  1. May 6, 2023 at 7:22 PM
    Azblue
    The Dirty T ( ^_^)_且
    :eek2:
    DJenerated and alb1k[QUOTED] like this.
  2. May 6, 2023 at 7:27 PM
    Zoroaster
    Zoroaster New Member
    2002 LTD AC TRD
    My dog’s brain when I explain why my phone made me giggle
    alb1k likes this.
  3. May 6, 2023 at 7:46 PM
    Thanks, that's all the confirmation I need.
    I'm curious what the "(J)" and "(L)" designations are in your screencap.
  4. May 6, 2023 at 7:50 PM
    My dad used this as a work truck before I got it. Lots of......uh....nasty was in these seats. I still need to do more passes on them.
    RUSTYNUTS, txagg and Azblue[QUOTED] like this.
  5. May 6, 2023 at 7:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I think they're turning out pretty good.
    RUSTYNUTS and bmf4069 like this.
  6. May 6, 2023 at 9:38 PM
    scooterprint
    scooterprint Idiot with a wrench
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Have you ever considered washing your balls?
    RUSTYNUTS, txagg, Mr.bee and 2 others like this.
  7. May 6, 2023 at 9:46 PM
    KK6PD
    KK6PD 2 1 yr. retired . . . after 42 yrs
    ROAD
    Upper Los Angeles Foothills
    2003 AC Tundra . . . . 7th owner
    New Tires, Stereo & Speakers,Uni-Strut Tie Down Continue watching THIS SPACE FOR FUTURE DEVELOPMENTS
    So Shifty, do you have a set of Calipers, I bet if you check the pin diameter vs the hole diameter, you are going to find some numbers that might indicate why so much force was needed resulting in the breakage.
    The set I used I had to mill a couple of thousands off piece to get it to fit, and the hole diameter was off.
    I wanted a couple of thou interference fit, and a enlargement was required, but too big, the pins fall out.
    Proper sizing is the job for a tiny reamer, but if necessary new pins in a size you need are available at McMaster Carr. Look under dowel. pins
    RUSTYNUTS and assassin10000 like this.
  8. May 6, 2023 at 10:54 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Some are heavier than others.
    bmf4069 likes this.
  9. May 6, 2023 at 10:57 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Welp, Just toss em up over your shoulder and go for a walk in the rain or something.
    NUDRAT, bmf4069 and Mr.bee like this.
  10. May 6, 2023 at 11:01 PM
    alb1k
    Left Coast
    It's good
    That’s not my seat in the picture. Im just a casual observer.
  11. May 6, 2023 at 11:05 PM
    scooterprint
    Jeremy
    Conway, AR
    ‘04 DC 4x4
    Ah, my mistake. I'll pack my things and go. :hattip:
    bmf4069 and alb1k[QUOTED] like this.
  12. May 7, 2023 at 7:17 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  13. May 7, 2023 at 7:19 AM
    Almost everyone has opinions on it. They have proven that they flow more. But they also filter less. Plus the oil can gum up the MAF sensor. Most are in the not worth it camp.
    Zoroaster[QUOTED] and RUSTYNUTS like this.
  14. May 7, 2023 at 8:36 AM
    Made an attempt to partially remove the driver’s side timing cover so I could check the belt. Ended up breaking off the lower bolt underneath. Originally thought I was screwed but the entire screw came out of the hole along with the plastic and metal covering it. Took a closer look at the screws involved on both sides and it appears the screws in the center of each timing cover are corroded so bad, it would take a 10 mm bolt extractor to get them out. :(
  15. May 7, 2023 at 9:02 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    ugh. Don't fix what aint broke?
    Looks like you have the benefits of road brine AND salt air. That's a tough battle.
  16. May 7, 2023 at 11:08 AM
    So I got my passenger wheel bearing replaced sorry I only took two pictures, but we made some interesting discoveries; my inner seal was intact as no diff fluid was getting out onto the shoes or anywhere else. But it seems water made it’s way into the bearing housing areas, full of rusty fluid. We’re thinking the ABS sensor or the outer seal, but more than likely it was the 11$ o ring that seals the backing plate to the axle tube, mine was no longer a O and hella crusty and fragile.
    Other than the C clip, getting everything off and pressed out was easy. We had to improvise when pressing the collar and bearing onto the backing plate and used the same method for the tone ring. I know we didn’t get the collar and tone ring EXACTLY back where it was, maybe 1/32 further away from the backing plate that originally so I will watch for leaking fluid at my drums. Bled that wheel cylinder and took it for a spin, the crazy grinding noise is gone!!!!! With a break for some tasty French toast, it took us about 2 hours start to finish. DE9912E3-97B6-4B8E-8AF1-EF75B1B26A08.jpg73D3E25A-6999-41A5-BB55-6B0171169297.jpg
    I will probably order another set of parts of the driver side and be ready when it starts speaking up.
  17. May 7, 2023 at 11:14 AM
    What did you use for a press setup and adapter plates to get it done?
  18. May 7, 2023 at 11:18 AM
    We had a 20t press, with the flat deck widened to 6 1/2” spread and a two piece black tool off of the rainforest. Those are mainly the removal tools, the stupid dies that come with the press we’re fighting us with the parking brake assembly on the back of the backing plate, so we ended up using some 3x3 angle iron clamped around the axle(two pieces so it sandwiched the axel and held the collar to be pressed)
  19. May 7, 2023 at 11:24 AM
    :confused:
  20. May 7, 2023 at 11:27 AM
  21. May 7, 2023 at 11:43 AM
    That’s pretty cool. Makes life a lot easier.
  22. May 7, 2023 at 11:50 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    All you folks doing diffs are making me want lockers. Quit it.
  23. May 7, 2023 at 3:28 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Both of mine are broke. If I don't open the window I have no issues. Stays closed just fine.
    txagg, NUDRAT and Mr.bee like this.
  24. May 7, 2023 at 5:39 PM
    Yeah, it definitely stays closed, but again, OCD me, can't stand knowing something is broken in a vehicle I own.
    oscardog86 and RUSTYNUTS like this.
  25. May 7, 2023 at 5:47 PM
    Live 5 years in the rust belt and that feeling will quickly fade about your vehicle as you realize some things are beyond your control.
  26. May 7, 2023 at 5:49 PM
    Let's be real, I'd never do that to myself or my vehicles. Someone could offer me a job for $300k/year throwing potatoes, but if it involved moving anywhere in the rust belt, that'd be a big fat "hell naw" from me. My comfort and my stuff are worth staying put.
    oscardog86, KK6PD and bmf4069 like this.
  27. May 7, 2023 at 5:52 PM
    Unwilling to adapt for $300k? Wow, most people in that role have their sacrificial winter vehicle and just take out the others in nice weather.
    oscardog86 likes this.
  28. May 7, 2023 at 5:53 PM
    Yup, just don't need any of that in my life. The cold, the old, and the salt ... I'll stay in GA.
  29. May 7, 2023 at 7:20 PM
    daveeasa
    I did 4 years in NJ and one in Long Island. That’s enough NE for me for a lifetime. I’ll go visit, sure. And I can see the appeal of Maine or even Rhode Island. Even western PA. But f the tri state urban sprawl. I’d need 50 mil to stomach that.
    Boston is cool. I could do 3-6 months there. But that’s my limit.
  30. May 7, 2023 at 7:22 PM
    I love VT, NH, and really love Maine, it's got the kinda outdoors I prefer. The people are mostly f'n nuts like me, too. But I just wouldn't subject myself to the winters. Only way I'd do it is if I could spend the non-snow months there, then come to warmer places in winter.
