Full Retrofit Options
Discussion in '1st Gen Tundras (2000-2006)' started by itsWarrior, May 4, 2023.
  1. May 4, 2023 at 11:39 AM
    itsWarrior
    itsWarrior [OP] TEQ_Toothless
    Luke
    North Georgia
    Toothless the 06 Tundra SR5 DC RWD
    Bilstein 4600s, Leveled, LT265/70R17 A/T Tires, Lighting, Cosmetic stuff, Stickers and Morale Patches, Recovery Gear
    Hey everyone!
    I'm looking to do full-blown LED Retrofit Headlights for my truck. I've been researching different companies for months and I just can't decide which one to go with. I've heard a lot of good things about CW Customs but know they're more on the pricey side. Does anyone have experience with CW, TEQ, or anything else? I'm not really wanting to do it myself because I'm not confident in my headlight modification abilities, but I would consider having another member build them if they're experienced.
    I have a 2006 Double Cab
    Thanks yall
  2. May 5, 2023 at 5:12 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 DC SR5 Tundra TRD Off Road
    There's a few LED threads floating around here. If you're dead set on LEDS for an '06 find some that have 'canbus' capability. You wont need to use resistors to avoid the no fog light or other problems.
    Coming from someone who had LEDS for high/low/fogs on factory lenses, just get the high power harness and real halogen bulbs. Much better light output VS LED. But if you just want it for the bling factor, you do you. Our lenses weren't designed for LED or HID so maybe buy some projector lenses or a retrofit kit to go with the LEDs.
    Link to high powa halogen thread:
    https://www.tundras.com/posts/2976691/
    Do a search and you'll see more threads about LED problems than happy stories. I rocked LEDs for a while but am much happier with the heavy duty halogen setup in the above link.
    Here's a good discussion with links to more good threads on the same topic:
    https://www.tundras.com/threads/best-1st-gen-headlight-solution.122680/#post-3151714
  3. May 5, 2023 at 5:22 PM
    BuzzardsGottaEat
    BuzzardsGottaEat New Member
    '16 Tundra DCLB
    Round Tires
    TRS
    theretrofitsource.com
    Buy the parts, bake, install, glue. Easy peasy.
    Nothing better and no better company or better customer service, hands down.
  4. May 6, 2023 at 7:39 AM
    itsWarrior
    Luke
    North Georgia
    Thanks, guys! I really appreciate the feedback. I'm wanting LEDs for the show factor and the modern white look, and I've seen a few pictures of people running them and like the all-black look. Also, this project is far in the future, its way out of the budget for a student attending 2 colleges and is a lead at chickfila lol
  5. May 6, 2023 at 8:18 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    The 1st gen headlight’s gotta be pretty straightforward to retrofit. There are inexpensive BI-LED options for under $100. For your first retrofit, these would be pretty killer. I’ve done a few 2.5 gen retrofits, they get easier each time. Do it once, you can always open them up and make them better later.
  6. May 6, 2023 at 9:35 AM
    @TX-TRD1stGEN laid out his upgrade pretty nicely, if you think LED H4 mini projectors at ~$60 or less aren't going to work for you.
    What he bought from TRS, which @BuzzardsGottaEat already reco'd:
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-123#post-1789347
    His pile of goods:
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-33#post-1638218
    His end result:
    https://www.tundras.com/threads/1st-gen-lunch-table-general-discussion.60450/page-34#post-1639332
    It's one of the things I considered when making the no-bake projector swap with H4 minis:
    More details, which includes links to my pics doing my housings, and a video showing the process with an important warning about something you can break:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1586#post-3140724
    Finished result, housing from behind:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1584#post-3139898
    My total rundown on parts and costs, knowing I wasn't gonna butcher my nearly-new OEM housings:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1573#post-3128727
    Why I opted for a fanless bulb, when there are ones with fans available:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1586#post-3141265
    My end result as far as light output goes, before/after, before I rotated things out properly, and if you scroll down there's more output pics and a side-by-side of new OEM vs. aftermarket OEM with the mini-projector, the output and color difference is tremendous, and a short video of low/high beam:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1586#post-3142167
    Last but not least, real-world usage in action:
    https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1587#post-3142321
    Sadly, no out-in-the-woods shots. I'm overall satisfied, and I think your end result may depend some on the condition of your housings. I wish the pattern was wider, but it's easily twice as good as stock.
  7. May 7, 2023 at 10:07 AM
    itsWarrior
    Luke
    North Georgia
    Thank you again Mr. Shifty'! You're always such a huge help, I'll check out those links when I get some time. Also, thank you BlueRibbon4x4, I appreciate the wisdom
    BlueRibbon4x4[QUOTED] likes this.
