Need help with strange mystery bolt
Discussion in '1st Gen Tundras (2000-2006)' started by Element27, May 9, 2023.
  1. May 9, 2023 at 12:11 PM
    Element27
    Element27 [OP] New Member
    2005 DoubleCab Sr5 4x4 v8
    Lighting, Auxiliary Battery
    So I'm changing my oil, and as I pull off the skid plate, next to one of the mounting bolts, there's a frame hole that had this bolt sitting in it! Towards the driver's side near the oil filter, pic attached.
    Been looking around but can't find any empty threaded holes...
    Definitely a long shot but figured I'd ask in case it's easily recognizable. It's a 14mm. Anyone know what this fell off of?
    Thanks.
    2005 Doublecab 4.7
  2. May 9, 2023 at 12:36 PM
    Find any 10 mm sockets in there?
    Can’t recall anything I’ve wrenched in 14 mm other than the lower ball joint bolts. That looks a little longer than the ones i mentioned.
    Element27[OP] likes this.
  3. May 9, 2023 at 12:53 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L “Best Cab”/AC Limited 50k mi
    No idea, OP, but from reading the Full Service Manual for my year I do know that those marks on that bolt mean something about what class it is and how many ugga duggahs it can handle.
  4. May 9, 2023 at 1:55 PM
    The tip looking that way makes me think it must go into something like the block? Maybe it's a bolt for a drive accessory? But it's threaded all the way up ...
  5. May 9, 2023 at 3:21 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Hmmm....not seeing a 14mm with those markings....12mm is the largest in the 05 FSM Standard Bolt chart.
    It appears to be an 8T marking with largest bolt being 12mm. with torque of 90 Ft lb that only shows up as brake caliper bolt. Doesn't appear to be long enough for that
  6. May 9, 2023 at 4:03 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    FYI: 14mm flange bolt head is probably a 10mm thread size. Thread size is what Toyota lists for specs on torque, not the bolt head size.
    Element27[OP] and landphil like this.
  7. May 9, 2023 at 4:21 PM
    nickrick78
    nickrick78 New Member
    Pittsburgh PA
    2004 DC
    If it's a 14mm head on these trucks it's gotta be a 10x1.25 bolt. Not sure where that would come from, hopefully whoever dropped it replaced it!
  8. May 9, 2023 at 4:23 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    There are 4 bolts on the AC compressor bracket...look there
  9. May 9, 2023 at 4:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check that the driver’s side motor mount bracket isn’t missing any of the 4 bolts that hold it to the block. You should be able to see past the rubber liner in the wheel well…
    Element27[OP] and w666 like this.
  10. May 9, 2023 at 6:30 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I bet a buddy of yours put that bolt in there just for shits n giggles and to drive you mad. :D
  11. May 10, 2023 at 8:40 PM
    Element27
    Wow, thanks everyone for the responses! First time posting here, really impressed with the info, so thanks a bunch! I appreciate all the feedback, I've looked again today, still not seeing anything, I'm gonna get a little extendable mirror and try again tomorrow.
    I have found that it's the same type of bolt that holds on my brake fluid reservoir to what it's mounted to, I don't know why it would've been removed but I did have brake work done when I recently had my rear bearing seals re-done.
    Thanks again everyone!
  12. Jun 2, 2023 at 1:17 AM
    Jack87
    Jack87 New Member
    Jack
    Denver, Co
    2001 White Tundra TRD AC Limited 4WD
    Pretty much stock
    My bet is AC compressor. I know it's near that area and had a few bold with 14mm heads. This might be the bolt in the far back upper end; hard to see and reach.
  13. Jun 16, 2023 at 9:39 PM
    Tech 101
    Tech 101 New Member
    2000 sr5 extra cab
    Power steering pump?
  14. Jun 16, 2023 at 11:05 PM
    Casper421
    In the woods
    06 DC
    Have you had the water pump replaced recently?
