'20 Alignment help
Discussion in 'Suspension' started by nobodyintexas, May 11, 2023.
  1. May 11, 2023 at 6:46 AM
    nobodyintexas
    nobodyintexas [OP] What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    This will be the 3rd time for me to have my truck aligned.
    and it still pulls to the right.
    Gleaning form the info below....
    can ya'll tell me why?
    what do I need to tell Firestone to do?
    the pull to the right is getting old.
    my suspension is stock...i have both TRD sway bars.
    I'm pot-commited to Firestone. I just want the damn thing to drive straight.
  2. May 11, 2023 at 7:37 AM
    nobodyintexas
    South of Houston
    when steering wheel is straight, it goes straight. if I let go, it goes to the right. a lot.
    I have to hold the wheel in the straight position.
    city driving is ok, but hwy driving gets aggravating.
  3. May 11, 2023 at 7:38 AM
    nobodyintexas
    South of Houston
    what condition would cause this?
    and why doesn't it show up on the fancy laser Firestone alignment thing?
  4. May 11, 2023 at 8:14 AM
    Vizsla
    Vizsla pretend2send
    I would have them even out the camber side to side closer to 0 degrees, little bit negative is good -.1 or -.2 at the most. Raise caster split to .4 or .5 keeping the lesser amount on the left/driver side, they have it at a .3 split currently.
  5. May 11, 2023 at 10:42 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    It's not the tire pulling to the right ? Had the same issue on mine, swapped left front and right front tires and gone.
  6. May 11, 2023 at 11:19 AM
    nobodyintexas
    South of Houston
    I've rotated twice...to no avail.
    ryanwgregg likes this.
  7. May 11, 2023 at 11:33 AM
    king.cong.1119
    king.cong.1119 New Member
    maybe completely unrelated, but most roads lean to the right for water dissipating purpose.
