Toytec boss
Discussion in 'Suspension' started by Tundra_mike89, Aug 12, 2017.
  1. Aug 12, 2017 at 2:21 PM
    Tundra_mike89
    Tundra_mike89 [OP] New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    Just got the toytec boss front coilovers with the toytec long travel rear shocks, and shackles at top setting. Just ordered nitto tires 295/70/18 and method standard rims 18x9 +18 mm offset. Will be here Wednesday
    Ride is awesome!! I highly reccomend these coilovers
  2. Aug 12, 2017 at 2:26 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Nice. Would you say it's day/night difference from the stock on the streets? More comfy ride?
  3. Aug 12, 2017 at 2:27 PM
    be77solo
    be77solo New Member
    2017 Silver Crewmax 4x4 5.7L
    KO2's on ENKEI ST6's, BakFlip MX4
    That looks fantastic! How much lift did that give you? Got the same truck, curious about suspension options. Can you tell much difference in ride over stock?
  4. Aug 12, 2017 at 2:37 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I haven't measured but the ride is MUCH better over stock. I was a bit skeptical when I read other people's post when they bragged about how much better the ride is with the boss kit. But now I know what they are talking about. It's definitely much smoother going over bumps. The UCA's are a little louder but not crazy loud where it's a nuisance. I'll measure when I get back home and let y'all know.
  5. Aug 12, 2017 at 2:44 PM
  6. Aug 12, 2017 at 5:12 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Ok I'm home and I measured. My mechanic did NOT make any adjustments to the coilovers this is how they came. And my rear shackles are at top setting. Before the lift my front end sat exactly at 22". Now I'm at 25.50". I didn't measure the rear before the lift but now I'm at 26". So .50" of rake. Here are pictures
    (Measurements are from center of hub)
  7. Aug 12, 2017 at 5:15 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    And I promise I do not work for toytec or I did not receive anything free. I paid 2 grand just for parts. Had I done it again I would have ordered the SPC uca's. But I went balls deep in my wallet. F it. If you don't wanna spend 3 or 4 g's on fox or icon I would not hesitate to get these.
    MotoTundra, Toytec Lifts and Law323 like this.
  8. Aug 12, 2017 at 5:40 PM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Looks great!!!
  9. Aug 12, 2017 at 7:33 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    @ToyTec Lifts or anyone else,
    Will I mess anything up if I drive my truck without carrier bearing spacer? I ordered one but it won't be in for another week. And I'm expierencing light vibration when I accelerate from a stop.
  10. Aug 12, 2017 at 8:02 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Looks great! And no, you won't mess anything up. I went 6 months with a 3" spacer lift without a CB drop and 2 months with my BOSS kit set at the preset height of 3". You'll be fine and it's such an easy install. Just crawl under and keep the driveline steady with some jack stands, remove bolts, install CB drop, put bolts back on and drive on!
    I put some loctite blue (the non permanent one) just as a precaution.
  11. Aug 12, 2017 at 8:28 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    Nice. Been thinking of doing this for now before I can afford my wheels and tires. Looks good!
    Law323 likes this.
  12. Aug 12, 2017 at 8:34 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looks good! Good choice on UCAs too! If you're gonna spend the money might as well go with uniballs. A little more maintenance but totally worth it!
    Law323 likes this.
  13. Aug 17, 2017 at 8:56 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Put some new shoes on her
    Halfjap, TheBeast, monaco730 and 4 others like this.
  14. Aug 17, 2017 at 9:02 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Looks great!!!!!!
  15. Aug 17, 2017 at 9:04 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Thanks. Got the bro lean going with those old steel rims and tires in the bed lol
    TheBeast and MotoTundra like this.
  16. Aug 17, 2017 at 10:47 AM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    Truck looks good, I've been debating about the toytec boss kit or bilstien setup, what part of Texas are you from.
  17. Aug 17, 2017 at 10:52 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I would honestly go toytec. I've driven both and prefer the toytec. Absorbs bumps better it feels like. And I don't work for toytec and they don't give me anything for free. Just my honest opinion
  18. Aug 17, 2017 at 11:37 AM
    CaptObvious
    CaptObvious New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    what wheel/tire setup did you go with?
  19. Aug 17, 2017 at 11:42 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    I went with method nv 18x9 with +25mm offset. Tires I went with the nitto ridge grapplers 295/70/18. Minor running but I think an alignment will fix that issue. As far as road noise, there is none. For as aggressive as this tire is I figured there would be some. But there is no change from the stock Michelin that came with the truck.
    CaptObvious[QUOTED] likes this.
  20. Aug 17, 2017 at 11:46 AM
    TheBeast
    TheBeast The Beach
    nothing wrong with that..lol
    great looking truck. lift + tires really make it pop
  21. Aug 17, 2017 at 11:48 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Thanks. The only downside to leveling out a truck is having that bro lean when u haul/tow something. But I hear the ladies like the bro lean?
    TheBeast[QUOTED] likes this.
  22. Aug 17, 2017 at 11:49 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    thought the method standards came with a 18 offset?
  23. Aug 17, 2017 at 11:51 AM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Method standard do come in +18 offset. I went with the method NV which come in 18 or 25. I chose +25
  24. Aug 17, 2017 at 11:53 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    ahhhh thought you went with standards, didn't realize you got the NV's.
    looks good brother!
  25. Aug 17, 2017 at 12:04 PM
    TheBeast
    TheBeast The Beach
    they like it around here..LOL
  26. Aug 17, 2017 at 12:14 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hell yea, looks awesome!!
    Tundra_mike89[OP] likes this.
