Low mileage maintenance
Discussion in '2.5 Gen Tundras (2014-2021)' started by PeteBozz, May 12, 2023.
  1. May 12, 2023 at 6:40 PM
    PeteBozz
    PeteBozz [OP] New Member
    2018 sr5 Trd offroad
    Hi all, I have a 2018 tundra I bought with just under 10k miles back in 2019. Since then I have only put on about 16k miles for a total of about 26k miles. I usually have just done 1 oil change a year with mobil 1 extended performance and matching oil filter. As I'm coming up on the 30k mile mark and it's been 5 years I'm not sure if I should do fluid changes (drain and fill) for my transmission, coolant, diff and transfer case. Was also thinking about changing spark plugs as well. My tires also are gonna need replacing soon too. Should my fluids be ok or should I just replace them? I know 30k miles is a big milestone according to Toyota maintenance plan
  2. May 12, 2023 at 6:42 PM
    AZBoatHauler
    So.Arizona
    I’m with you on the tires. I’d let the fluids go another few years with that low of mileage.
  3. May 13, 2023 at 8:27 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Brake fluid….
  4. May 15, 2023 at 6:25 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    What type of driving are you doing when you do drive it? Do you only use it to tow? highway trips once a week? Short stop and go trips?
    I think these are some things that will help determine some of the fluids.
  5. May 15, 2023 at 6:46 AM
    Chip_Tundra
    Chip_Tundra New Member
    The stuff I do on a time interval is brake fluid and coolant. Brake fluid every 2 to 3 years. Coolant every 3 to 5 years. Edit: I do power steering flushes every 2 years as well.
    Engine oil, transmission fluid and gear oils are what you're comfortable with being consistent at.
    For engine oil I do every 5K or 6 months, for Gear oil I do every 30K, and for transmission oil, I'll do every 25K miles. That's just me.
    V3N0M likes this.
  6. May 15, 2023 at 6:48 AM
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    If you want to keep it 10+ years: Brake Fluid, diffs, transfer case, power steering (turkey baster method). You'll be surprised what the rear diff fluid looks like, I bet it's pretty dark and 'glittery'. My transfer case is a lot smoother with Redline MTV than with whatever Toyota or the company that made the transfer case put in. Toyota makes great vehicles no doubt but I think they use the minimum specs on their fluids, nothing great, a cost saver for sure.
    All easy stuff to do and by doing it yourself you can put top-shelf synthetic fluids and still save a pile over a mechanic.
  7. May 15, 2023 at 9:26 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Oil degrades and their additives degrade over time as soon as you open the bottle, same for all the fluids in your vehicle. Follow the time recommendation in your manual if you don't hit the mileage. Like your engine oil, you should change it twice a year if you don't hit the mileage intervals.
  8. May 15, 2023 at 1:21 PM
    PeteBozz
    Thanks everyone for the suggestions. Most of my driving is just short trips no longer than 20 minutes in town. I used to work 5 minutes from home so I did that for 2 years. I have hauled some 800 pound loads to the dump here and there. The only thing I have replaced is the battery. I think I'm just going to do drain and fill everything to be less paranoid.
    Jaypown likes this.
  9. May 18, 2023 at 9:25 PM
    PeteBozz
    Ok so I just noticed this but my coolant temp gauge is slightly above the halfway mark. I could have sworn it was always at half before. I noticed this before I drained and filled with new coolant but it's still at the same spot after the drain and fill. I drove it around town and hit the highway for about 25 minutes and the temp gauge stayed at the same spot. It's not like 3/4 of the way up and it's not spiking or anything just slightly above halfway.
  10. May 19, 2023 at 6:16 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Weird. Your oil pressure and voltage are a bit high too. I'm usually showing a bit under half for oil pressure once warmed up and at speed. I've never seen more than 14 volts.
    Then, of course, who ever has a full tank??!!
    Might be worthwhile to get an OBDII reader to see what your actual coolant temp is. I'm usually around 185-195F and just under half on the gauge. If your motor is that hot, i would figure that fan would be howling unless you have an air pocket in the system.
    PeteBozz[OP] likes this.
  11. May 19, 2023 at 6:49 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Did you burp your coolant after the service? Air pockets will cause low flow and you will run hot
    Mike59 likes this.
  12. May 19, 2023 at 9:50 AM
    PeteBozz
    I burped it for like 45 minutes with the heat on max and the radiator fans were definitely going. Squeezed both radiator hoses after revving it up to 3k rpm for 10 seconds every couple minutes. It was at this level before I did the drain and fill too so I'm not sure what it could be. The a/c and heat work fine too.
  13. May 19, 2023 at 12:12 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I feel like this may be a dumb question but does it start at the bottom when the engine is completely cold?
  14. May 19, 2023 at 12:15 PM
    PeteBozz
    Yes it starts at the bottom and goes up as the engine gets to operating temps. It gets to a little past half and stays there once it gets up to temp.
  15. May 19, 2023 at 1:17 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Gotcha. Just ruling it out that it was a faulty gauge.
