plastic wheel well.
    nowayout, I do not have plans to change the factory trd pro suspension.
  9. Aug 13, 2017 at 10:23 PM
    theboy12
    theboy12 New Member
    Jon
    2013 Sequoia
    Cab mount chop...... if your worried about it. Or drive it like you stole it an burn some of the rubber off.
    2 cents,
    -Jon
  10. Aug 14, 2017 at 3:22 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I had no rubbing issues either on a flat level service, but when I turned to full lock backing down a hill it sounded like my truck was going to come apart.
  11. Aug 16, 2017 at 8:07 PM
    xoni
    xoni New Member
    Gordon
    2017 Cement Tundra TRD Pro
    When you come crashing down hard you'll know what to trim next.
    xoni
  12. Aug 17, 2017 at 1:14 AM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
    Looking good David!! Thanks for sharing:thumbsup:
  13. Dec 6, 2017 at 3:01 AM
    Toyota10s
    Toyota10s New Member
    Chace
    West Coast
    2017 Toyota Crewmax limited Tundra
    Bone stock.
    If @StealthCustom had those in all black, those might be the ones!! :)
  14. Dec 11, 2017 at 4:43 PM
    scs_vuth
    scs_vuth New Member
    Vuth
    Bay Area
    Check our website for availability.
    Vuth
  15. Dec 11, 2017 at 5:06 PM
  16. Jan 3, 2018 at 2:24 PM
    andymai
    andymai New Member
    Nice truck
