Revolver x4s Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by yakeng, Apr 19, 2023.
  1. Apr 19, 2023 at 7:38 AM
    yakeng
    yakeng [OP] 3URFE Apologist
    Anyone with a Bakflip Revolver x4s have this issue? The cover is laying flat except for one spot near the cab where there is a bulge. If I roll and un-roll it, I have to go back and push it down, but it still sticks up somewhat.
    I’ve taken it off and reinstalled and adjusted with no luck.
  2. Apr 19, 2023 at 8:08 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I have that cover on my 2020, it sits flat down both sides. It sure it would stick up in one spot, assume channel is clear in that spot, or the edge of the cover where it is sticking up?
  3. Apr 19, 2023 at 11:15 AM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    Aren't those things like $1,000?? I'd be calling backflip about it to fix it under warranty
  4. Apr 19, 2023 at 3:46 PM
    yakeng
    Channel is clear from what I can see. I'm going to remove the rail and take a look under the it and see if I can find out what is going on. Did you have to shim yours any?
  5. Apr 19, 2023 at 8:50 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    I had the same issue but not as bad as yours. I unrolled it upside down all the way on a flat surface and could see where the bulges were and had to bend the metal in the top to lay flat. The one I previously had purchased for my Titan fit great but this one on Tundra seems to leak at the end. I think its because its where the ends drain. Oh the cause of the bulge its not the rails.
  6. Apr 19, 2023 at 9:02 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    I went through two revolvers. Both were replaced under warranty. The third time i had them ship me the mx4 folding model. Its been flawless. I will say the company does have good customer service
  7. Apr 19, 2023 at 9:22 PM
    yakeng
    I removed it and looked at it, reinstalled and did some slight alignment adjustments, it’s now laying much flatter, but I still see a bit of a bulge on the right side. I may unroll it upside down and try what Tundra-XP suggested.
    la Moose likes this.
  8. Apr 20, 2023 at 4:28 AM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Bakflip has a great warranty. It is just unfortunate I have had to use it on my MX4 3 times now. They have sent new each time. Call them and have them send a new one.
  9. Apr 20, 2023 at 5:10 AM
    RickPlatinum2020
    Rick
    Eastern PA
    I did not. Just removed the factory tie down channels and installed the covers channels and everything went well. The only time I have an issue is if I have something in the bed that is sticking up over top of bed, it will cause the cover to not go into channel right. All I do is push down the cover as I unroll it where a branch or whatever is sticking up and all is good.
  10. May 8, 2023 at 5:48 AM
    yakeng
    Just an update. BAK has pretty awesome customer service. They sent me a new cover, showed up in 3-days after I emailed them. Just asked for photos of my old cover field destroyed to maintain my warranty. Anyway, got the new one installed and it sits much flatter.
    lerbud1 and Tundra-XP like this.
