Ironman 4x4 Suspension
Discussion in 'Suspension' started by linwozzle, Apr 1, 2020.
  1. May 7, 2023 at 7:24 PM
    #991
    Teddybear18
    Teddybear18 New Member
    Joe
    2018 smokey mesquite 1794
    Never ending ...mostly Ironman
    Thank you for correcting my error.
  2. May 8, 2023 at 8:27 AM
    #992
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Got my replacement coilovers in just a few days after calling, excellent service.
  3. May 8, 2023 at 8:36 PM
    #993
    zeekevin
    zeekevin New Member
    For those who have this kit, are you guys running the sway bar still?
  4. May 8, 2023 at 10:03 PM
    #994
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    ACDC2ZZTop likes this.
  5. May 10, 2023 at 4:59 PM
    #995
    TeaRD
    TeaRD New Member
    2020 Crewmax Trd4x4 1794
    Ironman FCP 3/2 Lift | JBA UCAs | Spidertrax 1.25" spacers | 285/75/18 Toyo RT Trails | F/R SwayBar delete
    I just took mine for a test drive after taking the front sway bar off a couple of hours ago.
    @rruff, thanks for making that recommendation mate!
    It's hard to describe exactly how it behaves while making tight corners/turns and abrupt changes in direction but the drive is firm and I did not at all feel the vehicle being unstable going into turns. There's a slight change in angle, very subtle and that's it.
    I'm off to the Oregon Dunes this Sunday so there will be some off-road action and testing. Will report back!
    Cheers.
  6. May 10, 2023 at 5:05 PM
    #996
    rruff
    rruff New Member
    Ya, I'm very amazed and pleased at the performance of these shocks. :thumbsup:
    TeaRD[QUOTED] likes this.
  7. May 10, 2023 at 9:33 PM
    #997
    zeekevin
    zeekevin New Member
    I installed my kit on Monday, haven’t driven it much yet. But I like it so far, I was thinking of running longer front end links for the sway bar.
    Wallygator, Legend33 and TeaRD like this.
  8. May 15, 2023 at 11:36 AM
    #998
    zeekevin
    zeekevin New Member
    Quick side shot.
  9. May 15, 2023 at 12:46 PM
    #999
    rruff
    rruff New Member
    Is that the standard IM rear springs giving you that much lift?
    If you go offroad much you might like having that swaybar gone.
  10. May 15, 2023 at 1:13 PM
    #1000
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Do all OG ironman coils have that bow? I'm starting to think I'm in that same boat. What do yall think?
    I've also noticed that after I get an alignment, it's still always off. The steering wheel leans to the right.
  11. May 15, 2023 at 1:14 PM
    #1001
    zeekevin
    zeekevin New Member
    yeah that’s the standard load springs installed.
    The sway bar will be coming off when I do my next oil change… too lazy to pull the trd skid plate I installed a few weeks ago to remove the sway bar.
  12. May 15, 2023 at 2:36 PM
    #1002
    rruff
    rruff New Member
    Looks fine; plenty of clearance. It's only an issue if it bows so much that it hits the shock body.
    For some reason so many places have a tough time with Tundra alignments. Does it pull, or is the wheel just not centered? Do you have a print out? At any rate the shocks have nothing to do with that.
  13. May 15, 2023 at 2:49 PM
    #1003
    AstroDude
    Eddie
    Well if that's the case, then yeah I'm fine. It if had hit the shock body, I would have 100% known by now. I've used the hell out of them. It doesn't pull, the steering wheel is just not resting on center. I've taken it to two different Firestones and they can't seem to get it.
    I'm thinking it might be the 35" tires. I'm about to put my 33s back on for a road trip from California up to Washington. Maybe that will fix it. I had a copy of my alignment but I threw it away today. If I were to get a copy, could you tell what the problem would be just by looking at it?
    rruff[QUOTED] likes this.
  14. May 15, 2023 at 3:05 PM
    #1004
    rruff
    rruff New Member
    I could tell if something was off on the printout, but sometimes the printout doesn't match what it is... o_O It could be something simple like not having the wheel quite centered when they did the toe adjustments. When I did mine in the driveway, I recall there was a lot of iteration because the wheel would keep moving. If you have a level place to park, you can eyeball it... sight along the side of the front tires to the rear. Use a straight edge it that helps. Just a hair of toe-in is spec, and it should be the same on both sides with the wheel centered.
    AstroDude likes this.
  15. May 15, 2023 at 3:10 PM
    #1005
    AstroDude
    Eddie
    I'll give it a shot. I'm not one to mess with my alignment, I've done that before and it didn't work out too well for me. I'll also get a printout of the last alignment that I had.
  16. May 17, 2023 at 10:43 AM
    #1006
    jhines621
    jhines621 New Member
    Jonathan
    2020 Voodoo Blue SR5
    Does anyone have any experience with the rack hitting the lower shock mounts and knocking the toe out every time it drives? IM is saying that they have never seen this before and I am going on three weeks with the issue... Ready to throw in the towel right now as the alignment shop has turned me away due to this issue....
    345038397_1419333425509576_1051230767072_db8acec30ee042a42afa5d74f939e693f28279cf.jpg
    crikeymike and rruff like this.
  17. May 17, 2023 at 10:49 AM
    #1007
    Rodtheviking
    Vancouver, WA
    Sequoia
    Did you remove the tire rod end when installing the coils? Is it possible that it is in upside down?
  18. May 17, 2023 at 11:03 AM
    #1008
    jhines621
    Jonathan
    No, i did not remove them.
    I followed the video they have on their site.
  19. May 17, 2023 at 11:14 AM
    #1009
    rruff
    rruff New Member
    Wow... I wondered about that with that big spring perch so low on the shock. Nobody was complaining, so I thought it must be ok...
    Do you see actual rubbing on the parts? Only one side?
  20. May 17, 2023 at 11:26 AM
    #1010
    jhines621
    Jonathan
    Yes it is on both sides... my steering wheel is off center and I am not willing to take it off road in this condition... The last thing I need is for the Rack to break and leave me stranded...
  21. May 17, 2023 at 11:28 AM
    #1011
    jhines621
    Jonathan
    This was with the ReadyLift 3/2
    don3032 likes this.
  22. May 17, 2023 at 11:29 AM
    #1012
    Rodtheviking
    Vancouver, WA
    Sequoia
    Well this is concerning, I have to install mine soon.
  23. May 17, 2023 at 11:31 AM
    #1013
    jhines621
    Jonathan
    I just received an email from Bubba and he said they had a meeting with upper management this morning and would have an answer for me today. It just doesnt make sense...
    rruff likes this.
  24. May 17, 2023 at 11:45 AM
    #1014
    rruff
    rruff New Member
    I have the old style springs, but the perch is low because it's adjusted to 2".
    I definitely have contact with the tie rod bellows at full lock, which doesn't seem ideal, but I don't see any issues so far. It looks like yours is about the same.
    Are you sure metal parts are rubbing? Alignment could be going out for other reasons. Something loose for instance.
  25. May 17, 2023 at 11:48 AM
    #1015
    jhines621
    Jonathan
    Everything has been checked over and appears good…
  26. May 18, 2023 at 7:42 AM
    #1016
    AstroDude
    Eddie
    I'm not having that problem. Then again I have the older version. If you adjust the bottom ring, it would NOT hit right? My bottom ring is a bit higher than yours. I just locked out my steering wheel in both directions and I still clear. BUT if my bottom ring was lower, I would for sure hit. I'll upload some pictures.
    rruff likes this.
  27. May 18, 2023 at 7:45 AM
    #1017
    AstroDude
    Eddie
    These are all pictures with the wheel locked out in both directions.
    Rodtheviking, jhines621 and rruff like this.
  28. May 18, 2023 at 7:58 AM
    #1018
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sucks to see the rubbing issue. I was gonna try and lower mine to get less than 3.5”, but looks like that may not be an option if they’re going to hit the tie rod. Still haven’t got to install mine yet. Really didn’t want 3.5” in the front, trying to avoid the squatted look especially once my trailer is hooked up, as the rear is only lifted 1.5” or so with an AAL.
    Wallygator likes this.
  29. May 18, 2023 at 8:05 AM
    #1019
    AstroDude
    Eddie
    If you get the heavy duty leaf springs, the squatter issue might not be a thing. I have a 200lb rear bumper and then when I load it up with like 800lb worth of stuff, I still don't get that squatter look. On top of having the car loaded with 6 people. I can't speak to their current quality of products; it seems like their new line up is having issues compared to their prior line up of products.
  30. May 18, 2023 at 8:11 AM
    #1020
    rruff
    rruff New Member
    That's the situation I have with a 2" lift... but it's just the rubber bellows that touches. It could be a problem on switchback trails, but it all looks ok so far. I'm not convinced that jhines621 is touching more than the bellows either, since it doesn't look like it from the photo.
    This is another reason for someone to go back to the drawing board (again) and make the damn spring shorter. The new one is even longer than the old one, and that was longer than any Tundra spring in existence. I do like the long-soft spring, but it needs to be 1-2" shorter, which shouldn't be an issue. The shock doesn't have long travel, so a shorter spring should be fine.
    I fear IM is going to end up dumping this shock for 2nd gen if they need to do a redesign and more replacements for another screw up.
    I don't think it was an option anyway since there are hardly any threads left. My truck will be heavily loaded eventually, so I might be able to adjust these new springs down to ~2" but I think 3" is about the limit otherwise. Still hope someone tries it though and takes good measurements.
