oops
Discussion in '1st Gen Tundras (2000-2006)' started by wiggilez, May 14, 2023.
  1. May 14, 2023 at 1:49 PM
    wiggilez
    wiggilez [OP] New Member
    2004 access cab 4x4 tundra
    Topper, 1.2-2" lift, older motorola radio
    I was rebuilding a caliper cause the pistons were seized on one side, but then I accidentally broke the bleed valve off when I got it all back together.
    those with a keen eye might also notice that my tap isn't straight, and that would be because i drill my hole at an angle :/
  2. May 14, 2023 at 1:51 PM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    My first thought when I saw the picture was that you were going to say you broke the tap off.....
    BravoDeltaRomeo likes this.
  3. May 14, 2023 at 1:58 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 52k mi
    Hey the good news is now you get to do the 13WL upgrade
    bmf4069, N84434 and Sunnier like this.
  4. May 14, 2023 at 2:04 PM
    Sunnier
    Sunny
    San Diego, CA
    And now you can justify buying a home drill press.
    a lotta silver lining here, Buddy! :)
    bmf4069, landphil, N84434 and 3 others like this.
  5. May 14, 2023 at 2:13 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    Sunnier[QUOTED] likes this.
  6. May 14, 2023 at 2:26 PM
    Aerindel
    Aerindel New Member
    Montana
    I had a tire chain break about a week after buying my tundra, which then wrapped around the axle, and tore the break line off with the fitting, and I ended up having to do this same repair to get that fitting out.
  7. May 14, 2023 at 8:15 PM
    wiggilez
    that tap not braking is about the only thing that went right this weekend.
    I've actually been looking at those little work bench mountable units as I don't really have enough space to justify a full size one.
