Color Matching Trim
Discussion in '3rd Gen Tundras (2022+)' started by GlizzyGobbler03, Mar 14, 2023.
  1. Mar 17, 2023 at 9:48 PM
    chill_trd
    chill_trd New Member
    '22 TRD limited
    Just got mine done today. PPF color looks good in the sun little more white in the shadow but I am pleased on how it turned out. Much cheaper then painted parts and ads some protection.
  2. Mar 18, 2023 at 7:49 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    how much did that cost? More pics please! Wanting to do fender flares in color match but want to ppf them after, this solves that issue
  3. Mar 18, 2023 at 9:47 AM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Looks great, that’s the color that matched my 1st gen. Venza. Did they have to remove the mustache?
  4. Mar 18, 2023 at 12:21 PM
    chill_trd
    '22 TRD limited
    Was 450. For front and bumper caps. Did not remove the grill. PXL_20230318_191645902.MP.jpg PXL_20230318_183644696.jpg
    Bigreed, =JSG= and 4mm like this.
  5. Mar 18, 2023 at 8:30 PM
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
  6. Mar 19, 2023 at 9:01 AM
    Bigreed
    Bigreed New Member
    Impressive stuff. Do you soil your pants every time you pull the tape off? I definitely would! Is this more expensive or less expensive than wrapping?
  7. Mar 20, 2023 at 6:10 AM
    nodak67
    nodak67 New Member
    JR
    i was basing my opinion on your profile pic not the pics you posted. your profile pic shows an aftermarket bumper that pretty much hides everything but the mustache
  8. Mar 22, 2023 at 8:38 PM
    Bigreed
    Bigreed New Member
    Those with black emblems on the TRD grill- did you buy a black emblem or paint the old one? What color?
  9. Mar 22, 2023 at 8:47 PM
    Breathing Borla
    AZ
    That doesn’t look like it matches at all, is it just the pics ?
  10. Mar 22, 2023 at 9:19 PM
    chill_trd
    '22 TRD limited
    Like I said its a little more white and that definitely shows in my pictures. In person with the pearl metallic coming through better it looks a lot closer. A metallic white is never going to match 100%. My door sills look like a different color when I stare at it. I would say a paint color match is probably a 9/10 match this wrap would probably be a 7.5/10. I'm happy with how it looks in person for the cost , not sure if double the price for color labs is worth the gain. I might change my mind down the line after spending money elsewhere is finished and revisit getting a painted oem parts but at $1200 I have better uses right now
  11. Mar 23, 2023 at 12:10 PM
    DexterL
    DexterL New Member
    My color x labs looks to be a closer match, mine is only slightly yellow
  12. Mar 23, 2023 at 12:11 PM
    DexterL
    DexterL New Member
    all those other parts were removed for the bumper install
    nodak67[QUOTED] likes this.
  13. Mar 23, 2023 at 1:53 PM
    chill_trd
    '22 TRD limited
    I agree that's why I said color labs is probably a 9/10 and the ppf I did is more like 7.5-8/10.
  14. Mar 25, 2023 at 2:06 PM
    Bigreed
    Bigreed New Member
    May be an in between stage- still debating the bumper piece in chrome, black or wind chill. The TRDOR grill is dark grey not black.
    The process was pretty easy though I did break 2 tabs on the top piece.
    one note for owners of 1794 (and perhaps others). The wheel wells have some insulation and 2 additional bolts in the bottom - the YouTube videos seem to not have or skip this part. Looks like this :
    Yaboy likes this.
  15. Apr 20, 2023 at 9:28 AM
    Nalwor
    Nalwor New Member
    2023 Tundra 1794 TRD OR
    Do you have a part number for the platinum badges you got to replace the chrome on the 1794 badge? Also, are the entire 1794/chrome pieces just stuck on with adhesive/3m? Thanks!
  16. Apr 20, 2023 at 3:55 PM
    Bigreed
    Bigreed New Member
    has anyone attempted this? Any tricks ?
  17. Apr 22, 2023 at 11:15 AM
    DexterL
    DexterL New Member
    Check the ultimate oem parts thread for the platinum badge numbers. I got mine from a guy who removed his. Youlll need to remove all the factory tape and break the plastic welds that hold the 1794/ platinum badge in place. It’s a tight fit so just taped them up and called it a day, almost a year later and no issues
    Nalwor likes this.
  18. Apr 25, 2023 at 4:55 AM
    MF140
    MF140 New Member
    2023 Tundra Platinum WCP Crewmax 4x4
    Just took delivery on Saturday and matched the stache last night:
  19. May 15, 2023 at 8:34 PM
    TexasTundraDan
    TexasTundraDan New Member
    2023 Tundra Platinum Hybrid
    What options did you go with to match? How’s the match to the windchill pearl
  20. May 15, 2023 at 8:42 PM
    #50
    MF140
    MF140 New Member
    I ordered the 3-piece grille surround and the upper bumper fog lamp piece from PaintedOEMParts.com. The color match is absolutely perfect. Since the above pictures, I've added a gloss black overlay to the front emblem. I'll upload a picture below.
    ryanwgregg likes this.
  21. May 15, 2023 at 8:43 PM
    #51
    MF140
    MF140 New Member
  22. May 15, 2023 at 8:44 PM
    #52
    Hella Krusty
    Hella Krusty New Member
    That looks real real good. Well done
    MF140[QUOTED] likes this.
  23. May 15, 2023 at 8:47 PM
    #53
    MF140
    MF140 New Member
    Much appreciated. I kinda like the grille itself. It has grown on me. I had debated swapping that out with the TRD Pro grille, but the smoke chrome grille surround removal makes it appear less large and gaudy.
  24. May 15, 2023 at 9:09 PM
    #54
    TexasTundraDan
    I agree looks really good. Did you install yourself or take somewhere once you received? All in from paintedoemparts how much was it?
  25. May 15, 2023 at 9:17 PM
    #55
    MF140
    MF140 New Member
    I swapped it out on my own. All 4 pieces cost around $1k at the time I ordered them. That cost included shipping from CO to NY. I only had around 170 miles on the truck when I replaced the smoked chrome pieces, as I will be trying to sell those. They are in new condition.
    Here is the YouTube video that gives excellent instruction and made the process very easy:
    https://www.youtube.com/watch?v=bvGd1WDMup8
    ryanwgregg and Mattedfred like this.
  26. Jan 26, 2024 at 10:27 AM
    #56
    ericscott21
    ericscott21 New Member
    Eric
    2023 Army Green Tundra
    If you don’t mind me asking, how did you color match that bottom piece below the fog light bezel? This looks awesome and would love to try and make it happen on my AG limited!
  27. Jan 26, 2024 at 2:34 PM
    #57
    cvd2312
    cvd2312 New Member
    2023 CrewMax SR5 TRD OR
    That picture wasn’t my truck, but I know you can get a color-matched fog light overlay from chromestoppers, or buy a whole new painted piece from paintedoemparts.com.
    The overlay is probably the cheapest route
