Leak from front of Drive Shaft?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Texan_Tundra, May 15, 2023.
  1. May 15, 2023 at 2:31 PM
    Texan_Tundra
    Texan_Tundra [OP] New Member
    2020 Tundra SR5 2WD Crewmax:
    57,000 miles
    Just changed rear diff fluid and was performing figure 8 turns to distribute it. Suddenly notice fast dripping leak from the front of the drive shaft. Doesn't smell of oil or anything. Any idea what it is?
  2. May 15, 2023 at 2:54 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Looks like just water from the A/C drain tube which is in that area I believe.
    FrenchToasty, WalnutWest and KNABORES like this.
  3. May 16, 2023 at 8:41 PM
    WalnutWest
    WalnutWest New Member
    2019 LIMITED CREWMAX MGM
    I feel pretty confident that’s your AC.
  4. May 18, 2023 at 4:09 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I had water dripping off my trans too. Doesn't always happen but noticed one time when I got under while truck was running.
  5. May 18, 2023 at 4:14 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    That definitely looks like plain water. No fluids are that color.
  6. May 18, 2023 at 5:11 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    AC drip.
  7. May 18, 2023 at 6:14 PM
    2mchfun
    Pretty sure it's blinker fluid, take it to your closest dealer and notify the service writer immediately. It's also corrosive and might dissolve the concrete in your parking area if left too long. Good luck!
    KNABORES and MadMaxCanon like this.
  8. May 19, 2023 at 5:21 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I've never seen an AC have a near steady stream of draining fluid.
  9. May 19, 2023 at 6:42 AM
    MadMaxCanon
    Maybe you have an accumulation of debris where water drains from the body and it rushed out finally and was a steady stream
    Jaypown likes this.
  10. May 19, 2023 at 6:46 AM
    You don't live in Louisiana
    TRD VO and 2mchfun like this.
  11. May 19, 2023 at 6:59 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    :rofl: True.
    That humidity though...
