Hail/Storm Protection Covers
Discussion in '3rd Gen Tundras (2022+)' started by WesternDawg, May 18, 2023.
  1. May 18, 2023 at 5:43 AM
    WesternDawg
    WesternDawg [OP] New Member
    2024 Ice Cap Tundra TRD Pro
    Hey, new member here. I’m likely going to be purchasing a ‘23 TRD Pro in the next month or so. Only issue is that my garage is too small to fit a truck, and here in CO we get some gnarly hail storms time to time. Does anyone have any hail protection covers or anything similar they recommend I take a peak at?
  2. May 18, 2023 at 7:32 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I can't help with the cover but welcome to the forum.:thumbsup:
    WesternDawg[OP] likes this.
  3. May 18, 2023 at 7:35 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  4. May 18, 2023 at 7:36 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Wrap it in bubble wrap. Or get a car port
  5. May 18, 2023 at 9:38 AM
    nodak67
    nodak67 New Member
    JR
    i like how they dont even come close to an actual hail storm impact simulation. not like it going to hail 1 big item at a time.
  6. May 18, 2023 at 10:01 AM
    spigatelli
    spigatelli New Member
    DFW, Texas
    2023 Limited Hybrid CrewMax 6.5 in Army Green
    Except for the part where it was in an actual hail storm, I guess. I think the idea of throwing a 5lb weight down is that you won't really see a hail stone that size, but if it can take an impact like that in one spot, a bunch of small stuff spread over a larger surface area shouldn't be a problem.
    We get a lot of hail out here in DFW and I am seriously considering this.
  7. May 18, 2023 at 11:11 AM
    WesternDawg
    Thanks for the advice! You might want to send me you spare bubble wrap ASAP as we’re getting a storm this afternoon.
  8. May 18, 2023 at 11:13 AM
    RCwyoming
    RC
    Thick blankets work, too
    ColoradoTJ and WesternDawg[OP] like this.
  9. May 18, 2023 at 11:18 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Or find a parking garage near you and pay to park there during the storm.
  10. May 18, 2023 at 11:52 AM
    Whistlindiesel tested one of the bubble covers the only way he knows how and it did remarkably well. Cool video too.
    https://youtu.be/qVs5FX4G2xc
  11. May 18, 2023 at 8:52 PM
    nodak67
    nodak67 New Member
    JR
    ok but you are guessing that the single 5lb weight is compressing the entire structure and that only has to resist 1 point. in some hail storms (outside quarter size and smaller) if you get a decent storm, the constant pounding across multiple points may cause a failure or compress the structure enough to cause contact.
    i wanna see one of these survive a decent actual hail storm and not a controlled environment.
    but then again, i have never had the luxury of dealing with a hail storm in ND that has sizes above pea much less quarter size. unlike the southern states they can get up to baseball size storms.
    i am just going by my limited knowledge
  12. May 18, 2023 at 9:01 PM
    Mr Badwrench
    Mr Badwrench New Member
    Get an area rug or piece of carpet and throw it over the hood/roof (fuzzy side down). The wind will probably sweep it off though.
    Honestly, if you live in an area with hail, you will get hail damage at some point.
    Are you going to stay home all day with your car in the garage if there is a storm in the forecast?
  13. May 18, 2023 at 9:01 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I guess the obvious question is - what is everyone else doing in CO about the hail storms?
    WesternDawg[OP] and JCBerb like this.
  14. May 19, 2023 at 5:18 AM
    FloridaMan80
    FloridaMan80 New Member
    I'm in Florida and everyone's trucks are outside b/c the garages in my neighborhood are too small. In talking with them about hail, they pull the truck as far into the garage as possible and cover whatever is hanging out with blankets and straps to keep it down.
    If your entire truck is outside, I'd purchase some moving blankets and bungee cords to keep under the back seat. This way you're always ready for hail and those will give some decent protection.
    Ray D likes this.
  15. May 19, 2023 at 6:29 AM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    In the OP's case, this justifies investing in a carport (cheaper option), adding one of those steel buildings, or adding on to the garage. There's really not much else OP can do aside from not buying a nice truck that doesn't fit in his garage and even if he went through all the trouble of constructing something, what if there's a storm while he's at work for example assuming the truck is parked outside. I had a few run-ins with hail while stationed in Louisiana, people in the city did not have covered parking so their cars got beat up. I drove a beat-up Subaru, got 10k from the insurance for the damage then traded it in shortly after. In practicality, some heavy moving blankets and some straps are the best and quickest portable solution.
  16. May 19, 2023 at 7:42 AM
    WesternDawg
    Yes, I think I’m going to have to get it mostly into the garage on bad days and use a moving blanket to cover the rest. Really just wanted to see if I was missing something obvious that others had used but sounds like it’ll just have to be a little x, y, and z. Also need to get my garage cleaned out too :)
  17. May 19, 2023 at 7:49 AM
    WesternDawg
    At the end of the day there’s just not much I can do if I’m at work or driving around, but figured I’d try to be prepared for when there is advanced notice and my truck is at home.
  18. May 19, 2023 at 7:51 AM
    Danimal86
    Daniel
    Sacramento, CA
    That was the video i was trying to find!:rofl:
