GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. May 16, 2023 at 1:00 PM
    #3091
    Nomoredomestics
    Nomoredomestics New Member
    GA
    2023 TRD Sport 4x4
    Nice looking truck! What leveling kit did you end up going with and did it change the ride? Got any shots down the side?
  2. May 16, 2023 at 1:24 PM
    #3092
    Kspegar
    Kspegar New Member
    Kalei
    Bigisland, Hawaii
    2023 Tundra Platinum
    Anyone running 295/64/20?
  3. May 17, 2023 at 10:14 AM
    #3093
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    Method 707 17x8.5 +25 Beadgrips going in soon with some 37/12.5/17 wildpeaks. Wasn’t aware but method ships these with hub centric rings.
    mayan, PBNB and ARCOVT23 like this.
  4. May 17, 2023 at 10:34 AM
    #3094
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    Are the hub rings from 106 to 78?
  5. May 17, 2023 at 10:36 AM
    #3095
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    looks like it...see the markings 106.25-78.3mm
  6. May 17, 2023 at 10:39 AM
    #3096
    iiawah808
    Oahu, HI
    Then these won’t work correct?
    I got mime from Amazon that another member here posted a link too. Hub rings along with my et lugs for assurance.
  7. May 17, 2023 at 10:52 AM
    #3097
    jgoliath
    So they are tapered and I’d assume it’s saying it works for a hub range of 78mm to 106mm. I don’t know enough about them to say more than that.
    EDIT: it’s not a hub range so disregard that. It is indeed for a 78mm hub. Thanks method?
    Yaboy and iiawah808[QUOTED] like this.
  8. May 17, 2023 at 11:11 AM
    #3098
    eddiefromcali
    Eddie
    100% Stock
    I dont know the hub bore size on these trucks, cant comment on that
    edit: Looks like gen3 has a 95.1mm hub. Those rings wont work
    jgoliath and iiawah808[QUOTED] like this.
  9. May 17, 2023 at 11:16 AM
    #3099
    eddiefromcali
    Eddie
    100% Stock
    jgoliath[QUOTED] and iiawah808 like this.
  10. May 17, 2023 at 11:38 AM
    #3100
    jgoliath
    per methods tech support. We don’t need the rings since the wheel is more lug centric but only if you use their extended lugs. I’ll getting the rings linked above just to be safe.
  11. May 17, 2023 at 11:49 AM
    #3101
    farpolemiddle
    farpolemiddle New Member
    I used them. Cheap insurance.
    iiawah808 likes this.
  12. May 17, 2023 at 2:09 PM
    #3102
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
    I’m assuming those will only work with Method Wheels? Was looking for some for Fuel Rebel 6
  13. May 17, 2023 at 3:35 PM
    #3103
    eddiefromcali
    Eddie
    100% Stock
    Works on any wheel with that size hub bore
  14. May 17, 2023 at 5:04 PM
    #3104
    WrapCO
    WrapCO New Member
    Eagle , CO
    2022 Toyota Tundra 6.5’ CM
    Westcott lift, Method 316 17” wheels, 35x12.5x17 Toyo Open Country AT3
    I’m pretty jealous :(
  15. May 17, 2023 at 5:43 PM
    #3105
    TexasTundraDan
    TexasTundraDan New Member
    2023 Tundra Platinum Hybrid
    295/60/20 will fit. Have them on my stock suspension no lift or level. No rub at all. Sits nice
    22platitundy likes this.
  16. May 17, 2023 at 7:26 PM
    #3106
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think the 78mm hub bore is for a GMC 1/2 ton!
  17. May 18, 2023 at 8:35 AM
    #3107
    RustyBRV
    RustyBRV New Member
    I'm planning to hyperdip my black TRD wheels to a bronze color, and want to cover the lug nuts and not dip that part. What size are the lug nuts if I bought lug nut covers?
  18. May 18, 2023 at 1:48 PM
    #3108
    Jinkx
    Jinkx New Member
    Keith
    Nothing really. It’s why I like 18s. Best of both worlds. More sidewall will def be smoother riding and I guess the bigger wheel guys can say better handling.
    To answer your question it’s all about looks when it comes down to it and what you like..Makes it fun picking. It’s personnel preference.
    Off roaders will usually always pick more tire size. Street trucks tend to pick more rim size…
    Did I mention I like 18s
    best of both worlds LOL
  19. May 18, 2023 at 3:23 PM
    #3109
    Kepaniamekolea
    Kepaniamekolea New Member
    Kendall
    Kailua-Kona, HI
    2022 WCP 1794 TRD Off-Road
    Looks cherry! What lift are you running?
  20. May 18, 2023 at 4:40 PM
    #3110
    Jinkx
    Jinkx New Member
    Keith
    Thank you
    ReadyLift SST kit
    3 front 1.25 Rear
    Kepaniamekolea likes this.
  21. May 18, 2023 at 9:04 PM
    #3111
    nodak67
    nodak67 New Member
    JR
    you want more sidewall for flex in off road conditions (contact patch can grab more traction on irregular terrain)
    less side wall flex for better handling in pavement conditions (bigger flat contact patch enable better accel, cornering, decel)
    nhra drag slicks dont count in this discusssion :) cause it throws both of those statements out the window
  22. May 19, 2023 at 9:57 AM
    #3112
    mskertchly
    mskertchly New Member
    Mario
    DFW TX
    2024 Tundra SR5 4x4 TRD
    Hi Everyone. I am switching my wheels from the stock 20" wheels to the TRD PRO 18" wheels. Anyone has a good recommendations for what tires to buy? I'm looking for comfort, durability and upsizing on the width. Thanks in advance
  23. May 19, 2023 at 11:19 AM
    #3113
    Jinkx
    Jinkx New Member
    Keith
    295/70/18
    Yes they fit with stock wheels. I’ve seen 3 trucks do this and they all looked soooo much better!
    U lose about 2 mpg
    Yaboy likes this.
  24. May 19, 2023 at 11:20 AM
    #3114
    Jinkx
    Jinkx New Member
    Keith
    We’ll changed the flares
    Haven’t decided if I like it yet lol
    Not pulling them off so I’ll wrap them flat black if I decide I don’t
    Def looks cleaner but my 3 inch lift looks smaller now lol.
    Decisions decisions
    ARCOVT23 and DMackler like this.
  25. May 19, 2023 at 11:34 AM
    #3115
    Breathing Borla
    Northern Illinois
    looks a lot nicer to me, it would really set it off and match the stash too
  26. May 19, 2023 at 11:40 AM
    #3116
    Talltugger
    Talltugger New Member
    Captain
    E WA or Pacific Ocean.
    23’ Platinum-MGM-6.5’
    Icon-35/12.5 Toyo AT3-Spidertrax 1” spacers. Rides better than stock, MPG SUCKS. D639441A-5D71-41F8-8CF6-328B2140BE47.jpg815C959F-974A-4A70-BF09-4F38F19538B1.jpg 96942FB0-5A92-4A41-86C1-C2BAF1E6DD50.jpg
    =JSG=, Jsmittyy, Yaboy and 2 others like this.
  27. May 19, 2023 at 11:51 AM
    #3117
    Jinkx
    Jinkx New Member
    Keith
    Good your helping me decide Borla lol thank you!!!
    Very nice TallTugger
    Breathing Borla and Talltugger like this.
  28. May 19, 2023 at 1:34 PM
    #3118
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    anyone run these?
  29. May 19, 2023 at 3:20 PM
    #3119
    eddiefromcali
    Eddie
    100% Stock
    looks way cleaner...keep them. Waiting on my painted set to come in. Not a fan of the Platinum combo with glossy black flares
  30. May 19, 2023 at 3:48 PM
    #3120
    ARCOVT23
    ARCOVT23 New Member
    Vermont
    2023 Tundra SR5
    TRD Lift, TRD skid.
    I like the white flares.
    What did that cost?
