Tire Pressure for Off-Road without bead lock?
Discussion in '1st Gen Tundras (2000-2006)' started by 1stGtundra06, May 5, 2023.
  1. May 5, 2023 at 11:23 AM
    1stGtundra06
    1stGtundra06 [OP] New Member
    06 DC White Tundra
    Bilstein 6112 7/5 clip Front/5100 rear; 255/80r17 Toyo R/T Trail
    I just had Toyo R/T Trail tires (255/80r17) installed on stock wheels and planning on off-roading soon. Without bead lock, what's the lowest pressures you have lowered tires to without issues? Type of terrain planned is some sandy washes and minor rocky spots.
    Thanks in advance!
  2. May 5, 2023 at 5:21 PM
    I haven't gone below ~17 or so. That was on sand. I don't know how much lower one can go.
  3. May 5, 2023 at 6:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Depends on the width of the tire vs rim, construction of the tire and how its being loaded.
    I used to run down to 15 or so rock crawling. I ran 35x12.50 on 15x8" wheels though.
  4. May 5, 2023 at 7:08 PM
    Casper421
    In the woods
    06 DC
    I used to run my old 10 plys down to 10psi no problem. 20 should give you enough footprint.
  5. May 5, 2023 at 8:27 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    I'd say 15psi on all 4 tires. That's around where I run when deflating. Keep in mind though, if you are ever super stuck its worth it to air down as much as possible, like down to 7psi. I've only ever heard of tire slippage when traveling too quickly, or doing a lot of rock crawling where rocks and whatnot push tires out of their positioning.
    Aerindel likes this.
  6. May 8, 2023 at 7:44 AM
    1stGtundra06
    06 DC White Tundra
    Thanks All, I ended up lowering to 25 psi and was good enough for the sandy wash we went through yesterday. Good to keep in mind it can go lower if needed for tougher situations.
  7. May 8, 2023 at 8:10 AM
    Tom
    Tom New Member
    It’s better to get stuck and get yourself out than have the bead pop off.
    shifty` likes this.
