Toyota tundra transmission
Discussion in '1st Gen Tundras (2000-2006)' started by Outsider1, May 20, 2023.
  1. May 20, 2023 at 12:03 AM
    Outsider1
    Outsider1 [OP] New Member
    Hello I replaced my 3.4 2003 toyota tundra transmission. The transmission is making a grinding scraping noise near the torque converter. The torque converter bolts were torque to 30 ft lbs. Anyone know what could be the cause. Transmission fluid has been filled
  2. May 20, 2023 at 2:00 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Does the noise happen in all gears? P,r,n,d,2,1?
    Stopped and moving? Idle and under load?
  3. May 20, 2023 at 6:00 AM
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
  4. May 20, 2023 at 7:18 AM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    Improper grammar so idk
  5. May 20, 2023 at 7:50 AM
  6. May 20, 2023 at 8:00 AM
    Mr Badwrench
    Mr Badwrench New Member
    Can you capture an audio clip?
  7. May 20, 2023 at 8:22 AM
    Bots have perfect grammar?
  8. May 20, 2023 at 12:48 PM
    Outsider1
    The Noise only occurs when in D,R
    Not in Neutral or Park
  9. May 20, 2023 at 12:59 PM
    Outsider1
    The flex plate looked fine
  10. May 20, 2023 at 1:15 PM
    Outsider1
    This is the noise it’s making
  11. May 20, 2023 at 1:38 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Jack McCarthy and bmf4069 like this.
  12. May 20, 2023 at 2:38 PM
    Outsider1
    Sorry it’s not letting me upload the video
  13. May 20, 2023 at 2:38 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Can you see see anything shiny where things might be rubbing?
  14. May 20, 2023 at 2:57 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    What format are you using to upload the Vid?
  15. May 20, 2023 at 3:30 PM
    Outsider1
    So the scratching noise was coming from the tail which was slight bent and coming from the shaft but. I have the car lifted and now when I accelerate in Drive or reverse it doesn’t make any noise but when I press the break it makes the noise coming from the bell housing. The video format I’m using is from my phone. I have an iphone
  16. May 20, 2023 at 3:32 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    You have to upload your video to YouTube (or Facebook, or Vimeo) then link it here
  17. May 20, 2023 at 3:41 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
  18. May 22, 2023 at 10:24 PM
    Outsider1
    So I dropped the transmission and changed out the torque converter with one of a Toyota tacoma with the same 3.4 engine. The noise went completely away however now it’s not shifting right when going in first and second gear. I’m assuming the car that went to the Yard was due to a bad transmission. I think the torque converter must have been damaged and they kept driving and it damage the first and second gear of the transmission. Would changing the torque converter with the tacoma one cause any shifting issues. It fit perfectly, same bolts and everything. The last question is I’m gonna have to get my money back, has a year warrant but I found an 04 transmission v6 2wd. They said it not the right transmission part for an 03. Are 03 and 04 v6 2wd a direct swap??
