Initial Development And Prototyping Of A 102 mm GM LS Throttle Body On A Supercharged Tundra
Discussion in 'Performance and Tuning' started by ViktorG, Oct 3, 2020.
  1. Mar 28, 2023 at 7:11 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I asked about my pressure loss he responded he was out. (Paraphrasing)
    reywcms[QUOTED] likes this.
  2. Mar 28, 2023 at 7:14 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Well that’s unfortunate
    e30cabrio[QUOTED] likes this.
  3. Mar 28, 2023 at 7:15 PM
    e30cabrio
    Agreed, he is an amazing person.
    reywcms likes this.
  4. Mar 31, 2023 at 6:30 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    What a crazy 180. Hope all is well on his end.
  5. May 10, 2023 at 12:09 PM
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    This is the Perfect Lamba owner's email, he said it's OK for me to share it:
    amalanssari1@gmail.com
    I don't know if they still make the adapter and harness though.
    WCTXN, e30cabrio, Wynnded and 4 others like this.
  6. May 10, 2023 at 12:11 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Sweet, I'll reach out to them, thank you sir!
  7. May 10, 2023 at 12:46 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Keep us posted if you get a response.
  8. May 10, 2023 at 2:18 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes! let me know, I'll hold to order the rcf then.
  9. May 10, 2023 at 2:18 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Thanks Viktor!
    HulkSmurf14 likes this.
  10. May 10, 2023 at 2:21 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Final hurdle would be an adapter plate.
  11. May 10, 2023 at 2:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Easy hurdle. Send me the dimensions.
    chugs and reywcms[QUOTED] like this.
  12. May 10, 2023 at 2:46 PM
    VWTim
    Corvallis, OR
    Perfect Lambda showed an adapter plate on their IG post for the wiring adapter. If not, we've got our own local machinist ;)
    chugs, snivilous[QUOTED] and reywcms like this.
  13. May 10, 2023 at 2:47 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Will do, if this harness comes to fruition then its game on lol Whipple inlet is 102mm vik's vid shows 103mm TB so would work great lol
    chugs and snivilous[QUOTED] like this.
  14. May 10, 2023 at 9:05 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I got an email response:
    Hello Bryan,
    I have a few of them in stock, but I have some issues with coding the board.
    I will try to fix the issues and get back to you next week
    Thanks,
    chugs likes this.
  15. May 11, 2023 at 6:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes!!!! How much? I’m pumped if this happens.
  16. May 11, 2023 at 6:32 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Not sure, that was the entire email...hopefully will find out more and get an order placed next week.
    e30cabrio and reywcms[QUOTED] like this.
  17. May 19, 2023 at 11:36 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I sent a follow-up email on Wednesday, no response yet...
  18. May 19, 2023 at 11:45 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Damnit. @snivilous Figure this out so we can run LS throttle bodies lol
    snivilous likes this.
  19. May 19, 2023 at 12:42 PM
    snivilous
    SW UT
    I'm not an electrical engineer :rofl:
    Send me a tundra and LS one and I'll combine them somehow though :D
  20. May 24, 2023 at 1:25 PM
    #50
    VWTim
    Corvallis, OR
    Instead of clogging the supercharger thread, I'm going to start posting my ramblings here and see if we can work through a solution.
    Found this on a Titan (Nissan) board:
    Tundra:
    pins color closed voltage open voltage (thanks texasranger96)
    6 red/y .9and .7 all the way closed 4.4 and ramps up all the way no plateaue
    5 y 4.9 4.9
    4 y/blk 2.6 and 2.2 all the way closed 4.9 and starts to plateau at about 75*, 90* being all the way open
    3 blue grnd grnd
    2 red 12 11
    1 grn 11 12
    Titan:
    Blue w/Black - TB motor - 0-5V
    Blue w/White - TB motor - 5-0V
    Yellow - Sensor Power - 5V
    Red - Ground
    White - TPS - 5-0V
    Black - TPS - 0-5V
    LS2/LS7:
    PIN ID LS2/LS7 90mm
    A.) ACT2
    B.) ACT1
    C.) +5v TPS Reference – Common to both TPS’s
    D.) TP1 Signal 0-5v
    E.) Common Ground
    F.) TP2 Signal 5-0v
    This matches with what Victor had mentioned with GM using a rising and falling TPS signal. Most should be 0-5V as it's pretty standard.
    Toyota has 2 signals, both raising, but it appears VTA is standard 0-5V (0.5V-4.5V actual) but VTA2 has a ~2.5V offset, so it's 2.5-5V. That rules out using VTA(1) for both signals.
    Throttle stepper motor:
    From Victor's first video it appears the stepper motor to actual move the TB blade works correctly, but then the TPS signal causes an error and likely CEL.
    TPS:
    If this was a simple 0-5V to 5V-0 invert, an Op-amp could be designed to cover it (I wish I would have payed more attention to these in college) I still think an Op-amp with a 2.5V additive offset might work, but the curve could cause an issue. An Arduino may also be able to process this, but I'd rather not have one inline on my TB.
    So now, anyone interested, let's poke holes in the above info. I could really use a couple voltage readings of VTA and VTA2 at idle and WOT to compare to. My truck is 1,200 miles away and won't be here for another couple weeks. I also have a message into a MegaSquirt guru in my VW club to pick his brain on this.
    OR our tuner buddies in the UAE can come thru and all of this is for naught.
    HulkSmurf14, snivilous and reywcms like this.
  21. May 24, 2023 at 7:41 PM
    #51
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I think I found a possible solution:
    http://www.torquerush.com/d2a
    Common Uses
    In D to A mode the D2A can be used to decode a GM LT digital SENT protocol throttle position
    sensor signal and convert it to the corresponding dual 0-5V analog signals. The signals can be rescaled and/or inverted as needed.
    chugs, HulkSmurf14 and reywcms like this.
  22. May 24, 2023 at 7:46 PM
    #52
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looks promising!
  23. May 24, 2023 at 8:04 PM
    #53
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That's badass! Nice find and research!
  24. May 25, 2023 at 6:14 AM
    #54
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Looks promising, I ordered one last night and sent them an email...got a response this morning:
    My Email:
    Do you know if this could be used to convert GM throttle body signals
    for use with a Toyota ECU? Specifically the 3UR-FE engine ECU? Thank
    you for your time.
    Response:
    It has been used on Toyota trucks before. We do have one Toyota TB preset setup in the app. I believe that Toyota TB has one TPS signal plateauing before the other reaches its maximum value. If your stock TB differs from this one, you can first connect it to the D2A and record its output ranges using the app. (Send us that recording) Then use those values when programming the D2A.
    I see that you ordered the GM truck harness. You will need to wire the end that usually connects the the GM stock throttle connector directly to your factory wiring, or find a connector that mates to your factory throttle connector, if one exists. Or we can supply a connector kit(housing/crimp terminals/seals) to replace your factory connector that will mate with the GM truck harness.
  25. May 25, 2023 at 7:07 AM
    #55
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    OH SNAP!
  26. May 25, 2023 at 7:09 AM
    #56
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Did you also get a Nick Willams 102?
  27. May 25, 2023 at 7:11 AM
    #57
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I haven't purchased a TB yet...I'll probably get a cheap unit to make sure it works as expected, before I get the Harrop snout with the integrated 110MM TB.
    Silver17, reywcms and HulkSmurf14 like this.
  28. May 25, 2023 at 8:03 AM
    #58
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Harrop confirmed the 110mm will physically fit and belt routing will work...only hurdles would be controlling the TB and a new intake solution:
    Thank you for reaching out and I’d be happy to help in any way I can. The 110mm TB front cover will work with the 3ur supercharger and belt routing. As you mentioned it will require a custom intake tube to be fabricated. It is designed to integrate with an LS and the control of it will likely be the biggest hurdle. The most common upgrade for the 3ur is the RCF throttle body which can be sourced fairly easy, while the 110mm is typically for drag applications. Please feel free to reach out anytime and I’ll help answer any questions you may have.
  29. May 25, 2023 at 9:27 AM
    #59
    VWTim
    Corvallis, OR
    Excellent, sounds like they can log the TPS signals of the OEM TPS to confirm if it's truely 0-5V for TPS1 and 2.5-5V for TPS2.
    I KNEW someone out there had to have solved this issue already. Sounds like it's time to track down a bulk order of Toyota OEM TB plugs and pins to make these integrate nicely.
  30. Jun 2, 2023 at 1:25 PM
    #60
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The signal converter and GM engine harness arrived today, and after some quick research I came up with the wiring diagram necessary to convert to a Tundra. Tomorrow I'll get the harness converted and shortened so I can hook it up and test functionality. Because threads are worthless without pics...here's the package including the converter, GM harness, GM engine-side connector and terminals/seals to make a Tundra harness, USB cable for programming, and instructions. Second picture is the inside of the converter where you hook up the USB, last picture is my wiring notes.
    **(Throttle body not included, I added to make it easier to understand what goes where)
    chugs, AZTundra, Saltyhero13 and 5 others like this.
