Vent Phone Holder Keeping The Ring
Discussion in '2.5 Gen Builds (2014-2021)' started by Nino44, May 13, 2023.
  1. May 13, 2023 at 10:57 PM
    Nino44
    Nino44 [OP] New Member
    Junior
    2020 Army Green Tundra TRD Pro
    I had to replace the 3 screws #4-40 x 1/2 that came with the clamp for #4-40 x 5/8 to make work with the vent rings.
    https://www.ajtdesign-llc.com/online-store/Vent-Rings-c70676012 $46
    https://hondogarage.com/products/un-holey-tundra-dash-mount $39.00
    MonsterBolts - #4-40 x 5/8" Socket Head Screws, Stainless Steel, 10 Pack https://www.amazon.com/dp/B07CJSR64W $4.73
    RAM Mounts RAM-B-238U Diamond Ball Base with B Size 1" Ball https://a.co/d/4wPH6fr $9.49
    RAM Mounts RAP-B-201U-A Composite Double Socket Arm - Short Arm Compatible with B Size 1" Ball Components https://a.co/d/fAtYa36 $10.49 Short Arm / $12.49 Medium Arm
    RAM Mounts RAM-HOL-UN10BU X-Grip Large Phone Holder with Ball with B Size 1" Ball https://a.co/d/9PsRLQU
    #4-40 x 5/8 from https://www.amazon.com/dp/B07CJSR64W $34.49 Small / $38.99 Large
  2. Jun 8, 2023 at 10:42 AM
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Sick set up, did you lose the ability to adjust the vent?
  3. Jun 8, 2023 at 3:04 PM
    Nino44
    Junior
    Yes, I can't rotate the vent. I have it facing the driver side. I can open the vent, but I can't completely close it...Since I never close my air vent it doesn't bother me at all.
