My hood glare fix !
Discussion in '3rd Gen Tundras (2022+)' started by Ruger19, May 6, 2023.
  1. May 6, 2023 at 8:59 AM
    Ruger19
    Ruger19 [OP] New Member
    2022 Tundra
    I decided to add a strip of tint to the bottom of my windshield. I'm 6 3" so I made the strip just high enough to cover the glare off the front of the hood, 6 inches. most folks can make it a few inches shorter. On the outside it looks really tall due to the black strip at the bottom of the window. It works great. I also added this to the hood glare thread..............IOpTnFbMPdtpVTqP-Hhks3ZS75AGwo_p_SUqACQZ_6bae83baf0c24ae7cbdb16d4fddd8ec2c939f3ae.jpgPSzvi6DxTWsqz9tFebjKToD5ZaArKkaFUSMsRfRc_d1328f9686dba4585a559c5a6f45b86c7b143ef5.jpg
    WoodyOne and 6thyota like this.
  2. May 8, 2023 at 5:05 AM
    nodak67
    nodak67 New Member
    JR
    probably wouldnt work for those that have a hud and if there is a special insert to reflect the hud display on the inside windshield.
  3. May 8, 2023 at 7:02 AM
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    Make sure to check with your state’s laws. Most don’t allow tinting or decals below the AS1 line (upper right corner of windshield)
    Might get an unwanted talking to from the popo
    GODZILLA and AND like this.
  4. May 8, 2023 at 10:53 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I'm planning to eventually wrap the angled/raised sections on either side of the hood to eliminate the glare. That is, once someone releases a color-matched product for the '22+ Tundra..
  5. May 8, 2023 at 11:11 PM
    18" TRD Off Road Wheels
    I was going to post the same thing. IIRC no state allows tinting below that line, so the bottom of the windshield is an easy ticket.
  6. May 9, 2023 at 3:08 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    I wonder if a flat or semi gloss clear vinyl would work on the entire hood or strategically applied in areas.
  7. May 9, 2023 at 3:12 AM
    It definitely helps cut glare. The Taco TRD Pro has the decal for that reason. It's not a 100% solution, but certainly makes it better.
  8. May 9, 2023 at 6:37 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    If you color match, isn't it still gonna reflect? If you do matte or satin, I think it'll look like a different color no matter what. Unless you find a color that matches without gloss, but then looks different when it's wet.
  9. May 9, 2023 at 8:59 AM
    Bourbonator
    North ID
    '23 LE CM 6.5
    Satin should be enough to kill the glare, and as far as color matching, I'm not looking for perfection - I just don't want silly looking black strips up and down the hood.
  10. May 9, 2023 at 9:22 AM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    I gotcha. What color is your truck?
  11. May 11, 2023 at 3:46 PM
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    You don't use hud due to polarized sunglasses so it shouldn't matter to you.
  12. May 11, 2023 at 4:26 PM
    chrisf111
    chrisf111 New Member
    Reminds me of this picture I snagged of the craziest tint I've ever seen.
    LarryDangerfield likes this.
  13. May 11, 2023 at 4:31 PM
    Front_Range_Pro
    Vail, Colorado
    nodak67, RobertD and AGTundra like this.
  14. May 11, 2023 at 4:40 PM
    AGTundra
    AGTundra New Member
    Miguel
    North Carolina
    21 CM TRD Off-road
    I have been tinting for a living right at 20 years …the young bucks call em’ …
    ‘Creeper brow’ :monocle:
    we also don’t do stuff like this bc of liability
