A/C Switch light flashing.
Discussion in 'General Tundra Discussion' started by motod6, Jul 7, 2019.
  1. Jul 7, 2019 at 8:15 PM
    motod6
    motod6 [OP] New Member
    2015 White TRD
    2015 5.7... Just got back from a road trip and the AC was shutting off and switch light was flashing. I've searched and read some possible causes but didn't see anything with my exact issue. My issue is it seems to happen when accelerating for a long period of time. Like going up a long grade. Did it a handful of times. I was able to get the AC back working after turning it on and off a few times. Anyone have this issue before? Or have any insight?
  2. Jul 8, 2019 at 7:04 AM
    motod6
    2015 White TRD
    Bump
  3. Jul 8, 2019 at 7:10 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
  4. Jul 8, 2019 at 8:47 AM
    motod6
    2015 White TRD
    Yeah I saw this. Just not confident it's the relay based on the symptoms/issues I'm having
  5. Jul 8, 2019 at 11:51 AM
    motod6
    2015 White TRD
    Going to check codes tonight with a techstream.
  6. Sep 4, 2021 at 3:09 PM
    Jereck1
    Jereck1 New Member
    What was the solution? My 2014 AC is flashing only when I step hard on the Accelerator. I turn the button off and on again and the AC works fine.
  7. May 15, 2023 at 9:58 PM
    Mfaley
    Mfaley New Member
    2015 CM SR5
    5100’s, Coachbuilder 3+ shackles, TRD pro grille on 18” Fuel Mavericks
    I had this same issue this last weekend. Any update on this????
  8. May 15, 2023 at 10:08 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Definitely start w/trooper2s suggestion; relay is always first place to start. However, if that doesn't resolve your issue, you're probably looking at an AC compressor or compressor clutch going out.
    By design the light will flash to indicate a problem within the system, but that's the extent of the troubleshooting it does for you. Good luck on having an inexpensive and easy fix!
  9. May 15, 2023 at 11:01 PM
    Mfaley
    Mfaley New Member
    2015 CM SR5
    Relay was replaced almost right away, as I was in the desert when it happened and I needed a quick fix. I was able to get it to work, but it eventually continued to happen and if I went too fast on the highway with it blowing at MAX, it would cut out and blink with hot air. I was able to get it to run on a lower fan speed and it stayed on for the rest of the trip, and haven't had an issue today with it blowing full speed. The clutch would be giving some sort of symptom of failure I would think, but I haven't seen or heard anything of the such. I 'll try to spin it with the engine off tomorrow to see though. Thanks!
